loading
This tutorial will show you how to assemble a Badge Kit. The Badge Kit is unique in that it uses a piece of cardboard which has been pre-printed with Bare Paint in the shape of a jaunty octopus with a hat. Your job is to poke some holes and attach a couple of components using Bare Paint as a cold solder. This is a fairly straightforward kit and we'd expect you to have your octopus bliking (or changing color) in 30 minutes (including drying time). Have fun!
**If you don't have the kit, all you need is some conductive paint, battery & LED's. You can make your own drawing and watch it glow!
Step 1: Components
The parts that you'll need:
1 x Bare Paint Pen (or any conductive paint to draw a circuit with)
2 x Octopus Badge (or any circuit drawing of your own)
2 x Badge Pins with stick back
2 x Coin Cell Batteries
1 x Blinking LED
1 x Color Change LED
**If you like you can get all these components as a kit from our online shop otherwise feel free to improvise!!
hi can you provide me detail for some discussion <br> <br>email: subrotradeindia@gmail.com
Is there a way to add a mini switch so you can change between on and off? <br>-Doctordv
You could definitely incorporate a switch if you wanted to add this function! :)
If not, then wouldn't the light stay on until the battery runs out? <br> <br>-Doctordv
Yes! If you just left it on it should probably run for about 5 days though (because the LEDs use up so little poer). <br> <br>However, one of the advantages of the paint is that it works as a cold solder so you could easily replace the battery if you want to keep using it! You can just pull it out, and pin a new one in!
About This Instructable
11 favorites
License:
Bio: Bare Conductive makes creative electronic tools for any designer, engineer or aspiring maker.
More by Bare Conductive: Make your own touchscreen gloves Make a musical cardboard guitar Enchanted Puppets
Add instructable to:
