3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make a well-insulated travel cooler
This may not be a problem for most people, but I have a habit of keeping drinks and food in my car so that I can use them on my work breaks. This becomes a problem in the summer when the car gets hot (140dF). Nobody likes drinking their DrPepper at 140dF. Simple plastic lunch coolers with thin foam filling and solid lids won't keep cold for long at all. After much debate over the possibility of using active refrigeration schemes, I decided that the easiest and most reliable design was simply an icebox. This would also make the cooler more portable and lend it to a variety of uses.
Step 1Think first
Think first
As for design, we want the box to be absurdly insulative for a couple reasons. First, more insulation results in a longer melt time on a given mass of ice. That's simple enough. As long as there's solid ice, the block's temperature remains relatively constant. Second, the greater the disparity between the thermal resistance of the box walls and that of the air inside, the less of a temperature gradient exists between the ice block and the walls of the cooler. This is what allows me to avoid using shaped or distributed (bulk crushed ice) charges.
I personally needed it to fit behind the passenger seat in my car. This limited the dimensions, so I had to find a size that would work with different arrangements of beverage containers and ice containers. I chose an internal box size of 7W x 10.6L x 10H (inches). Different applications would require similar planning.
I considered a few materials for the insulation: FIP polyurethane foam inside a cardboard box, EPS (beaded polystyrene foam), and extruded polystyrene foam. Since the first two ideas suck and I already had a sheet of 1.5" pinkboard, I decided to use that, thus giving the box its absurd 3" thick walls.
11 comments
Apr 30, 2011. 7:06 AMslim451 says:
I have used "Enerfoam" adhesive for joining foam pieces together. It is available from some building supply stores having used it on ICF's (insulated concrete forms) for a concrete foundation wall. It bonds well and expands to fill any voids. It sticks to most things so be careful when using it.
Jan 1, 2008. 6:34 PMKevvixx says:
I really like this. Very useful and original. I think I'm going to have to make this, but I would probably do it upright with a hinged door. and keep it in my room.
Sep 30, 2010. 4:02 AMWingDings says:
There is an advantage to having the "chest freezer" style orientation rather than the upright fridge one, in that while the door of an upright fridge is open, the (heavier) cold air falls out of a fridge, and is replaced with warm, moist air.
That warm, moist air is an extra thermal load for the refrigeration unit (in an electric fridge) or stored refrigerative capacity (ice, etc., in this kind of cooler) to remove, and so will lead to your stored stuff heating up faster, or your stored refrigerative material running out sooner.
Jul 2, 2009. 9:15 AMjackbomber says:
Dr. Pepper on work breaks eh??? looks suspiciously like milwalkee's best light haha Great Idea.
Aug 25, 2007. 10:29 AMLowEnergy says:
Nice instructable! It could work well in a stationary application as well as a portable application, as a substitute for those inefficient mini-fridges. In a climate-controlled room, you'd have to add ice much less frequently
Can I suggest adding it to the new group I created, energy efficinecy?
Aug 17, 2007. 1:24 PMnepperhanman says:
Two thoughts/observations: 1. Restricting air flow/exchange has helped us keep cooler items frozen longer. We do that by first placing a draw top garbage bag in the cooler and closing the bag in between openings of the cooler. We have kept the ice chest items frozen in a regular picnic cooler for two full days that way. In this super insulated version that might be four days. 2. There are fiberglass/plastic backed panels of pink board used in the cell phone stealth business. If you could get your hands on some of that for the bottom you would have a particularly strong base from which to add handles or carrying straps.
Jul 21, 2007. 4:10 PMve2vfd says:
I like it! I'd probably make a flat ice pack (freezer ziplock bag maybe?) thats permanently attached to the lid.
Jul 21, 2007. 5:09 AMMyself says:
I've considered doing exactly this for quite a while. How did you waterproof the bottom, or does it just leak meltwater on your seat? I assume the glue forms a pretty good joint, but is that all you rely on? Keeping the ice above the drinks would reduce the thermal stratification. Do you think the pinkboard is strong enough to support an "ice hammock" hanging from the lid?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ElFantastic0
the letter B
