Make a Tiny Dynamo Flashlight From Junk in 2 Steps
65,861
13
16
Posted
Introduction: Make a Tiny Dynamo Flashlight From Junk in 2 Steps
The power of junk! Here is something really cool to make out of a tape player/ or CD player and a LED.
Any old LED will work, but it will be a lot brighter if you can find some 5mm white ones. Pretty much all LEDs will run happily (and forever) on the low current supplied by a tape/CD player motor.
What makes this project really cool is that the end result is not just a demonstration of free power generation, it's also quite practical. The LED is blinding bright... I always keep one handy in case of a thermonuclear exchange induced power outage.
Here's a video. It was kinda hard to take a video while spinning it...Oh, and I find it easier to spin it towards me (more leverage or something).
Step 1: Here's What You Will Need
Look in the free bin at yard sales... I was only able to find a tape player motor and a 5mm blue LED.
1. Small Electric motor from a CD player or Tape player. Larger motors will work WAY better, but tiny motors are easier to find in the junk pile.
2. Any LED. 5mm white ones are preferred because of the brightness, but little green or red indicator LEDs will work fine too.
3. It's totaly optional, but pliers would probably help a little.
Step 2: LED Installation
Twist the ends of the LED into little loops and wrap them around the leads on the motor. Give the motor a fast spin and enjoy the free light!
LEDs only work one way (light emitting DIODE), so if it wont light up, switch around the LEDs leads and try again.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    17 Comments
    I have made it around 17 years ago when I was in my high school.....but there is a problem I faced at that time
    It produces a humming sound of rotation when ever I tried to run a audio tape
    Cool. You probably need a zener diode if you want to use a capacitor. Great idea for a another project. I use this for an emergency, but it uses batteries, and we all it expires sooner or later. https://picasaweb.google.com/114139587529302221541/Misc#5650192742949431842
    Use a magnetic DC motor.
    Well, this is fun! Picture attached.
     could I use this to charge a capacitor to run the led
     The trouble is: When you spin the motor, it charges the capacitor...then the capacitor drains into the motor...
    I suppose you could use a capacitor if you had some sort of diode arrangement.
    Nice instructable! I have done this before, now i use stepper motors. just stick an led into the plug. If it does not work, just try different pins. Steppers are great because they don't need to be spun fast. However use a diode to turn the ac to dc if used to power polarity sensitive devices.
    hhehe, put a crank & a resistor on this and it's a pretty nifty idea.
    You could also  just throw a flywheel onto the gear end and have the spin last a few seconds more
