Ever wanted to make a robot that could actually do something, but never had the time or knowledge to do it? Fear no more, this instructable is just for you! I will show you step by step how to make all the necessary parts, and programs to get your very own robot up and running. I was first inspired to build a robot when I was ten, and saw Lost in Space, with that famous B-9 robot, I wanted one! Well six years later I finally built a working robot, its name- Walbot of course!
To find out more...Go to step one.
Remove these ads by
Signing UpStep 1Gathering supplies
note: these are only the prices I found from a quick search, if you look harder you probably will find better prices somewhere else, also the DIgiKey links might be broken or timed out, just search for the part description and whatever price matches the one listed here.
Parts:
Arduino USB board - $34.95
LV-EZ1 Ultrasonic Rangefinder- $25.95
2X 54:1 16mm Spur Gearmotor, FF-050- $13.80
2XPack of 4 Energizer NiMH AA Batteries- $4.85
9Volt Energizer NiMH Battery- $8.99
2X3mm Aluminum Bearing Block- $3.50
2X 3xAA battery holder (DigiKey part # SBH-331AS-ND - $0.98
2.1 x 5.5 x 9mm Right angle DC Power Plug - $0.95
2X Noise Suppression Capacitors - $0.50
L298 double full H-Bridge - FREE SAMPLE!
12"X12" sheet of 1/4" Lexan polycarbonate - $16.36
3X Aluminum 1" 8-32 standoffs - $0.45
4X 2-56 X 1/4 BUTTON CAP SCREW - $0.37
BOX of 100 4-40 X 3/8 BUTTON CAP SCREWS - $5.40
3X 8-32 X 3/8 BUTTON CAP SCREWS - $0.29
Neoprene Foam Tire - 3"D x 0.75"W (pair) - $5.36
Mounting Hub - 3mm (pair)- $8.00
9Volt battery clip (DigiKey part # 234K-ND)
Break Away Headers - $2.95
2 red 2 green and 1 yellow 3mm LED - $2.20 total
4X 1N5818 SCHOTTKY Diode (DigiKey part # 1N5818-E3/1GI-ND) - $0.15
2X 47k and 2X 2.2k and 1X 10k resistirs (digikey part #'s P47KBACT-ND and P2.2KBACT-ND and P10KBACT-ND) - $0.34
Ping Pong ball or other small low friction sphere for a caster- Free????
Custom order Arduino circuit shield see step 4
Optional / If your a complete beginner:
22AWG High Strand Count Silicone Wire Combo Pack - $16.80
Polarized Connectors to make things look neat, you will need crimp pins, 4X 2 pin header and housing, 4 pin header and housing - $6.45
Velcro for sticking things to base
Tools
these are the suggested tools to have for this project, you could either buy borrow or use something else you have for the same purpose.
Bandsaw for cutting the Lexan base and various parts.
Drill Press for drilling straight holes in Lexan base.
Tap and Die set for tapping holes in the Lexan base.
Good soldering iron for soldering various parts on the robot.
Digital Multimeter for debugging electrical components.
Wire strippers
Needle-nose pliers for gripping and crimping the connectors
can u pls mail it to ashikbekal@gmail.com
pls Brandon
Is the schematic still available and where can I get it
Thanks
but for now heres a link to where you can also find the same instructable www.societyofrobots.com/member_tutorials/node/45 also take a look at some of the other member tutorials and stuff on that site. I know the guy who runs it, and as far as hooby robotics goes- he's the best.
