Our beers are stored in plastic boxes, like everywhere, and these are very strong (some guys made a chapel with it!). Rather than using them as bricks I chose to transform them into a toolbox.
It's a funny project (of course) that resulted in a heavy-duty, cool and spacious toolbox. I'm sure I'm going to make some jealous people on the work sites ;-)
Al you need:
- two beerboxes (one for the box, one for the cover)
- some good friends to give a helping hand
- some plywood
- a piece of aluminium sheet
- some scrap metal for the handle
- (polyurethane) glue
- chemical anchor
- a pair of hinges
- some bolts
- jigsaw
- ripper
- pliers
- drill
Step 1: Prepare the box
Any beerbox will do the job. I chose Westmalle Tripel, a strong blond beer and one of my favorites. This type of beerbox is relatively high and has the perfect dimensions for a toolbox-project.
Use saw, cutting pliers and knife to remove everything you don't need, and keep just the bottom of the box.
I decided to glue some plywood in the beerbox. This gives a perfect bottom and a perfect surface to attach the handle and the hinges. Use polyurethane glue.
In the hand-holes I glued plastified plywood as well, shaped with a jigsaw. In this zone the hole for the handle will be drilled.
Attach the frame-side of the hinges, and almost ready is your box.
Step 2: Prepare the cover
Cut out the bottom of the second box, shape some plywood and go for the glue. Use thick plywood inside, tiny plywood outside, with a small piece of plywood on the underpart of the cover as support for the hinges. Drill the holes for the hinges.
Cut out some aluminium sheet for the cover with a jigsaw. Use this sheet as model to set out the zone you'll rip out. Use a ripper to smooth the edges and to rip out some wood from the top. Paint the edges and glue the sheet in the cover.
Step 3: Prepare the handle
Cut everything into the right size, and look out for some big wood bolts.
Drill holes in the sides of the handle and use a hammer to smash the quartered end of the bolts into the aluminium.
I didn't want to spend lots of time, so I filled the steel tube with chemical anchor and put the two prepared pieces into place.
Ten minutes later: some sanding and the only thing I had to do was to drill some holes in the downside of the handle to attach it to the box.
Final phase: paint it.
Step 4: Assembly!
Ready is your toolbox! Enjoy!
Visit Our Store »
Go Pro Today »
In Canada our beer comes in cardboard boxes. Even 'Stella Artois' imported from Belgium in glass bottles. 'Stella' is one of my favourites, especially on tap in draft. Cheers and thanks for sharing this.
They're a lot easier for me to get where I am at.
