Make an LED Blaster by finkbuilt
Featured
If you fancy a Star Wars rebel trooper blaster pistol, you have basically 2 commercial options. There is a blue plastic dart gun by Hasbro, or a great looking, solid but non-functional $400 model from Master Replicas. Neither of them shoot bolts of red light accross the room.
I wanted one that really "worked" and looked good, so I made my own. The project was more about learning electronics than anything else, but in addition to the new understanding of how to build blinky lights, I ended up with a pretty neat toy. I modeled mine after a Hero (that means it was used for close-ups) ROTJ Blaster prop that recently sold on ebay.
The blaster build consists of 2 sub-projects : building the electronic effects, and making the gun itself.
The circuitry is pretty basic and was my first real scratch-built electronic project. It involves a 555 IC timer circuit to trigger the sound and LED effects, and a 4017 decade counter chip to make the LED chaser effect seen at the rear of the gun.
The chassis of the blaster is made from PVC and aluminum tubing, some sheet aluminum a real scope and grip and a few other doodads.
Step 1: Electronic Effects Overview
When the trigger is pulled, the gun shoots out a pulse of bright red LED light out of the barrel, a pulse of laser from a laser diode, and a "blaster" sound is triggered. In addition, there is a line of 10 blue LED's that chase down the side of the gun creating some visual excitement.
In order to keep the effects synchronized and of a consistent duration, each trigger pull will set off a one-shot timer, which will trigger all of the effects for about 1/4 second, and then turn them off even if the trigger (switch) is held closed.
The Laser diode, Red LEDs (muzzle flash), and the sound effect module, and the blue LED chaser are all turned on by transistors that are triggered by the timer.
The LED chaser effect consists of another timer set up as a normal oscillator, which is driving a 4017 decade counter chip. The decade counter lights up each of the 10 LEDs in succession.
You can see the effects in action in this video:
1-40 of 117Next »
KingRockyIV says: Mar 27, 2013. 4:19 PM
I've been staring at these pictures for a couple days trying to make sense of it, but I've got no experience with electronics and timers, so I'm probably going to have to avoid circuits entirely and stick to push-button activation. Pulling the trigger would push the switch that completes the circuit, and it would remain on for as long as the trigger is held.
tylerjj says: Jan 10, 2013. 4:43 AM
can someone tell me how much this is or i will eat a cat
tylerjj says: Dec 13, 2012. 4:30 AM
how much did it cost to make this ?
elvishpiper42 says: Aug 7, 2012. 2:13 PM
My husband fell in love with this as soon as he saw it! Wonderful work!
Too bad neither of us have an electronic know how. Anyone willing to make 2 for us? I can do everything after step 7, just need the lights and sound.
NERF ASSASSIN 1 says: Jul 10, 2012. 2:29 PM
This is a sick star wars gun. I wish I could make one.
joppe says: May 26, 2012. 1:38 AM
Hey,
Nice cirquit, but i need 2 of these and one 5 led chaser, can this be powered by one or 2 USB Ports?
And if so, how do i do it?
ljm12# says: Feb 11, 2012. 9:11 PM
wow it looks just like the original prop:D
markee2 says: Sep 14, 2011. 6:22 AM
cool project
builderkidj says: Apr 19, 2011. 5:46 PM
Can I please have a parts list?
kruiz-1 says: Mar 15, 2011. 6:42 AM
It would also be a nice idea to use the blue LEDs, instead of a chaser, to use them as a "round counter" to then just press a button to "reset" it. It's just something that came into mind while seeing how it works. Although it's really cool.
pjrpumpken says: Mar 12, 2011. 3:21 PM
It like laser quest(homemade)
nomuse says: Feb 2, 2011. 12:27 PM
Thank you so much for the info on how you did your lighting effect -- I've been tinkering with a very similar idea (also tired of prop guns that make a wimpy sound and blink a single LED.) Nice to see the idea of combining a super-bright and a laser works so well. Can you share some info on the laser module and why you chose that particular one?
Oh, and there's enough on this page -- the assembly of the housing -- to warrant a full instructable on its own. You "expoxied aluminum skin to the cone?" Finding out more about how you did that, alone, would be worth the price of admission.
(I know...whine whine whine, more more more! :) )
uberzombiebob says: Jan 24, 2011. 10:10 AM
how could i adjust this so that it worked like an republic blaster rifle?
330 says: Oct 6, 2010. 6:46 AM
cooool i want one
commissarpenguin says: Sep 25, 2010. 7:44 PM
Very nice, but one thing I can't figure out is how you get the sound effect to play whenever you trigger it. I have the radio shack recordable module, but I can't figure out how to set it up so it will trigger when the power is switched on by the switch/trigger.
finkbuilt (author) says: Sep 26, 2010. 10:13 AM
well, I honestly don't remember. But pin 3 is the output of the 555, so that should be wired to the base of the transistor. The collector is the positive, and the emitter is the negative side of the transistor, which you will wire up as the "switch" to activate the sound module. Sorry, I dont remember more specifics.
As far as making the sound play, mine just worked when triggered by the transistor. Maybe try removing the diode. Someone told me that I didnt realy need to use them. Although mine didn't work without them. And double-check the diode polarity.
commissarpenguin says: Oct 1, 2010. 10:08 PM
Thanks to that help, I was able to get the 555timer chip circuit and the sound module to work perfectly. Again amazing job on the blaster.
finkbuilt (author) says: Sep 25, 2010. 8:13 PM
the 555 one-shot triggers a transistor, which it wired to the "play button" on the sound module. pulling the trigger sets offf the 555 which turns on the transistors fro the various effects, one of which is the sound.
commissarpenguin says: Sep 26, 2010. 5:38 AM
thank you for your reply, but how are the npn transistors (and the diodes) wired with the 555 one-shot? I'm having trouble looking at the images you have of the npn sequence to make out details on how it's wired. Is there a schematic you made?
funnydan says: Sep 3, 2010. 4:55 PM
About how much did it cost?
seabananers says: Aug 11, 2010. 11:27 AM
could you post a video of you using
the commentor says: Apr 24, 2008. 4:13 PM
Is there a way to create it without the sound?
hyudryu says: Jun 17, 2010. 1:03 PM
Dont add the speaker... Remove it
zalen says: Feb 3, 2010. 2:29 PM
how
hyudryu says: Apr 5, 2010. 8:29 PM
Instead of using LEDs(light emitting diodes) Use a 5mW red Laser(light amplification by stimulating emission of radiation). It will go way farther
finkbuilt (author) says: Apr 6, 2010. 10:17 AM
If you look closely, you will see that I used both LED's and a laser.
Pretty cool
xerodesolate says: May 23, 2010. 7:29 PM
wow great build 10/10! An other idea is if u used a 20-50mw green laser diode to see the actual laser beam
Dipankar says: Feb 3, 2010. 4:38 PM
Goodworkkeepitup.
zalen says: Feb 3, 2010. 2:28 PM
how
russian_blackbird says: Aug 27, 2009. 3:33 AM
10 outta 10, good job dude, totally awesome.
CybergothiChe says: Oct 28, 2009. 3:53 AM
 I agree. totally awesome
marvin1969 says: Sep 6, 2009. 3:34 PM
Great project!!! I'd like to see about doing it myself, so I'm trying to lay out the entire circuit for all 3 functional blocks. I'm curious as to the final portion of the circuit, specifically the 3 chained NPNs. Can you post the outputs? Thanks.
tjeppen says: Jun 24, 2009. 3:38 PM
I'm going to (well, at least try to) make the "clip" a battery pack with 2 contacts inside the gun so if "Luke" gets out of ammo (flat battery) he can reload, or just reload for the fun of it :)
cgn397 says: May 20, 2009. 4:31 PM
does it actually shoot a laser ball sort of thing or is it a beam? that is really cool though.
snowpenguin says: May 6, 2009. 10:49 AM
iMac! W00t!!!
Geoffrito says: Feb 4, 2008. 1:52 PM
Where exactly does one find the 4017 decade counter chip? Thanks :) great instructable, too....very cool.
finkbuilt (author) says: Feb 4, 2008. 2:19 PM
Radio Shack catalog # 276-2417. But if you can find a local electronics parts supplier, or tack it onto an order from Digikey or the like, it will be cheaper.
Geoffrito says: Feb 4, 2008. 4:29 PM
None of my local radioshacks had it, oddly enough........ =\
thanks anyway
zoltzerino says: Apr 21, 2009. 10:41 AM
A great place for electronics stuff is Rapid Electronics (just google it). I'm not sure whether they are UK only though... ZZZZ
1-40 of 117Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
