3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a stained glass mosaic portrait from a photograph.
Aimed at total glass newbies, instructions on making an 8"x10" framed stained glass portrait from a photograph of your subject. Please read the supply list and the entire instructable before beginning. From start to finish you need about 3 days: one day for gluing the glass to the frame and letting it dry, one day for gluing the glass to the glass and letting it dry, and one day to let the grout dry so you can seal it.
SUPPLIES: (see instructable for details, cost is in USD, ESTIMATED)
frame ($10-$20)
flat surface (hope you already have one)
PATIENCE (priceless)
glass ($20-$60 depending on your design)
ruler (if you don't have a suitable one, usually around $10, add a couple bucks if you need to buy the cork separately)
glue/s ($5-20)
glass cutter ($1-$40)
cutter oil (about $3)
glass nippers ($25)
running pliers (about $10)
breaker/grozer pliers (about $8)
grout ($1-$10)
plastic bowl and spoon ($2?)
paper towels ($4-$8)
newspaper/plastic sheeting ($1)
masking tape ($2)
adhesive bandages (for when you cut yourself with the glass) ($3)
gloves ($3)
sharpie ($1)
grout sealant ($5)
hanger for frame ($1)
bamboo skewers ($2?)
Total cost $107-$236 depending on what you already have and how you budget.
If you do not live near a craft store or specialty stained glass store, www.delphiglass.com is a very reputable and well-stocked store to order most if not all of these supplies from.
Step 1Find your frame
You have to have something to do your mosaic on, right? So the first step is to find a frame you like. For your first one, let's go with an 8"x10". Preferably wooden and not painted, and if it has any paint or fancy gilding it would be best if it has a protective coating of some kind. At some point you are going to be grouting and using glues, so it's best if the frame is sort of simple and easy to repair if something were to get scratched or scuffed. Hopefully your frame comes with glass, but if it does not, don't worry, the next step will cover getting that fixed.
45 comments
1-40 of 45next »
Mar 18, 2012. 1:49 PMestebansensei says:
Hello,
Congrats for you comprehensive instructions, they are great. I want to start making mosaic table tops and realize for that kind of object is quite important to get a very flat surface, how could I achieve it? Could you make an Instructional about it? I have lots of questions.
Best regards.
Nov 11, 2011. 12:42 AMlfay1 says:
Thank you so much for your tutorial! I really, really want to try this! I have been collecting old window frames!
Oct 11, 2011. 6:51 PMJuleemt says:
Lovely, amazing idea!!! i will try it soon
Oct 29, 2010. 6:50 AMamberchina says:
Very beautiful
Oct 29, 2010. 6:49 AMamberchina says:
ˆ® ˆœ"_ó(?ôÌoÙ7„DIY
Jul 15, 2010. 12:43 AMLadyPage says:
Great tutorial, I have been working with mosaics for 4 years now, and I can appreciate the work you put into this! What an amazing creation, a work of art!! Congrats!
Dec 7, 2009. 12:04 PMmouly says:
I have started working on this. I'm around Step 5 - having trouble finding the colored glass online. Most of the online stores sell assorted colors - so I can't pick the exact color I want. Do you have suggestions (links) to the products I could try?
Mar 19, 2010. 4:58 AMpjstewart says:
Since you can't find colored glass to match, have fun with it.  Remember, cool colors (greens, blues, purples) recede, and warm colors (yellow, orange, reds) advance.  Remember, stained glass portraits do not look like real portraits anyway; colors will make it look interesting.
Mar 1, 2010. 7:23 PMUna says:
Beautiful.
Nov 2, 2009. 7:22 PMfeltprincess22 says:
This is amazing. Thanks for sharing.
Sep 8, 2009. 6:49 AMmisskitty914 says:
Q. i would like to do a mosaic on my bathroom door (of a mermaid of course! i have two sons so it will be a merboy and his sealPUP). can i glue directly to hollow core door? Q. can i get away with mounting door and working on mosaic a little at a time or does it def. have to be in horizontal position? might this depend on finding glue wit shortest set up time? thanks!
Sep 8, 2009. 3:39 PMmisskitty914 says:
i am hoping to make mural full size, therefore i thought that i would use regular bull nose tile as a frame around mural. i thought that would be in keeping with project but make safe edges. what to do you think? Q. good point about the wood since it will be in a bathroom! what do you mean by sealing the wood? do you mean like boat varnish? i like suggestions about tape/contact paper as i would only do small sections at a time. thanks for answering so promptly.
Sep 8, 2009. 7:28 PMmisskitty914 says:
yeah, i think i'm going to do the hardware work first (hinges and doorknob). thanks for all of your input!
Aug 19, 2009. 11:19 PMadarii says:
Hiya, this is a great instructable I'd love to try. I was wondering if you could maybe add exactly how you convert your photo to the template you end up using for your mosaics. I know you mention using the "Cutout" feature with Photoshop but after fiddling with that I wasn't able to come anywhere near how your photo came out. Are you using other steps as well? Thanks!
Aug 24, 2009. 8:47 PMadarii says:
Thanks, that helped a lot. I filddled around some more after your tips and got some good results.
Jul 10, 2009. 7:12 PMMaxineLaRue says:
Love it!! Excellent job.
Jun 28, 2009. 6:02 PMthewall_ster says:
Your mosaics are so pretty! Making one for my sister.... I hope it comes out nearly as good!
Jun 21, 2009. 3:19 PMteachme2night says:
i used to make something like this using shrink-it paper...trace and colour the photo,then cut it up into small pieces...looked really good when i scanned and printed a portrait and made it grey scaled.like an old b&w pic..love this mosaic one..ill definatly try iy if i ever get brave enuff...glass scares me lol.
Jun 5, 2009. 4:16 AMshazni says:
this is really nice....for people who cant find coloured glass or tiles...or if it's very expensive like in my country...or sometimes if we are lazy... paste a photogragh...and then paste clear cut glass on top. then do the same grout stuff. and Bang!!! you have almost the same effect!
May 30, 2009. 5:51 AMjtong77 says:
Great ible!!! So beautiful and accessible. I have a question: why does the glass need o be glued to the frame? Is it because using the original backing will block light from going through? If that's the case, do you think it may work well to make a custom backing with plexiglass to utilize the original tabs in the back to hold the mosaic in place? That may save some glue drying time.
May 28, 2009. 7:53 AMaholway says:
REALLY looking forward to trying this--I'm just getting into mosaics--so THANKS! Question, tho: any particular reasons to do this within a frame rather than setting frame around it when it's done?
May 28, 2009. 9:46 PMSooz says:
I think the question is... can you just craft the mosaic on the glass backing, without the backing being seated in the frame during construction, and then slide the glass backing into the frame after the mosaic is completed? I'm assuming you can't do it that way because you might get the mosaic into areas of glass which are supposed to be fitted into the frame, and then you will cry great big soppy tears that you wasted all that time sizing the glass to the frame... This is so awesome and I'm now looking at a hobby in which I was never interested until I saw your 'ible. Thank you for sharing!
May 29, 2009. 7:54 AMneale says:
brilliant!!! i am so excited to try
May 28, 2009. 4:30 PMViolaceous Lilac says:
Wow! That looks really cool, and definitely something I would love to try. I really appreciate you going into so much detail for each step!
I hope I get to try this sometime. =)
May 28, 2009. 7:40 AMluigidifranco says:
excellent job! Quite a impresive result and great idea to get the picture into the paper.
May 27, 2009. 12:15 PMimakeit says:
Very cool and most creative bravo!
May 27, 2009. 5:58 AMjustin_the_jack says:
Great instructable! Thanks for taking the time to describe exactly what materials work well and which don't. I knew I was saving those stained glass shards for something!
May 23, 2009. 7:24 PMuguy says:
Outstanding work and ible. Well done. Thanks for sharing.
May 23, 2009. 6:35 AMmba2jc says:
SUPER COOL!! I JUST GOTTA TRY THIS OUT FOR MYSELF!!
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:KedaDibandion
