iImage Information
(this instructable would like to be entered into the wallet competition and laser cutter one)
If you use/buy skimmed milk in the TectraPak (sp?) cartons you end up throwing away at least 1 empty carton a day -which is a terrible waste and surely must make a huge impact on the enviroment! So here is one way of recycling at least 60% of that waste into something awesome, creative, and unique!
Step 1Cut the carton up..
iImage Information
First you will need to cut off the top. try cutting as little as possible to save having to do it all over again because you cut off too much. So cut off the very top of the carton and then rinse it out with water and then dry it (or wait for it to dry) I reccomend using as sharp a knife as you can, the sharper the knife *hopefully* the neater you cuts will be and presumably your wallet. After you have cut off the top and rinsed it out do the same to the bottom of the carton, cutting as little off as you can.
