Step 3Foil facing
For the sake of durability, the aluminized face should be positioned toward the inside. You can identify the aluminum face of the film by rubbing on it with your finger (the aluminum comes off) or using an ohmmeter.
The mylar is attached to the box using a spray adhesive. I used green label 3M Spra-Ment, although there are several compatible adhesives available. CHECK THE LABEL. Not all spray adhesives are safe on foamboard. Cover the box by rolling the sheet around the sides, leaving the excess to form flaps to cover the top and bottom. If you can wrap a present, you can do this. It's best though, to spray the box (not the film) one side at a time. The glue tackifies quickly, and you can't reposition the film on tackified glue. Once the film is in place, It might be a good idea to use clear packing tape to hold down all the edges and reinforce the corners.
Add Comment
