Why not make a custom brand that you can use as much as you like?
I wanted to make one that would last and that could be used many times over the years. I thought a simple coat hanger wire one would distort after lots of use, and I wouldn't be able to get the detail I wanted.
I had never done anything like this...
But I won a cordless Dremel from the Halloween Challenge! Time to put that thing to use!
Remove these ads by
Signing UpStep 1Materials
What you'll need:
Materials
- The design of whatever you want to wood burn
- A piece of metal plate stock - I used 1/4", that should work for most everything
- A solid or hollow metal rod for a handle
Tools
- A Dremel or other rotary tool - I won one from Instructables in the Halloween challenge, thanks Instructables!
- Tungsten Carbide cutting bits - get a fine and regular size
- A hacksaw or other metal cutting device
- A vise to hold the workpiece
- A sharpie, and a pencil or carbon transfer paper
- Safety gear - earplugs or headphones, safety glasses
First thing to do is make up your design
- Some things to know - A design with straight lines is easier to carve than one with lots of curves (not that it stopped me)
- You need to remember to MIRROR your design! Or else your brand will always be backward!
- The smaller the detail, the harder it is - again, didn't really deter me but just FYI
Choose your metal stock
- You need the metal you use to be thick enough so that you wont cut through, but not so thick as to be tough to heat
- The handle should be generously long - you don't want a brand on you!
Once you've bought or scavenged everything, time to get started...
To help with the mirror image, I use Microsoft Word or a copier that has a setting to make reversed images.
I only bought my wife a ring...
