3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an Iron Man Arc Reactor
Step 3Make the inner ring assembly
  • last photo ←
Now we have to make the inner ring. This is a clear ring that is held by a frame (which I call the lower spider frame.)
First cut the inner ring from clear acrylic sheet and rub it with a scotchbrite pad (steel wool would also work.)
Now comes the tedious part- there are 20 arms that need to be cut out, bent and then placed around a central ring to form the lower spider frame. The dimensions on this are not critical, but you have to constantly check the fit so that it will fit into your previously constructed backplate assembly. You also have to make sure that the clear ring will fit into the slots cut into the spider arms.
The distance from the outer edge to the opening of where the large notch is approximately .08 inches. The trick is that you will have to adjust the fit of this to your acrylic ring as well as the outer ring. You want the spider to essentially press fit snug into the outer ring. Then fit the acrylic ring to the spider. I can guarantee that you will probably have to do some trimming because the spider is so difficult/frustrating to make so that everything is aligned properly. I had to trim probably every opening to get everything to fit properly.
The easiest way to trim the opening in the spider is to use a small sanding disk with a Dremel tool to carefully trim the opening to fit the acrylic ring. The acrylic ring doesn't have to be  a perfect fit as it's held in place by the copper wire wrapped around it.
I cut both the central ring and spider arms from 22 ga sheet steel using sheet metal shears and a jeweler's saw. A dremel tool would also work and will come in handy cleaning up all the rough edges. The finished arms were then welded to the central ring. Then the center bottom ring was cut from steel sheet and welded to the spider frame assembly- note how it is positioned. I was short on time so I left out the additional slots. The bolt holes were threaded for 3mm bolts.
As a substitute for sheet steel you could make the parts from brass or copper sheet and then solder the arms to the central ring and then solder the central bottom ring to the spider frame assembly.The parts could also be made from thin plastic sheet as well and just glued together, but they wouldn't be as durable.
Now you have to make 10 little brass tab thingies. These sit on top of the clear ring after it has been placed into the spider frame assembly and then they are then wrapped with 22ga copper wire. Make sure when you wrap the wire it doesn't stick out too far outside the spider frame arms- make sure to check the fit with the backplate assembly- mine is just a light friction fit. The brass tab thingies should be about the same width as your clear ring and the four little tabs should just stick out over the edges of the spider arms. The last bit is to solder some short 24ga copper wires to the tabs.
69 comments
1-40 of 69next »
Oct 19, 2011. 7:28 PMSethaulton says:
Hi, you have said that you are using sheet metal as you're primary material and that you have been welding them with an unspecified welder. i am not familiar with welding. and would like to know what kind of welder you used ( in the bill of materials and tools it was not listed)
Thanks, Seth
Oct 19, 2011. 7:43 PMSethaulton says:
Thank you very much, i was just wondering cause my neighbor has a garage full of welding equipment and i had no idea what kind of welder was used.
also may i suggest something for the outer ring ?
in my variation of the arc reactor i am building i am using a material for the outer light ring called light pipe
http://www.sparkfun.com/search/results?term=light+pipe&what=products
you may want to look into said products they are very applicable to projects like these!
Oct 19, 2011. 8:14 PMSethaulton says:
I'm inclined to use JB weld, but in my experience its always been messy and kind of a pain in the butt. ( i built electric racing cars in high school) that and the few things we used it on the welds never held up. How strong would the weld be in that case? also if i am so inclined to use JB weld. what kind of gauge sheet metal should i use?
and yeah light pipe is really neat. i just got a order in from sparkfun for my own arc reactor. i cant get over how good it looks ( i'm replacing your acrylic outer ring with two 6mm light pipes stacked on top of each other)
Oct 19, 2011. 8:47 PMSethaulton says:
Lighting it through the end, i'm drilling holes in the ends and inserting LED's to get maximum brightness. as well as saving plenty of space. i intend on hiding the ends of the light pipe under one of the copper windings.
and what do you mean by roughing up the areas?
Oct 17, 2010. 2:53 PMxocdpxdrummerx says:
HONUS HELP ME!!!!! im a cmoplete novice at this. i bought all the matieral, and tools, and have several different people with backgrounds in this stuff to help solder, wire, etc.
Here's my issue, im following your digrams and sketching them out to make a stencil so i can cut the individual spider arms. the snag im running into, is that the measurements you gave, im following them exactly, but the entire length (1.16) seems to be short, and my spider arms seem to look stubby. where am i going wrong?
Oct 17, 2010. 4:11 PMxocdpxdrummerx says:
no, i havent even begun cutting yet, im drawing the designs on bigger paper, some of the numbers are REALLY hard to see on your diagrams. but for some reason, my sketch is coming out differently. i bought everything, and im already getting discouraged, lol
Oct 24, 2010. 10:30 PMmr08kitt says:
Honus is right don't get discouraged its not that hard, if the decimals are throwing you off just convert them to fractions and use a ruler to roughly find your measurements. I was in a hurry to make mine since i started a couple weeks before i started managing my Spirit Halloween store. it still turned out great! still getting offers from people to buy it lol. thanks again honus
Oct 17, 2010. 10:09 PMxocdpxdrummerx says:
hey btw, whens this kit coming out? and whats going to be in it? just all the pieces already precut with instructions on how to build it?
Oct 19, 2010. 11:07 PMdoodoo123 says:
what is the clear ring made of
Aug 24, 2010. 9:34 PMMrChipify says:
Hey honus, I herd you were making a kit. Is this true? Will it be out in time for Halloween? If so I'm totaly gunna buy one!
Aug 26, 2010. 11:52 AMdavest says:
I might be interested too...do you have a price range in mind?
Sep 29, 2010. 6:55 PMc_nic says:
dude that would be awesome. 150 is steep but itd save hours that i dont have due to work. keep me posted as well!
Aug 28, 2010. 8:55 AMerictank says:
Sounds quite promising - that'd save me a lot of work!
Aug 29, 2010. 10:00 PMMrChipify says:
Would I be able to order what's in the first pic on the last step?
Aug 25, 2010. 8:23 PMMrChipify says:
Sweet!!! Keep me posted cause I am so getting this kit!!! Hope u get it done in time!
Aug 1, 2010. 2:41 AMJason Amigo says:
Honus, I just received the acrylic that I will be using for the clear ring. It's really thin (about 2-3 mm thick) but it's the best I've got. How'd you cut something like that? I think using an electric saw would just shatter the whole thing, but other than that, I don't have any other tool that would cut the acrylic into a perfect circle. Would using an X-Acto knife work? Or would a coping saw work better? Jason
Aug 2, 2010. 6:50 AMJason Amigo says:
Alright, thanks. Looks like I'll need a steady hand for that. So I guess I'll need to leave a few mm allowance for the sanding. Just wondering how to cut the middle circle out...do you just bore a big hole, put the blade through, screw it on the saw and just saw it out, or do you do something else? Thanks again :D
Aug 3, 2010. 5:49 AMJason Amigo says:
Alright, looks like I'm on the right track. Thank you very much!
Jun 1, 2010. 6:29 AMRiMwE says:
i have a quastion.
Where can i get the plastic cycle thingie?  Or how to make one?
Hope you understood what i wanted to say (my keyboard isn't working properly)
Jun 2, 2010. 4:36 AMRiMwE says:
http://www.instructables.com/files/deriv/FVV/PRUC/G8TCT36A/FVVPRUCG8TCT36A.MEDIUM.jpg
this platic cycle thingie
Jul 9, 2010. 8:19 PMconrad0102 says:
Hey Honus, first off I would like to say great job and im beginning my own project off of your design so thankyou!. I ran a prototype but it was too small and so im making it into a belt buckle, but i was wondering how you cut the acrylic sheet. I have plexiglass so i figure it is close to the same process. im about to just start at it with a dremel tool but was wondering if you had any pointers.
Jul 10, 2010. 9:22 AMconrad0102 says:
thanks. your the best Honus. oh and for most everyone in america i got my plexiglass and sheet metal at the local home depot for under $30 and its enough to make a lot of reactors. =] happy reacting. "Honus built this in a cave!!! With a box of scraps!!" (iron man 1 direct quote)
Jun 2, 2010. 6:16 AMRiMwE says:
ugh thanks anyway :)
1-40 of 69next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
621
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
