Make a Super Customizable Home Theatre and Movie/videogame Room
Introduction: Make a Super Customizable Home Theatre and Movie/videogame Room
How to setup and plan out a cheap, inexpensive, simple-to-setup home theatre system.
Step 1: Find a Good Location
In my basement, there is a fairly open space with a TV shelf, couches, and a desk. I had to re-arrange everything in the room to make it more comfortable.
Step 2: Use Old Computer Speakers As the Surround Speakers.
I used 3 sets of old/new computer speakers. 2 of which have two speakers and a sub, and 1 is a 5.1 surround set. I positioned them around the room. One set on left (pic 1), one set on right (pic 2), and the 5.1 behind me (pic 3).
The third picture also depicts where I sometimes put my laptop to play games (WoW + FSX)
Step 3: Connections, Wiring, Converters, and More!
Get every single cable, splitter, connector, and converter you own in your house and throw them in a pile. Sort out the 1/4 in. 1/8 in. etc. Get lots of splitters ( I have 2).
this is what i can do:
I can turn a composite connection audio out ( red, white, yellow) and then turn that into 1/8 inch connection. from there, I have two splitters that can then feed to my 8.2 (8 speakers, 2 subs) surroudn sound system.
in order to span the length of the room for the back speakers, I used a 1/4 inch cable and then turned it back into 1/8.
S-video. I can watch movies and work on my non-hd tv... =( . the quality isnt that good, but i can get movies from and watch them without much hastle.
Step 4: The Hardware!
I have a dvd player that takes the incoming signal from our tv cable and then goes into the tv.
THE DVD PLAYER CONTROLS EVERYTHING. the reason why: ONE reomte. yes. yes. yes. only one remote. It isn't even universal. the 6-disk cd player, xbox, gcube, laptop, all run through the dvd player. I have a box that controls which line to use because i have so many.
There is a little compartment int he shelf where I use my laptop sometimes. I can hook up the s-video and play WoW, FSX, or watch movies.
250gb HDD for everthing you can imagine...
Step 5: Sit Back, and Enjoy Your Very Own Show!
Doing this, you can have as many speakers as you want. You can control each speaker (or set of speakers) individually with their volume control. You can control your tv and dvd player with 1 remote. You can have your paltop closeby while watching tv. You can turn the sound FX volume up really loud so you feel your actually runnign around in WoW, or flying a plane... unlimited possiblities. Not too expensive, if you have what you need, just a little creativity!
and maybe you have a HD-TV to make it ten thousand times better!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    umm where do u buy that cord in the middle
    what do your "old computer speakers" connect to? like the laptop, or the actualy tv, or what?
    Ok I had to search it out... I found a few places on the internet that are still selling it... No not new... Prices are starting at about 79.00 and working their way up... Most stores that have it still listed are discontinued... :-( All in all.. I would say check eBay, and a few places like that and see what you can get out of it. Other than that, I find it to be a great product reviewing the specs, and the features....
    whoa! I have the same altec lansing speakers.
    A sony SLV D350p Not sure if they're still made, but it's a good DvD player
    Nice set up, but just a suggestion, you should put your sub woofer on the floor, because the vibrations from it may end up doing damage to your 360 or game cube.
    I hope that doesn't happen. The reason I put it there, is because It needs to be seen in order to be heard (my philosophy). i didn't want it feeling left out. but because you said that, I'll move it
    Sorry, your philosophy doesn't hold true. The subwoofer can go in lots of places because the bass sounds are mostly non-directional (i.e. you can't tell so much where it is coming from). Try putting it in different places (on the floor) and see how it sounds. Often you can get more bass putting it right in the corner of a room. Sometimes it may get a bit too 'boomy' and you could get standing waves (places where the is either a lot of sound or not enough), in which case just try another spot... listen to it from all the seats in the room. Often the Dolby intro to movies is good to use as a test! Good luck.
