3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an Iron Man Arc Reactor
I didn't have a lot of time to make a great Halloween costume this year so I figured I'd do something relatively simple that was still eye catching and cool. I wanted my Arc Reactor to look pretty realistic, but not necessarily 100% movie accurate, so it's kind of a cross between a MkI and MkII version. There are some things I'd change on the next version (and I'll point them out) but overall I'm pretty pleased with it.
The reactor is attached to an old heart rate monitor strap and it's powered by a 3 volt battery pack that just slips in my jeans pocket. It's light weight and is comfortable to wear for several hours at a time. In the photos below you can see how bright it is- it easily shines through my t-shirt under normal office lighting conditions and is very bright at night.
Follow along and see how it's made.....
Update: see page six for the new style reactor!
Step 1Tools and materials
There are a few necessary tools:
soldering iron
dremel tool
drill bits
metal snips/shears
jeweler's saw (or some kind of saw to cut metal and plastic)
needle nose pliers
wire cutters
files/sandpaper
glue gun
And for materials:
thin brass sheet
plastic sheet ( I used Delrin- you can buy Delrin and acrylic sheet from Colorado Plastics)
clear acrylic sheet
copper wire- 22ga and 24ga thickness solid wire
sheet metal- 22ga thickness (.025in or about .5mm thickness)
PCB (printed circuit board)- at least 4" square (Radio Shack sells some that measures around 4.5" x 6")
several small bolts - I used 10ea 2.5mm bolts and 3ea 3mm bolts w/nuts
3 volt battery
11 ea NTE30027 surface mount LED's - I bought them from a local supplier but you can order them here: http://www.cablesandconnectors.com/30000-30.HTM
battery hook up wire
As an option for LEDs and making a circuit board you could use these instead-
http://www.sparkfun.com/commerce/product_info.php?products_id=8735
I'll make specific notes about the materials used and possible substitutes/workarounds on the specific construction pages.
Please note: be careful cutting sheet metal as the edges can be very sharp and it's pretty easy to cut yourself.
643 comments
1-40 of 643next »
May 21, 2012. 7:45 PMski bum says:
Hi Honus
I am having an extremely hard time cutting my PCB into a 4 inch circle. The PCB keeps on cracking and I can't even remotely get a clean cut. What do you recommend that I use to cut it?
Thank you.
May 22, 2012. 8:35 PMski bum says:
Ok cool thanks for the advice. I have been using a jig saw with a metal cutting blade on a scrolling feature. I'm assuming that it was to violent for the PCB to handle.
May 21, 2012. 9:35 AMFrasbo09 says:
Would it be possible for you to take a pictuer of all of the individual parts?
May 21, 2012. 9:36 AMFrasbo09 says:
May 21, 2012. 9:38 AMFrasbo09 says:
For model 1.
May 16, 2012. 5:49 PMbook man says:
do you have a template for all of the pieces so I can laser cut them out ?
Jan 23, 2012. 4:23 PMDareDevil147 says:
Iroman147 says: cool :)
Jan 17, 2012. 11:03 PMfugher says:
Hey I wanted to ask you have you been able to get a kit together for this cool project?
Jan 19, 2012. 8:59 PMfugher says:
Cool. Whats the price range on it?
Nov 21, 2011. 3:49 PMtech dawg says:
This is the Arc reactor I made.It took a while to make and I made it the day before halloween.
Nov 21, 2011. 3:56 PMtech dawg says:
Thanks!
Oct 19, 2011. 7:28 PMSethaulton says:
Hi, you have said that you are using sheet metal as you're primary material and that you have been welding them with an unspecified welder. i am not familiar with welding. and would like to know what kind of welder you used ( in the bill of materials and tools it was not listed)
Thanks, Seth
Oct 19, 2011. 7:43 PMSethaulton says:
Thank you very much, i was just wondering cause my neighbor has a garage full of welding equipment and i had no idea what kind of welder was used.
also may i suggest something for the outer ring ?
in my variation of the arc reactor i am building i am using a material for the outer light ring called light pipe
http://www.sparkfun.com/search/results?term=light+pipe&what=products
you may want to look into said products they are very applicable to projects like these!
Oct 19, 2011. 8:14 PMSethaulton says:
I'm inclined to use JB weld, but in my experience its always been messy and kind of a pain in the butt. ( i built electric racing cars in high school) that and the few things we used it on the welds never held up. How strong would the weld be in that case? also if i am so inclined to use JB weld. what kind of gauge sheet metal should i use?
and yeah light pipe is really neat. i just got a order in from sparkfun for my own arc reactor. i cant get over how good it looks ( i'm replacing your acrylic outer ring with two 6mm light pipes stacked on top of each other)
Oct 19, 2011. 8:47 PMSethaulton says:
Lighting it through the end, i'm drilling holes in the ends and inserting LED's to get maximum brightness. as well as saving plenty of space. i intend on hiding the ends of the light pipe under one of the copper windings.
and what do you mean by roughing up the areas?
Oct 17, 2011. 9:24 AMPrestond says:
I'm sure this has already been asked, so I hope I don't annoy any body by asking this.
How did you make the lens for the center light? I can't seem to find one anywhere to buy, and I'm not sure how I'd go about making one.
Any help would be awesome!
Oct 17, 2011. 7:20 PMPrestond says:
Stretching it over a wooden dowel, what a great idea! I'm gonna have to try that this weekend! Thank you very much!
Oct 15, 2011. 3:57 PMTTAMREKRAP says:
Could you give an estimate of how expensive this was? (sorry if you already did)
Oct 10, 2011. 10:06 AMUlyBoy83 says:
Awesome work!!! I'd like to try and make one. Can you send me in the guide please? uly_sixer@yahoo.com Thanks a bunch!!! =D
Sep 27, 2011. 8:46 PMkeys_smittyfreak says:
Honus- I'm also making one (very great design by the way), however I'm wanting a self-contained pack (as opposed to the strap with the battery pack) Mine will be an inch smaller in diameter than your 4" version, and am trying to figure out the battery wattage. I'm fairly ignorant but my dad is tech-savvy. We do have a way to do it with my design, but I don't want to use a AA battery due to size. I saw the post you have for the Lily Pad LED strips... what kind of battery do these take (or are they self powered with a small battery of their own?) I tried to find the answer on Spark Fun but had no luck and thought you may have a better insight? Thanks!
Sep 28, 2011. 4:27 AMkeys_smittyfreak says:
Thank you for getting back to me so quickly- one more quick question, where do you pick up batteries like this one? (I mean you personally) I hit Radio Shack a few days ago and they seemed a bit limited... thanks again!
Sep 25, 2011. 3:39 PMnrakoski says:
Hey Honus,
I sent you a message about your Arc Reactor.
thanks for your help,
Noah
Sep 22, 2011. 10:54 AMSpidey28 says:
Hey Honus,
I have researched and studied your tutorial for about a year now and I'm finally worked up the nerve to try it. = )
During my research I found tons of other reactors and yours is the best, not just by design, but in overall execution.
I'm sure I'll have more questions as I'm working, but my first is, what instrument did you use for your measurements. Was it a digital caliper? What would you recommend as a replacement tool?
Thanks for any input you can provide.
1-40 of 643next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
