Make an External HDD from Old External CD/RW
Pretty straight forward conversion of an old external cd/rw to a more useful external hard drive.
1-external cd/rw (preferably the more boxy type)
1-hard drive (must match internal connector of drive case, needs to be formatted/sysed )
1-small fan (preferably able to fit the case nicely and quiet enough not to be annoying)
1-5.5"-3.5" bay insert to hold drive (should be easy enough to fab if necessary)
---minor tools and the want to do it
Disclaimer and ---t
I take no responsibility/liability for any damage to anything you might incur from this instructable. Do not ingest, spray into eyes, etc..............................
I've been using a spare 40gig in this for weeks before this and now a couple weeks after w/o issue mounted under misc. *nix or doze.
Step 1Dissassembly
Dissassembly
-- Remove the case screws, clips, etc. and open the case. (Just work cautiously so as not to damage the case)
-- Remove any mounts or screws holding the cd/rw drive.
-- Gently unplug the power, ide, and audio connections.
-- Remove old drive and install elsewhere or shoot it, blow it up, scavenge laser and motor,etc.
32 comments
Oct 16, 2010. 11:30 AMdanielemur says:
I tried this and with a cd drive connected it works fine, but when I connect a hard drive it doesn't show up in "my computer" and in device manager (It does show up as mass storage device) it says the device cannot start.
Apr 24, 2009. 11:45 PMmisterchar says:
please help my windows xp can't detect the harddisk drive
May 4, 2009. 12:39 AMmunchman says:
Make sure all the connections are secure, and that the HDD works.
Aug 2, 2010. 9:19 PMmisterchar says:
yes all connect correctly ... winxp still see it as optical driver nor hdd drive ... so it's can't detect it >.<''
Aug 9, 2008. 11:50 PMeclayton says:
Thanks a bunch for this tutorial. I was going to buy an enclosure, and I remembered I had a Memorex CD Recorder under the couch. I'd never heard of putting a hard drive in a n external CD Drive, but when I Googled it, I found this site. I used an AMD processor fan and put it on top as an exhaust fan with a screen and cover to make it look nice and protect the fan. I used a mesh blank plate that I had laying around for the intake on the front. I like how it all looks, but I didn't realize how loud processor fans are! I think I'll go get a couple of those smaller fans like you used, and the next ones I make will be QUIETER! Thanks again, I enjoyed this little project! Eric
Sep 28, 2008. 3:10 AMDerin says:
Ewilhelm eric or other eric?
Sep 28, 2008. 8:46 PMeclayton says:
? Not sure what Ewilhelm Eric is, so I must be some other Eric! :-)
Jul 25, 2009. 10:01 PMthermoelectric says:
:-) Eric Wilhelm is the CEO of Instructables, Incase you haven't noticed that yet...
Jul 25, 2009. 10:19 PMDerin says:
yes i have
Jul 26, 2009. 2:00 AMthermoelectric says:
Well, I was saying that to eclayton, but oh well
May 24, 2009. 1:32 AMabadfart says:
can i do this with a old iomega zip drive
Dec 7, 2008. 6:26 AMEmankcin says:
I found my iOmega CDRW, but I could not find the AC adapter, which kinda looks like a PS/2 Mouse connector, and may be an iOmega propriety adapter. I was wondering if anyone knew the voltage requirements of the CDRW, and if it might be possible to remove the AC input from the CDRW, and solder in place one from something else with a low power output, such as one from a DSL modem or something else small like that?
Apr 6, 2009. 2:37 AMralphh says:
Only just spotted this! The CDRW6402 has 5 power input pins, three on the right, from the top, 0V, 0V and +12V 0.75A; and two on the left, for +5V 1A. These are not big demands: you could certainly use another supply unit, or bring it out of the PC itself. Does anyone know how to get the blue Iomega cases open without breaking them?
Apr 3, 2007. 9:14 PMLasVegas says:
Good Job! Do take note that many external cases for Optical Drives are limited to 137GB (128GB in base 2). This is a limitation of the slower ATA chip in the enclosure.
Feb 16, 2008. 5:42 PMszymk1 says:
Ha, unfortunately I discovered the 137GB limit the hard way :) I converted an antiquated sony recorder box into a external pocket but after I swapped a 15GB harddrive for something 10x bigger a disappointment was lurking about. If you have heard about a way to hack the firmware or to bypass the limit in another way, I'll be thankful for news!
Apr 5, 2007. 9:00 PMVelvetElvis says:
It's good that you brought that up. I have an 80 Gig Maxtor external, and was wondering about swapping in a big drive. Sent Maxtor tech support a note and was advised of the 137 Meg limitation you mentioned.
Jan 8, 2008. 5:36 PMPunkguyta says:
Is that Megabytes or Gigabytes?
Gig
Apr 3, 2007. 9:19 PMLasVegas says:
Also note that the new drive must be set into MASTER mode with the jumpers. The jumpers are usually between the power and IDE connector. Jumper positions are normally identified on the drives top label.
May 10, 2007. 11:50 PMinertia18 says:
I have an extra external USB- CDR/W casing with circuits complete, I just replace it with an HDD, but my computer can't detect it. Pls help. my external USB-CDR/W is a yamaha brand with external power supply. Badly needed help:)
May 14, 2007. 11:18 PMinertia18 says:
Thank you so much:)
May 1, 2007. 8:17 AMgemsuraj says:
Its really nice . Y not to make a portable HDD means that should be directly put in the CDROM cover which will be always connected to the system and whenever we required to attach a new external HDD we can directly slide it in the CDROM cover and that's done >> Isn't this might be cool .. Wondering right .... . . '
Apr 5, 2007. 11:06 PMkrazy says:
i once did this with a hdd that came from one of my mothers old computers but i totally forgot about needing a fan and overheated the damn thing. lol this is cool tho wonder how cool it would look to use like old college books for a shell. i have the My Book hdds i like the way they look on my desk but i bet a real book for a case would look even better
Apr 4, 2007. 1:04 AMmikesty says:
Good hack. I've never even thought about this. It just so happens I own a similar Iomega drive. Instead of creating an enclosure, I might just strip it down and turn it into a free IDE connect0r for data-yoinking. I doubt it will work. This one is kinda old, and I think it connects via the parallel port :-/
Apr 4, 2007. 11:16 AMLasVegas says:
I doubt if the IOmega enclosure will work. The parallel/SCSI port does not convert to IDE, but to an IOmega specific interface.
Apr 4, 2007. 12:38 AMlabeey says:
this doesnt always work. a few years ago i tried this. i had an old external cdrw and tried putting a HD in the enclosure.. guess what happened to the HD.. FRIED within a second...and it wasn't from overheating...
Apr 4, 2007. 11:13 AMLasVegas says:
The only reason this could harm a drive is if the ribbom cable is plugged in backward. Be sure the pin 1 (normally a red line on the edge of the cable) is to the left when facing the connector. You could also destroy a drive by using the wrong power adapter for the enclosure. Most cables and drives are keyed to prevent this with a notch on top of the connector.
Apr 4, 2007. 7:14 AMroyalestel says:
Hey, great job, and great idea!
Apr 3, 2007. 9:06 PMdavidbacsik says:
Nice work repurposing, and way to think about ventilation. I probably would have completely forgot about it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:username
