Step 2Cutting things, building things
All the panel sizes were cut on a radial arm saw, though one could easily do this with a circular saw or a hot-wire cutter. I could've done a bit better on a few of the pieces, but the biggest problem wasn't my measurements. It's that the sheet was bowed and all the edges were not perpendiculars, but radials. Make sure to get a flat sheet, especially if your foamboard is thicker.
The box is assembled using a polyurethane glue such as "Gorilla Glue" or any of the similar glues on the market. The advantage here is that they have a good bond strength and they expand to fill any gaps between the sheet edges. The assembly of my box was made difficult by the bowed panels as they would constantly leave gaps at their edges. That's what clamps are for though. The clamps are pretty necessary anyway, as the polyurethane glue doesn't have a very high initial tack. If your panels are flat, you could probably get by with using tape to hold it tight.
comment
Add Comment
Add Comment
