loading
Step 7: Step 5 - Attach your badge pin
Remove the plastic paper from the pin and attach to the badge back. That's it, you're done! Wear your badge with pride!
hi can you provide me detail for some discussion <br> <br>email: subrotradeindia@gmail.com
Is there a way to add a mini switch so you can change between on and off? <br>-Doctordv
You could definitely incorporate a switch if you wanted to add this function! :)
If not, then wouldn't the light stay on until the battery runs out? <br> <br>-Doctordv
Yes! If you just left it on it should probably run for about 5 days though (because the LEDs use up so little poer). <br> <br>However, one of the advantages of the paint is that it works as a cold solder so you could easily replace the battery if you want to keep using it! You can just pull it out, and pin a new one in!
About This Instructable
11 favorites
License:
Bio: Bare Conductive makes creative electronic tools for any designer, engineer or aspiring maker.
More by Bare Conductive: Make your own touchscreen gloves Make a musical cardboard guitar Enchanted Puppets
Add instructable to:
