3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an airport in Google Earth and fly around
After discovering there is a hidden flight simulator in Google Earth, part of a beta test for some future online game, it was only a matter of time ( two days) before I thought about hacking the simulator on a minor scale. After doing some NOE flying and after many attempts at landing, I decided I wanted to fly around more familiar places.
This instructable will show you how you can make a new airport anywhere and takeoff from the new location. After I wrote this instructable, I decided to select the option "Current location" from the Start location in the settings panel, it kind of makes this instructable useless to anyone other than those interested in practicing takeoffs and landings in their home town.
You can also place a plane anywhere you want by going to the location first and press and select "Current Location" as your start point. Be sure to rotate the view before you start the simulator or give yourself altitude or your plane heading straight down, if you were zoomed too close to the ground you may not have enough altitude to pull out of the stall.
If you enter the simulator with your altitude higher than 31,500 feet or so, the plane will be in a stall, until it reaches an altitude low enough to support flight, but dropping into the atmosphere from such a high altitude is pretty cool, you can lift the nose up to see the curved horizon. The highest elevation that you can start at seems to be around 69,300.
One thing this instructable might do is to open the idea to others that we can control things we use in our lives, things that surround us, and this idea may spawn ideas in others and an understanding of the way things can be explored.
Step 1The Simulator
The Simulator
Discovery of the flight simulator, a not so hidden feature in Google Earth, as I was reviewing past stories in Makezine; vectored my behavior for a while. I found the instructable today written by Jare-Bear back , not really hidden yet has been hidden to this someone who has not explored all the programs options.
To get to the flight simulator, launch Google Earth and after the initialization press <Ctrl-alt-a>. An options window will open, where you can choose one of two aircraft and a starting location. The motion and the great realistic landscape makes this a fun simulator worth hours of squandered time.
The two choices of aircraft, being a jet fighter the F16 much faster than the SR22, takeoff speeds are understandibly different as well; so for a beginner, I would suggest the SR22 till you get the hang of the simulator. Unless of course you are like me and want to learn using the fastest.
You can put the plane anywhere on the globe by first going to the location then selecting the option of the start position to "Current View"
I have used the simulator for a short time and have been very good at limiting the wasted time... I think what day is it? I have however squandered a bit of time writing this Instructable, a choice made willingly.
For a list of keystrokes for flying in the simulator press <Ctrl-h>.
The flight simulator has a list of airports which you can fly out of, some of these are too far away from the areas I wanted to explore, trimming the plane and watching it periodically was not the way to enjoy the experience. Of course all before I realized my error of missing the radio button that solved that problem.
24 comments
Feb 12, 2009. 12:18 PMrandofo says:
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
Jan 25, 2012. 1:27 PMouuo says:
This isn't hacking... this is changing settings(.ini=setup file) just to let you know...=)
Jan 28, 2012. 2:06 AMouuo says:
Haha! Nice post overall. Seen many people making posts like "hidden air simulator in google earth" and stuff but this is something fun to do with it. Never thought of this before(been into real hacking) but now i might try it out.=))
Oct 13, 2009. 3:57 PMjoelr97 says:
i love google earth flight simulater but i can really land the f16 plus i play on a lap top that is good and bad i guess but i cant play in the car i get to dizzy then i get sick
joelr97
Jul 23, 2009. 7:15 PMiLikeCoolStuf says:
sacromento???
Aug 2, 2009. 10:09 PMiLikeCoolStuf says:
Aug 3, 2009. 9:23 PMiLikeCoolStuf says:
Ok ...?
Jul 23, 2009. 3:35 PMValos_Cor says:
Hi, I skimmed your Instructable and Saw at step 3 that you must be using Windows. I am using Linux and I keep seeing authors assume that readers assume that the authors are using Windows. That is just kind of annoying. Could you find some way translate the steps in to Linux? (say, Fedora 11?) Thanks. It looks like you have a good technique!
Feb 21, 2009. 5:20 PMCapt. Fat says:
Is the good version of google earth ree to download?
Jul 23, 2009. 3:41 PMValos_Cor says:
Hi, Yes (you can look around the plane with the "Ctrl" key and the arrow keys). I also found that you can use "Alt" and the arrow keys to move around slowly. I use it to see the compass because my laptop's monitor is slightly too small and I have to "look around" for the compass.
Feb 22, 2009. 6:11 AMCapt. Fat says:
thanks. ill download it once i get a bigger hard drive
Jul 19, 2009. 6:33 PMalphaglider says:
can you hack the plane to see it
May 31, 2009. 1:16 PMDon,t try this at home says:
how do you hit the afterburners
May 31, 2009. 1:13 PMDon,t try this at home says:
in the simulator if you have 5.0 you can go to the middle of the ocean you can dive down a few thousand feet
May 18, 2009. 8:41 AMNotbob says:
interesting, but where is the giant earwig?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Gravity Boy
