loading
Step 2: Wire Up the Transformer
Okay, before we attach the wires to the transformer, you need to take a look at it first...
The two leads of the transformer that are connected to the mains power source, is the primary (the high voltage side), and the other two leads are the secondary (the low voltage side).
We are going to connect the transformer in reversed, I mean the primary (the high voltage side) of the transformer becomes "secondary" and the secondary (the low voltage side) becomes "primary".
So we are going to connect the battery on the primary (the low voltage side) of the transformer and we will get some sparks from the secondary (the high voltage side)!
Right, attach the wires to the transformer!
hi you using battery how DC will work with a transformer?<br>
<p>the spark gap creates an alternating current that can pass through the transformer</p>
Why not just use a 555 ic to switch the circuit connect that to a transformer and then use a simple cockcroft walton generator to step it up to hv dc this is a very simple circuit is is a lot more efficient than manually tapping it as you can accurately control the frequency all be it a bit more advanced.
<p>So I've been working on a 555 timer stun gun circuit for months now and with a 12 volt power source i've only been able to get about 700 V DC out of it. The 555 circuit is fine, my transformer is fine (about 280 Vp-p out the gate), the multiplier though is only outputting about 700 volts DC... In LT Spice I get 1.3 kV on the output I am doing this for my job and I would absolutely love to make this work... Any help is greatly appreciated.</p>
<p>My guess the resistance of the inductors, are working as a voltage divider, measure it using a multimeter, from your transforemer, and add it on the simulation, in series to the inductors, or right click on the inductor to modify the properties.</p>
<p>seems great!, the values you use for the inductors of the transformer, you choose it for the simulation, or actually are the values of your transformer?</p>
<p> It's not simpler since this only needs a transformer.</p><p> Bob Clark</p>
<p>I'm quite sure who made this instructables does not know about &quot;complex&quot; electronics.. And yeah 555 circuit would be way more effective.</p>
i like it <br>Thnx man <br>i finally found a way to automatically ignite my flame thrower *-*
<p>will it give continuous high voltage supply...</p>
<p>check this out ppl... look how does 3.5 MILLION VOLTS look like .... beautiful</p><p>https://www.youtube.com/watch?v=ngiZBaS4Ago</p>
So I have to repeatedly switch the current on and off, amirite?
Yep!
Could you wire a 555 circuit to switch it for you? I can see no reason why not. Does anyone else see a reason that you shouldn't do that?
<p>To keep it simple..</p>
It works, ive created inverters that way
I believe it will work. I'm trying that myself.
a 555 can only source 200 mA of power. is that a problem?
Just use a big MOSFET, like the IRF740 or so... <br>And, if you use a Powertransistor, dont forget to use a diode anti-parallel to your transformer. in case you dont, it could Kill your transistor!
yes especially when charging a capacitor bank. That is why is use zvs driver
Would a Pulse Width Modulator &quot;PWM&quot; work in place of the switch? Just curious.
<p>use he pwm signal to drive a transistor to pulse the battery</p>
Square wave generator is better, use a irf620 and a astable 200 hertz 555 circuit
It will be more easy if we use ardunio for switching
<p>how much volts will it make?</p>
So im guessing that this is similar to the ignition on a gas cooker that only uses 1AA battery? ?
i just looked up direct current and transformers and according to the internet, you cannot use a battery of any kind it has to be alternating current, check this website <a rel="nofollow" href="http://wiki.answers.com/Q/Can_you_use_dc_current_in_a_transformer">http://wiki.answers.com/Q/Can_you_use_dc_current_in_a_transformer</a><br/>
according to the internet......<br /> <br /> really? <br /> <br /> comment directly above you explains it <br /> <br /> i'll post it again for you...<br /> <br /> &quot;redhawk44:<br /> Yes transformers use collapsing electrical fields and so AC input is required. However AC input can be simulated by rapidly switching DC voltage on and off to produce the required rising and falling field to induce high voltage in the secondary coil. This can be achieved mechanically in several ways and is how the high voltage for the early experiments with Giessler and Crookes tubes was produced, leading eventually to the discovery of X-Rays. google Ruhmkorff coil for more info. &quot;<br />
&nbsp;this project does not use pulsed direct current voltage therefore how can it work?&nbsp;
*sigh, you create the square wave by tapping wires together fast, NOT taping, TAPPING
the instance you connect dc to a circuit it is pulsed dc it goes from no current to having current <br /> <br /> we have been suggesting to use a timer which would repeatedly turn the current off and on creating pulsed DC or simulated AC instead of doing it manually by connecting and disconnecting a wire or pressing a switch over and over again <br />
You aint using a dc constant source, by tapping wire to wire fast enough you create square waves, which can run a transformer
transformers are met to work with ac or pused dc currents does this really work?
Yes, the input is a square wave pulse
by tapping the switch you are creating pulsed dc
Wait, I don't understand. The mains transformer takes around 120 Volts and converts it to the 5-12 Volt range. Even if the transformer is used in reverse, how will it generate a few kilovolts?
Google &quot;flyback effect&quot;, youll fugure it out
its the ratio of turns that alters how the voltage will be changed, double the turns on the secondary coild and the voltage doubles on the secondary coil, this can work in reverse
At first, this guide confused me. <br><br>Mains transformers take 110 or 220 volts (depending on where you live) and convert it to around 10 volts. If you reverse the transformer, inputting 9 volts, you should get the same amount as your mains supply. This would mean that the output is not in the several kilovolts range, but actually much lower. But then how would the relatively long sparks be generated?<br><br>I think, now, that this works through inductive kickback. When the 9V supply to an inductor (the transformer's primary) is interrupted, a much higher voltage is generated. This would then be induced in the secondary, producing the static-like spark. I don't think this works with a perfect sine wave, only a square or sawtooth wave.
Only a square wave, its the flyback effect, good job figuring that out on your own
is this dangerous? i.e should i not touch the high voltage wires?
It shouldnt kill you,(shouldnt!), but it hurts
since increase in voltage means decrease in amperage (right?) and amperage is the biggest danger to humans with electricity, Can this be used to shock people?
Please dont, i was once working on a high voltage power line and was shocked so badly that i lost consciosness for three days, so i know how it feels, im not saying that will happen with this thing, but please be considerate of hurting others, epecially with electricity, as it can kill people with pacemakers or heart problems, skin effect or not
try this on get mechanical relay with a normally closed contact . <br>take the + from the battery go to the relay coil&gt;&gt; out of the relay coil to the transformer&gt;&gt; from the transformer to one side of the normally closed contact. <br> Then take the - battery to the other side of the normally closed contact. it will buzz the relay sending pulsed dc to the transformer stepping it up and giving you a higher frequency spark.
<p>Can U Tell Me How Can I Get Continuous Supply From The Transformer ? By Using A 9v Battery </p>
You need a pulse circuit, look up &quot;555 timer high voltage generator&quot;
<p>This won't work. DC does not transform in this way. At most you might get a very brief spark when you disconnect the battery from the EMF collapsing in the opposite polarity.</p>
Thats the point, this is for noobs who dont know enough about electricity to know positive from negative, people like me and you who know this shouldnt be on this page
<p>dc to ac is not possible without a capacitor and diode . isn't it ?</p>
About This Instructable
389,759views
243favorites
License:
Bio: &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash; &quot;Energy cannot be created nor destroyed!&quot; &ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;&ndash;
More by Plasmana:How To Build A Simple But Powerful Flyback Driver ZVS Flyback Driver - Video Close ups on electronics
Add instructable to:
