My modification was done on a cheap acoustic guitar, the modifications consisted of converting it to a "Fat Strat" config.
I suggest you DO NOT do it to a pricey acoustic guitar or any acoustic guitar that you REALLY LOVE and just want to keep that acoustic guitar on it's way. If you want to do this, better buy an acoustic guitar that is cheap.
Pros: You get to Electrify your acoustic.
Cons: Sacrifice much of it"s Tone
Remove these ads by
Signing UpStep 1Pick-up routing
Some extra wood
plywood
industrial glue
saw
cutter
others:
pick-ups
wires
guitar switch(it is up to you what switch you need)
First of all you need to route the areas where you need to place your pick-ups.
Nice "structible! Your guitar looks like it was designed to be modified to begin with. You did a good job. A tip: You said you couldn't locate suitable material to make the pick guard area with. Have you considered counter tops? Construction crews regularly throw out the cut-out area for the sink. Soak the piece for about a week in water, and the chipboard base will have disintegrated. Then just scrape off the remainder and sand off the backside of the laminate remaining for a nice piece of plastic finger guard! There are many different colors and patterns to choose from, too.
