Make an Evaporative Terra Cotta Beer Chiller by jolshefsky
Featured
Step 4: Add the fill tube and cement.
Use a piece of rubber tubing to provide a fill tube. The idea is to make it big enough that you can actually add water (and to provide a reservoir as the water slowly wicks into the sand).
Mix up a tiny batch of cement -- about 1 cup. I'm no expert at mixing it but I know it shouldn't be like wet sand and it shouldn't be like soup. If it's too dry then it won't seal and if it's too wet then it will crumble once it's set up. If you're not familiar, try a batch and see how it works.
Anyway, insert the fill tube along the edge of the sand. Stick it into the sand just a small amount (maybe 1/10" or so) -- just enough that the cement won't flow around and seal it.
Add the cement around the edge and try to seal around the fill tube as best you can. If you want to make it look less industrial, you can add decorations into the cement -- once it cures you can't.
Let the cement cure overnight.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
