loading
If you fancy a Star Wars rebel trooper blaster pistol, you have basically 2 commercial options. There is a blue plastic dart gun by Hasbro, or a great looking, solid but non-functional $400 model from Master Replicas. Neither of them shoot bolts of red light accross the room.
I wanted one that really "worked" and looked good, so I made my own. The project was more about learning electronics than anything else, but in addition to the new understanding of how to build blinky lights, I ended up with a pretty neat toy. I modeled mine after a Hero (that means it was used for close-ups) ROTJ Blaster prop that recently sold on ebay.
The blaster build consists of 2 sub-projects : building the electronic effects, and making the gun itself.
The circuitry is pretty basic and was my first real scratch-built electronic project. It involves a 555 IC timer circuit to trigger the sound and LED effects, and a 4017 decade counter chip to make the LED chaser effect seen at the rear of the gun.
The chassis of the blaster is made from PVC and aluminum tubing, some sheet aluminum a real scope and grip and a few other doodads.
Step 1: Electronic Effects Overview
When the trigger is pulled, the gun shoots out a pulse of bright red LED light out of the barrel, a pulse of laser from a laser diode, and a "blaster" sound is triggered. In addition, there is a line of 10 blue LED's that chase down the side of the gun creating some visual excitement.
In order to keep the effects synchronized and of a consistent duration, each trigger pull will set off a one-shot timer, which will trigger all of the effects for about 1/4 second, and then turn them off even if the trigger (switch) is held closed.
The Laser diode, Red LEDs (muzzle flash), and the sound effect module, and the blue LED chaser are all turned on by transistors that are triggered by the timer.
The LED chaser effect consists of another timer set up as a normal oscillator, which is driving a 4017 decade counter chip. The decade counter lights up each of the 10 LEDs in succession.
You can see the effects in action in this video:
Step 2: Build the 555 ic one-shot timer
The timer that controls the effects is based on the good old 555 timer chip. I used the low-power CMOS version.
You can adjust the amount of time that the timer stays on by varying the values of the resistor to pin 7, and the capacitor to pin 6.
Time (seconds) = 1.1 x R x C
It is a good idea to set up the circuit on a breadboard to get the bugs worked out prior to soldering. However, in my experience, things can behave differently once they are reassembled onto a circuit board. I had to adjust my component values a little bit once i built the circuit on perf board.
Image courtesy of Rob Paisley.
Step 3: Add some output transistors
Once i had the one-shot timer working, I rebuilt it on a piece of perf board.
I tried driving both the bright red muzzle flash LEDs and the Laser diode directly from the output pin of the 555 chip, but it didn't seem to work once I added the second effect, so I chained together 3 NPN switching transistors (with diodes to the trigger legs) to use as outputs for the effects. Using the transistors to turn on the effects individually gave much more stable results.
At this point you should set up the LED, laser, and sound module on a breadboard and test to see that they are being triggered properly.
Step 4: Build the LED chaser effect
I found this 10 LED chaser circuit on the web, and integrated into my design.
This circuit produces the sequentially flashing line of blue LEDs that shoot down the sides of the blaster when it is fired.
The circuit consists of another 555 chip, this time wired as a straight oscillator. The oscillator output drives the 4017 decade counter chip, which has 10 transistor outputs.
I wired up 2 arrays of 10 LEDs, one for each side of the gun, and hooked them to the appropriate pins on the 4017. I built the chaser effect on a second circuit board because I ran out of space on the first one.
I ran a jumper from the output of the first timer circuit to the LED chaser board where I had installed an NPN transistor to turn on the effect.
The chaser will cycle over and over while the signal is high, so I adjusted rate of the oscillator (variable resistor on pin 6-7 on the 555 chip) so that the chaser would do one full cycle during the time that the effect was in effect.
As you start wiring this stuff together, be sure to keep the final enclosure in mind, my gun was pretty jam-packed with wires when I was done. I could have planned a little better. It might have been worth doing a printed circuit board for this project.
Step 5: Prepare the LED's
The LED's that I used for the main emitter are ridiculously bright, and their narrow viewing angle and large 10mm package makes them project really far. I used 3 of them clustered together and focused at the same spot. In order to fit them into the barrel of my blaster, I had to grind down the cases and crowd them together a bit.
The 2 sets of 10 blue LEDs that make up the chaser effect, (which I call the pulse generator) have their anodes connected to a common ground via individual current limiting resistors. Pairs of the cathodes (left and right side effects) are wired to the output pins of the 4017 chip.
Now, as bright as the big red LED's are, I wanted to be able to shoot a visible blast of red onto a wall across a well lit room, so I added a laser. I ordered a laser diode that included a focusable collimating lens. The lens allows you to change the focus of the beam so that rather that shooting out a little pin point laser, you can adjust it to whatever size spot you want. I made it about 10 inches across at 30ft.
Step 6: Sound Effects
I purchased a Radio Shack recordable sound module to use for the blaster sound effect. I originally started to use a little child's toy sound recorder, but found that the memory was volatile, and the sound would be lost whenever power was cut to the module. The radio shack module uses non-volatile memory.
I cut off the microphone and wired the leads to the sound output jack of my computer. By pressing the record button on the module and the play button on the computer at the same time, I was able to load the sound onto the module.
Step 7: Build the Blaster
Of course, you could use these effects in any number of raygun projects, but I chose to build an LED Star Wars Rebel Trooper Blaster pistol because, well, "Hokey religions and ancient weapons are no match for a good blaster at your side, kid."
The Original Star Wars props were based on old Sterling sub-machine guns. Like the originals, my blaster is largely a model of a Sterling SMG with a few additions, such as the aluminum emitter and the scope.
Receiver/chassis
I built my Blaster from PVC, aluminum tubing, scrap aluminum bits, sheet aluminum, wood, and miscellaneous bits and doodads that I had lying around. If you choose to build a Star Wars blaster, there are templates available that will help you with the lalyout. I used the template linked to at the top of this page on the Blaster Builder's Club forum to make the reciever tube, trigger guard, and magazine housing.
Emitter
The emitter is aluminum tubing with aluminum trim. The cone tip is made from a wooden furniture leg from Home Depot. To aluminize the cone, I epoxied an aluminum skin to the outside.
Handle/Trigger
The handle is wood, and is glued and screwed in place. I made a trigger that hits a momentary switch when pulled, which trigggers the electronic effects. I installed a power switch in the handle as well.
The grip is from an actual Sterling SMG. There are resin copies of the grip out there, but I found that the real ones were cheaper, and they don't shatter when you drop them.
The sight is a cheap red dot gun sight that I bought n ebay. I made a mounting rail from aluminum.
I painted everything but the emitter with a few coats of semi-flat black. There are some neat prop metalizing paint tricks that you can do with the finish as well.
Step 8: Stuff the Blaster
Once you have wired up your electronics and built yourself a raygun, you need to install the electronics in the gun. I glued a thin strip of wood to each blue LED array to make them easier to install.
I put the 4 AAA battery pack in the magazine housing, and made a little cap for it that looks like the end of a magazine.
The Speaker that came with the Radio Shack Sound Module was a perfect fit inside the PVC endcap. I drilled sound holes in the end of the cap.
Once you get the circuitry in place, you can solder up the connections to the effects and stuff the remaining wiring where ever you can fit it.
Step 9: Blast Away!
If all went well, you can begin felling stormtroopers.
Here is a video of the blaster operating in a well lit room.
<p>I done this by using Arduino and 10 LEDs</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/jDdvyJ55Z2s" width="500"></iframe></p>
<p>I need one of thes for a friend mine. He loves Star Wars. How much does it cost overall</p>
<p>So, did you use just 4 AAA batteries = 6v supply or one 9v and 2 AA's with two seperate power supplies? Do the schematics reflect actual resistors and caps used on Your build? The directions show several so I am confused how it actually works. Please clarify. </p>
I've been staring at these pictures for a couple days trying to make sense of it, but I've got no experience with electronics and timers, so I'm probably going to have to avoid circuits entirely and stick to push-button activation. Pulling the trigger would push the switch that completes the circuit, and it would remain on for as long as the trigger is held.
can someone tell me how much this is or i will eat a cat
how much did it cost to make this ?
My husband fell in love with this as soon as he saw it! Wonderful work! <br> <br>Too bad neither of us have an electronic know how. Anyone willing to make 2 for us? I can do everything after step 7, just need the lights and sound.
This is a sick star wars gun. I wish I could make one. <br>
Hey, <br> <br>Nice cirquit, but i need 2 of these and one 5 led chaser, can this be powered by one or 2 USB Ports? <br>And if so, how do i do it?
wow it looks just like the original prop:D
cool project
Can I please have a parts list?
It would also be a nice idea to use the blue LEDs, instead of a chaser, to use them as a &quot;round counter&quot; to then just press a button to &quot;reset&quot; it. It's just something that came into mind while seeing how it works. Although it's really cool.
Thank you so much for the info on how you did your lighting effect -- I've been tinkering with a very similar idea (also tired of prop guns that make a wimpy sound and blink a single LED.) Nice to see the idea of combining a super-bright and a laser works so well. Can you share some info on the laser module and why you chose that particular one?<br><br>Oh, and there's enough on this page -- the assembly of the housing -- to warrant a full instructable on its own. You &quot;expoxied aluminum skin to the cone?&quot; Finding out more about how you did that, alone, would be worth the price of admission.<br><br>(I know...whine whine whine, more more more! :) )
how could i adjust this so that it worked like an republic blaster rifle?
cooool i want one
Very nice, but one thing I can't figure out is how you get the sound effect to play whenever you trigger it. I have the radio shack recordable module, but I can't figure out how to set it up so it will trigger when the power is switched on by the switch/trigger.
well, I honestly don't remember. But pin 3 is the output of the 555, so that should be wired to the base of the transistor. The collector is the positive, and the emitter is the negative side of the transistor, which you will wire up as the &quot;switch&quot; to activate the sound module. Sorry, I dont remember more specifics.<br><br>As far as making the sound play, mine just worked when triggered by the transistor. Maybe try removing the diode. Someone told me that I didnt realy need to use them. Although mine didn't work without them. And double-check the diode polarity.
Thanks to that help, I was able to get the 555timer chip circuit and the sound module to work perfectly. Again amazing job on the blaster.
the 555 one-shot triggers a transistor, which it wired to the &quot;play button&quot; on the sound module. pulling the trigger sets offf the 555 which turns on the transistors fro the various effects, one of which is the sound.
thank you for your reply, but how are the npn transistors (and the diodes) wired with the 555 one-shot? I'm having trouble looking at the images you have of the npn sequence to make out details on how it's wired. Is there a schematic you made?
About how much did it cost?
could you post a video of you using
Is there a way to create it without the sound?
Dont add the speaker... Remove it
how
Instead of using LEDs(light emitting diodes) Use a 5mW red Laser(light amplification by stimulating emission of radiation). It will go way farther<br />
If you look closely, you will see that I used both LED's and a laser.<br />
Pretty cool
wow great build 10/10! An other idea is if u used a 20-50mw green laser diode to see the actual laser beam <br />
Goodworkkeepitup.<br />
how
10 outta 10, good job dude, totally awesome.
&nbsp;I agree. totally awesome
Great project!!! I'd like to see about doing it myself, so I'm trying to lay out the entire circuit for all 3 functional blocks. I'm curious as to the final portion of the circuit, specifically the 3 chained NPNs. Can you post the outputs? Thanks.
I'm going to (well, at least try to) make the "clip" a battery pack with 2 contacts inside the gun so if "Luke" gets out of ammo (flat battery) he can reload, or just reload for the fun of it :)
does it actually shoot a laser ball sort of thing or is it a beam? that is really cool though.
iMac! W00t!!!
Very nice idea, well done, great clear instructable !
Awesome! I will try to make one!
EPIC!
Very nice!<br/><br/>I have a suggestion (I do not know the technical feasibility) you could put something that throws up a powder (flour, talcum powder) or smoke.<br/><br/>When it was launched the laser would appear as if the air like the films (because the light can only be seen when enter into contact with something). <br/><br/>What you think about it?<br/>=D<br/>
Awesome project! Congratulations on a well made blaster! What's up with the blue chaser though? Sometimes it seems to trigger much more chaotically than just the chase, then it's back to the regular dandy chase. Could it be if you trigger it again within the 1 second period?
Thanks, Yeah, I don't really know what's going on there. I think that the 4017 chip is really sensitive to "noise" or something. I couldn't solve it. Cheers, steve
Yupp, I have noticed it myself a few times. Have you found it to be related to multiple "shots" within a second, or does it happen if you wait a second or two between each shots? It would perhaps be an idea to bake it all onto one Arduino or PIC. :-)
No, its not multiple shots with a second, the thing is just skittish. Yes, this level of complexity would definitely be easier with a microcontroller. But the whole thing was an ongoing electronics learning experience for me.
And it worked out beautifully. Well done!!
AWESOME,question though: can u make it without the sound or without the chaser leds?
To answer Renagade, yes. The sound and chaser LEDS are an added effect for more fun and entertainment. If you don't have the parts, are to lazy to do it (like me), or feel those effects will cost to much on your budget, you can successfully build the gun with out the chaser LEDS and the sound, but you may need to take note of how to steer around those parts in the intractable without getting confused. If you wish to make the gun and use the chaser LEDS and sound, the parts are easily found at local electronic stores and online. Hope this helped! :)
what are all the parts for this instructable? (like i asked before) i want to get everything at once
About This Instructable
180,131views
438favorites
License:
Bio: I am a web designer and broad-spectrum tinkerer.
More by finkbuilt:Make an LED Blaster
Add instructable to:
