Step 5Continue Assembly
iImage Information
Stand the wheels up and align them how you want them. I turned one of mine 90 degrees from the other so that when I looked through the top wheel I would easily be able to see the lower wheel. Put a rubber washer, a steel washer, and an acorn nut on each piece of allthread and insert them through the lug holes. Hold the base in position and screw each allthread into the corresponding t-nut. I recommend using a drill with a socket on it to screw them in most of the way, otherwise it will take forever. I recommend using power tools every chance you get. Tighten everything finger tight then make sure the tires are exactly lined up before you finish tightening them with a rachet.
