3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make acoustic panels for your recording studio or home theater
Step 5Trim the fiberglass
Trim the fiberglass
The fiberglass needs to be trimmed to fit inside the frame (since we built it to 2' x 4' outside dimension). Use a utility knife to trim 1 1/2" from both a long and a short side. This can also be done on a table saw, but we found that the utility knife keeps the fibers and dust in a smaller area. Do not use a hand saw, as it will shred the board more than cut it.
Use caution when cutting fiberglass. Wear long sleeves, gloves, a breathing mask, and proper eye protection to prevent the fibers from causing irritation. When you are done cutting, thoroughly clean your work area with a broom, vacuum cleaner, and damp cloth.
NOTE: A perfectly straight edge isn't too important since the board will be covered by fabric anyway. We found it better to aim for cutting slightly less off than to cutting more, because the extra friction helped keep the board in place while covering it with fabric.
1 comment
Jan 9, 2011. 8:39 PMMatrixDweller says:
Best tool, bar none, for cutting rockwool or fiberglass board is an electric carving knife. Very little mess and it cuts through like butter.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:TheHighwayBeautiful
My name is Bryan. I'm a 23 year old drummer/musician from NY. While most of my "Making" is music, I do occasional other projects to support and enhance my performances and recordings. I joined this si...
more »
