Make an Attiny13 Based IR Proximity Sensor for $2.42
35,516
119
36
Posted
Introduction: Make an Attiny13 Based IR Proximity Sensor for $2.42
NOTE: The diagram is wrong. The sense pin goes on pin 6 (one more to the left), not pin 5. I'll update the diagrams soon.Thanks to brmccollum for the correction. (Diagrams now fixed)
This is an extremely cheap IR proximity sensor you can make with a few cheap parts and an AVR programmer. I use an Arduino as my programmer in this Instructable.
This sensor only has a range of about 3 inches. You can easily add more LEDs or brighter ones to extend the range. You can also easily re-arrange the LEDS to detect when a beam is broken as well.
The design takes advantage of a cheap AVR (computer on a chip). The computer pulses the IR LEDs off and on and compares the analog readings from the sensor in each state. When the reading with the lights on is above the reading with the lights off the sense pin goes high indicating the sensor is seeing it's own (reflected) light. There is an LED on the sense indicator in this design so you can see when the sensor engages. You can connect the signal right to a microcontroller like an Arduino or Picaxe.
This design moves some processing out of your main robot brain and into it's own node. You may want to debounce the signal, but you don't have to flash the leds and take the readings. You can also use just one digital pin to take the reading. The sketch is around 700K out of 1024 available.
Why I built this
I'm way out of high school, but this is part of a series of designs related to bringing the robots from the game Robot Oddysey into the real world. I want to allow grade schoolers the same chance to learn robotics I had. So I am working on building really inexpensive robots that can move in 8 directions without turning. The "bumpers" are complete now.
Step 1: Gather Materials
The electronics you will need are as follows. Digikey part numers and prices are as of 4/18/2012.
Quantity
Digikey Part Number
Description
Cost
475-1439-ND475-1439-ND
PHOTOTRANSISTOR NPN W/FILTER 5MM
$0.53
ATTINY13A-PU-ND
IC MCU AVR 1K FLASH 20MHZ 8PDIP
$0.95
CF14JT220RCT-ND
RES 220 OHM 1/4W 5% CARBON FILM
$0.24
CF14JT1M00CT-ND
RES 1M OHM 1/4W 5% CARBON FILM
$0.08
2N3904FS-ND
IC TRANS NPN SS GP 200MA TO-92
$0.18
754-1241-ND
EMITTER IR 3MM 940NM WATER CLEAR
$0.44
TOTAL
$2.42
You will also need
  • Electrical tape
  • plastic drinking straw
  • scissors
  • Wire snippers
  • breadboard and/or soldering iron
  • Jumper wires
  • An AVR programmer (any Ardunio compatible will do)
  • Ardunio 1.0 software with modifications to program Attiny and the Atiny13 core
Step 2: Create a Sensor Shroud
You don't want IR light leaking in from the sides of the sensor. We will create a little tunnel from electrical tape and a straw. My tape is opaque to IR. Yours probably is too but you can line it with aluminun foil if you want to be sure. Make sure no metal is exposed because it will ruin the circuit.
Cut off about 1.5" (4cm) of the straw. Wrap it in electrical tape. Trim the ends and make it neat.
Cut about 1/2" (8mm) bit of tape and roll it up from the short edge. Fold the roll in half. It won't stay but put a good crease in it. This will plug the bottom of the sensor and keep stray light out that way.
Step 3: Prepare the Sensor
Cut the middle leg off your phototransistor if it has one. It's not needed in this design and can actually cause problems if you leave it on. You don't have to cut it all the way back, but don't leave very much.
Gently wiggle the sensor into the straw until the base is 1/4" (5mm) in or so. Push in the folded roll of tape behind it and seal the back with a bit of tape.
Step 4: Wire It Up
You can do this on the breadboard or solder it all together "dead bug" style. Do the breadboard first so you can program the Attiny13 easily. Once it works you can solder it together.
Follow the wiring diagram and keep some notes in mind.
  • The chip, LEDs and transistors only work one way around.
  • The short leg of the LEDS is connected to the 220 ohm resistors.
  • The long leg of the phototransistor is connected to the 1meg resistor.
  • You can add more IR emitter/resistor pairs in parallel with the existing pair. Get the basic circuit working first. You could also just use one IR emitter, but 2 seemed to make the readings a lot more stable.
Note: After I did this diagram I discovered a 0.1uf capacitor across the Attiny chip from VCC to GND helps out with stability. It's recommended to put one across every microchip in a design. It worked reasonably in the breadboard without it, but the circuit board really improved with the addition.
Step 5: Wire Up the AVR (Arduino) and Program the Chip
If you burn the ArduinoISP sketch to any AtmegaX28 based Ardunio it can burn the Attiny chips program. The diagram shows a pro-mini to save space. Just use the same pin numbers for whatever board you use. If you have another AVR programmer I assume you know how to use it.
Install Attiny13 Core13 from sourceforge. Here is an Instructable by diy_bloke with directions and even a zip file to download.
Here is MIT's instructions for modifying your environment to burn Attiny.
This page might help if you have problems. Check the comments.
Wire in the Arduino. You can unwire it when the programming is done.
Load the INO file and burn it to the Attiny13 chip.
Alternately just use an AVR programmer to burn the hex file or Instructable author nikkipugh has a super strip board shield design for programming attiny13 chips.
You may need a 10uf capacitor or 120 ohm resistor from the Arduino's reset to ground.
code:
Attiny13 proximity sensor
by Dustin Andrews 2012
License: Creative Commons Unported http://creativecommons.org/licenses/by/3.0/
//Do some low level AVR pin writing to save instructions. 1010 of 1024. Close!
#define SetPin(Bit)    PORTB |= (1 << Bit)
#define ClearPin(Bit)    PORTB &= ~(1 << Bit)
//wire your IR led to this pin. (chip pin 5?);
#define irOutPin 3
//This pin goes high when the sensor detects and obstacle. (chip pin 6)
#define outPin 1
// wire this pin to your phototrans vcc-->phototrans-->pin4-->1M res-->gnd(chip pin3)
#define sensorInPin 2
void setup()
pinMode(irOutPin, OUTPUT);
pinMode(outPin, OUTPUT);
//pinMode(2, OUTPUT);
analogReference(0);//analogread won't work on Atiny13 w/o this line. Won't work on others WITH it prob'ly.
void loop()
static long difference = 0;
unsigned static long lastTime = 0;
SetPin(irOutPin);
delay1();
unsigned int r1 =  analogRead(sensorInPin);
ClearPin(irOutPin);
delay1();
unsigned int r2 = analogRead(sensorInPin);
difference += r1 - r2;
if(millis() - lastTime > 5)//might get a smoother response with bigger delays
   if(difference > 0)
      SetPin(outPin);
   else
      ClearPin(outPin);
   difference = 0;
   lastTime = millis();
void delay1()
   //delay(1) is too costly in memory. Why is this so much cheaper? :D
long start = millis();
while(true)
   if(millis() - start > 1){break;}
Step 6: Build Some Awesome Robot With the Sensor
At this point you should have a functioning sensor on the breadboard. Solder it together for a cheap sensor you can add to a robot. The sensor will end up having 3 external wires. VCC (5v), GND and Sense. See the circuit diagram for where to hook into "sense". It's the same wire as the long leg of the indicator LED.
Troubleshooting:
  • Check all the wires.
  • Wiggle the LEDs and make sure they align well with the barrel.
  • Check the wires again.
  • Have someone look over your shoulder while you explain where each wire goes. (This helps so often it's not even funny)
  • Check the polarity of the LEDs and sensor and transistor.
  • Check the polarity of the Attiny. If it's hot you put in in backwards.
  • Use a phone or other digital camera to check that the LEDs are glowing.
  • Turn off any flourescent lights and try the sensor away from sunlight.
  • Take one the LEDs and attach it to long wires and put it right down the barrel of the sensor to see if it can see at all.
  • Change out the 1M Resistor for smaller values to get less sensitivity.
  • Tweak the code.
Step 7: Optional - the Circuit Board
This step has a PDF you can use on a laser printer with the toner transfer or photo methods of making boards. There's lots of instructions all over for how to do this. I did determine that adding a .1uf cap across VCC and GND on the chip helps make the board work more reliably.
Print the pattern on what will be the bottom of the board. Put in the components in from the blank side of the board according to the diagram and solder them. I bent the LED and sensor leads 90 degrees so the sensor would be looking "ahead".
The PDF and layout are slightly different than the picture. I added the 0.1uf cap explicitly and made the base leg of the transistor run keep away from the sensor line.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
36 Comments
Hi! Thanks for sharing this. I've working on this for a couple of days now since I read this instructable and this article http://www.ikalogic.com/infra-red-proximity-sensor-part-1/ . I'm using a Picaxe 14M chip and a clear capsule phototransistor (w/o filter) So far I found this: The sensor is very sensitive to daylight (I was working next to my room's window LOL ;) ).
In order to solve that problem, watching the behavior of the readings on my PC, I programmed my Picaxe to read the value of the phototransistor on the ADC0 (leg 7) with a 8bit resolution and add some to the reading (4 to be specific); the microcontroller takes a first reading of the phototransistor with the IR led (only one), adds 4 to it, takes a second reading of the prototransistor with the led on and compares, if the second is bigger than the first the indicator led goes on. This is reliably working for me between 4" and 1/2" even working next to the window!!! :D
Here is the program I downloaded on my Picaxe:
main:
low 5
readadc 0,b1
debug
high 5
readadc 0,b2
debug
let b3=b1+4
if b2>b3 then high 4
else low 4
pause 5
endif
goto main
The IR LED is connected on the output 5 and the indicator LED is connected on the output 4. I'm not familiar with Arduino, so I hope Picaxe people can use this too, this is really helping my little robot so, thanks again!
I am so glad this helped you out. Thanks for the insights. My program could use some tweaking for working in bright lights or sunlight. Right now it can get confused under fluorescent lights that have a similar period.
amazing
work mate
I had hoped that your recommendation to include analogReference(0); would solve my analogRead problems on the Attiny13... but sadly it doesnt I updated my core... but no luck.
Any suggestions?
seems it is fixed. apparently needed to restart my IDE after the update of the core
I am getting an error:
Arduino: 1.5.6-r2 (Windows 7), Board: "ATtiny13 @ 4.8MHz (internal 4.8 MHz clock)"
Attiny13IRproxsense.ino:22:21: error: Arduino.h: No such file or directory
Attiny13IRproxsense.ino: In function 'void setup()':
Attiny13IRproxsense:24: error: 'OUTPUT' was not declared in this scope
Attiny13IRproxsense:24: error: 'pinMode' was not declared in this scope
Attiny13IRproxsense:27: error: 'analogReference' was not declared in this scope
Attiny13IRproxsense.ino: In function 'void loop()':
Attiny13IRproxsense:34: error: 'PORTB' was not declared in this scope
Attiny13IRproxsense:36: error: 'analogRead' was not declared in this scope
Attiny13IRproxsense:42: error: 'millis' was not declared in this scope
Attiny13IRproxsense.ino: In function 'void delay1()':
Attiny13IRproxsense:61: error: 'millis' was not declared in this scope
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
I think the problem is that we used the 20 MHz chip you recommend, but there is no 20MHz option in the board menu.
This circuit works for me as described...but according to the datasheet it shouldn't(?)
The datasheet for the phototransistor used says that, starting from the long pin side, the pins are: BASE, COLLECTOR, EMITTER (long, long, short).
So, actually, the circuit has the BASE connected to GRN through 1M Resistor (and also to the ATTiny input) while the EMITTER goes to +5V.
I'm very new to circuits/transistors, but that setup doesn't make any sense to me. Why does it work? Am I misreading the datasheet? (This is the datasheet I'm looking at: http://catalog.osram-os.com/media/_en/Graphics/00045426_0.pdf)
I think that datasheet is wrong. Last time I clicked the link the datasheet was in English and the pins were CBE not BCE. I agree it shouldn't work as specified in that datasheet!
American stuff is usually CBE, while Japanese components are often BCE. But they should have different part numbers to differentiate them. As always, you are the final inspector.
I think it's at least possible that the part you refer to in your instructable (475-1439-ND) refers to a slightly different part on Digi-Spark and the pins are different now.
Mine works by ignoring the first long pin and putting the short pin to the 1M resistor (and Pin 3) and the middle pin to +5vcc - so if anyone orders the part from DigiSpark and it's not working the way you think it should - I would try this!
