Make an all purpose organic pesticide from vegetables by iPodGuy
Featured
This instructable will show how I made a cheap, all-purpose organic pesticide for my herb & vegetable garden. It can be used on a variety of insects that live in the dirt or on the plants including worms, mites and other parasites.
This entire pesticide will eventually break down and be reduced to nothing, so it is OK to eat any herbs or vegetables that are growing. This is mainly intended for indoor use, but I see no reason why it wouldn't work outdoors as well.
Step 1: Materials
The materials used to make the pesticide should be easy to obtain.
You will need:
  • an empty & clean gallon jug (such as a milk jug)
  • a spray bottle with spray nozzle
  • a funnel
  • a piece of cloth such as a shirt or bandanna
  • a pot that can hold 1 gallon
  • 2 small onions
  • a jalapeño pepper
  • a clove of garlic
  • some dish soap
Take 1 gallon of warm water, dump it in a pot and you're ready to begin making the pesticide.
Step 2: Killer Salad
Take the vegetables and begin cutting them up. It doesn't have to be pretty, since nobody's going to eat it!
Chop up the 2 onions, the garlic and half or 3/4 of the jalapeño pepper. The seeds can be left in, since they're hot too.
Blend all the veggies together until pasty in a blender. The killer salad is now a killer paste.
***Take care not to rub your eyes or face after handling the liquid or the vegetables. The pepper especially can really burn if it gets in the eye!***
Step 3: Making the killer soup
After everything has been blended, dump the paste into the pot of warm water and let it sit for 20 minutes.
The ground up vegetables and water will make the killer soup or tea. It's going to be mighty fragrant at this point. Just let all those offensive tastes and odors seep out into the water.
Step 4: Straining out the veggies
Once the soup has been allowed to sit and a lot of the flavor and odor has mixed with the water, the liquid needs to be strained.
I used a funnel and bandanna to catch the vegetable particles as I strained the liquid into the gallon jug.
I tried using a coffee filter at first to strain the liquid, but it clogged easily. Cloth seems to work best.
The mush that collects in the cloth can be squeezed out into the jug and the leftover can simply be thrown out or put into a compost bin.
Step 5: Add some dish soap
After all the straining is complete, I added 2 tablespoons of dish soap to the liquid.
Keeping with the spirit of this being an organic, plant-friendly pesticide, I used a vegetable-based dish soap. It is free of petroleum-based chemicals, dyes and perfumes and biodegrades naturally.
If you are using a soap that is petroleum-based or has dyes or perfumes, try adding half of what I used.
The soap makes the already bad-tasting, stinky liquid soapy and even less palatable to the insects that inhabit the plants.
Step 6: Using the pesticide
Using the funnel, fill the spray bottle up and set the nozzle to a light mist.
At this point, the rest of the liquid can be capped and stored in the refrigerator for up to 2 weeks. Simply shake it up before it is used.
Take the spray bottle and spray the plants first. Try to get all over the plant including the stem and under the leaves. Spray the soil as well so that the top of it is wet.
What this liquid does is make every part of the plant that it touches unpalatable to the insect. The water evaporates and leaves behind the odor and flavor. It smells and tastes gross and they won't eat it. When they won't eat anymore, they eventually starve. The liquid will not kill the insects on contact, so do not get upset if you see increased activity after the application. They're simply struggling to find something to eat.
Treat every 4 or 5 days to kill off the pests and prevent newly-hatched babies from feeding. It may take 3 or 4 treatments, but the numbers should gradually decrease.
1-40 of 96Next »
armetisius says: Mar 3, 2013. 11:54 PM
It is only a small amount of soap in the total solution anyway; however, for those concerned about it here is a viable solution. Since the soap really only acts as a sticking agent in this formulation why not substitute fish oil for use outside. The odor would be strong so not for indoor use but a standard fish oil from the farm dept. would not only achieve the sticking quality but also provide nutrients to the plants as it breaks down.
CosmicGM says: Nov 10, 2012. 2:28 PM
I need something that will get rid of fungus mites,their larval form lives in the soil of potted plants and attack the roots and all my houseplants are infested with the liitle jerks.I've heard Neem Oil is good but I haven't been able to find it anywhere.
jeff-o says: Aug 18, 2009. 6:23 AM
Can you use something hotter than jalapeno? They're pretty mild IMO. ;)
iPodGuy (author) says: Sep 3, 2009. 2:36 PM
I'd bet that you could go as hot as you could get. I ate a tiny little pepper off some unknown pepper bush and it was easily the hottest I ever had. No rabbit on earth would like that.
kitsuken says: Sep 5, 2009. 4:36 AM
Usually the smaller it is, the hotter it is. The problem here is that smaller chillis would have a smaller proportion per litre in the mix. Might be better to go with increased quantity of the standard chillis than to go with the same number of chillis, but hotter (unless you can find some ultra hot ones that are the same size as regular ones)
thepelton says: Feb 16, 2010. 4:40 PM
The strongest, as far as I know, is the Habanero or Scotch Bonnet.  It's orange, and about two inches across when ripe.  I have seen it in the local supermarket.
xrobwx says: Aug 15, 2012. 7:47 AM
The Trinidad Moruga Scorpion is the current hottest in the world. The #2 is the Bhut Jolokia. These are dangerous peppers.
tztmama says: Aug 14, 2012. 11:01 AM
My garden is not that big. Could I freeze half of the spray and use it later? I just dont think I will use it all within two weeks.....
CountryAngel says: Jun 9, 2012. 11:00 PM
Why is everyone freaking out about the soap? They still make 99 1/4% pure Ivory soap. A few drops of that will suffice.
Ijsbeer says: Mar 26, 2012. 7:09 AM
Does it smell particularly strongly? My bedroom is full of plants, and I've just found aphids on one (quite surprising how long it took, this is the first time I've found them in here after years of having the room full of plants), and obviously I want to prevent a mass aphid takeover - though for obvious reasons, I don't want my bedroom smelling like any of the ingredients.
And how is there all this mention of replacing the original soap, but no-one's suggested making it themselves? ;) I'm pretty sure there are multiple instructables on the subject.
Anyway, thanks for posting this.
losregni says: Mar 17, 2012. 5:34 AM
I believe the soap may be used as a "sticker" which helps the mix stick to the leaves longer. We use sticker on the farm when we are spraying pastures.
cjb84 says: Dec 11, 2010. 11:39 AM
im not sure you should be calling this "organic". Last i checked there are some pretty nasty chemicals in dish soap that arent organic. Otherwise it sounds like a great idea. i will try it without the soap.
becca_katisonly1 says: Mar 9, 2012. 3:30 PM
same here --w/o soap first
winterwindarts says: Sep 4, 2011. 6:44 PM
Try castile soap such as Dr Bronner's. It's pure vegetable oil and sodium hydroxide (plus water for the liquid version). True soap is some sort of oil/fat mixed with sodium hydroxide/lye and allowed to react. I love using it and the lavender version with the essential oil works as a mild natural antibiotic that should be safe even for gray water systems. It's highly concentrated and a small bottle lasted me more than a year even with my husband doing dishes.
jtalbot522 says: Apr 7, 2011. 7:47 PM
There are organic dish soaps like the brand Method. It's honestly better than other soaps
aaronscottaugustinhotmail.com says: Feb 24, 2011. 5:39 PM
actually seventh generation is dish soap made with all organic ingredients. Its supposed to be eco friendly. we use it our house hold because of the septic tank
alee52 says: Oct 18, 2011. 5:59 PM
The dill in my garden went wild, grew about two foot tall. I let it go to seed so it would re- seed the herb patch and notice it is covered in lady beetles, yellow ones! Hope they gobble the aphids big time. Will let u know if the organic spray saves my cauliflowers which are being decimated by cabbage moths.
actually they say having lady bugs in your garden -- food or flower -- is actually good for them like having earth worms in your soil is good for your plants growing in said soil
jjone538 says: Jan 23, 2012. 1:21 AM
Garden Moths Are Pretty Annoying
becca_katisonly1 says: Mar 9, 2012. 3:29 PM
very cool we will have to try it. do you think it would work on regular flowers and 'green' plants?
jwitkowski1 says: Jan 18, 2012. 2:41 PM
I would like to suggest an alternative to dish soap. The Shaklee Corporation makes a product called basic H. Farmers have been using it for decades in their soil. It makes the soil more absorbent. As a pesticide it actually kills them by penetrating their bodies and drowning them. I use it to clean my vegetables. It is an awesome product. You can order it from Shaklee at http://naturewise1.myshaklee.com/us/en/
jakoby says: Oct 4, 2011. 10:01 PM
I'd be careful when spraying something containing dish soap on your plants. Dish soap can remove the waxy plant cuticle that covers leaves and the like, making plants more vulnerable to viruses, fungi, and other nasties that you don't want. In fact, that's the main idea behind the organic herbicides that use vinegar; the soap removes the cuticle allowing for better absorption of the vinegar, which kills the plant.
TimmyMiller says: Jun 30, 2011. 8:52 PM
is it safe to use on grapes?
iPodGuy (author) says: Jul 1, 2011. 1:06 PM
Should be ok
winterwindarts says: Sep 4, 2011. 6:37 PM
You might want to rinse the grapes before eating, especially if you spray them shortly before harvest....I learned the hard way that the tiniest residue of hot pepper can be painful....but I'm also very sensitive to capcasin (spelling?) and can't even allow hot peppers in the house, sweet peppers are hot enough for me to deal with.
videoman22 says: Jul 10, 2011. 9:02 AM
Will this work to kill beetles? I grow pumpkins and tomatoes along with variouse other veggies,herbs,vining plants, tropical plants, succulents and cacti. Just curiouse if i could use it on everything.
winterwindarts says: Sep 4, 2011. 6:33 PM
Technically, this counts as a repellent rather than a pesticide-alluims (garlic/onions) and peppers won't actually kill much of anything but will certainly chase them away and not come back (the soap can kill some types of tiny insects but not very effectively). You might want to look into using pyretheum (my spelling might be off) aka "painted daisy" flowers in the mix which will kill insects yet break down within hours but you have to make sure to use it only in the evening when the good bugs such as bees are asleep or you'll kill them too. The amounts to be used vary and I don't remember them off the top of my head...my plants haven't blossomed this year for some reason and it's my first year trying to grow them myself so I haven't made any from scratch yet. It's an insect neurotoxin and can be poisonous to humans when fresh or in solution but once sprayed on plants in the evening it breaks down so fast that by morning the veggies/fruit are usually considered safe to eat.
solive says: Jul 25, 2011. 3:42 PM
Besides as a pest repellent, essential oils play important role as a attractant for several pests. You can find the complete article here at Indonesia Essential Oils:
http://indonesia-essential-oils.blogspot.com/
smileygirl12 says: Jun 25, 2011. 2:38 PM
I can't wait to use this!Because of were I live bugs just love to eat up my plants and i am about to plant some tomatoes so I needed something that would keep the bugs away thanks iPodGuy!
moxiepurple says: Apr 18, 2011. 11:16 AM
Thanks! I just saw some ants manking their way into my pantry today, and needed a way to kill them and not ruin the food. I am also going to try this out on our garden, luckily we don't have many pests eating things up out there. (I like your silverware too, I got a set from Ebay, we had them when I was a kid too.)
judema says: Apr 8, 2011. 1:25 AM
tobacco can give tomatoes tobacco mosaic disease, if you smoke you should wash your hands before handling tomatoes. try adding black pepper to your mix.
metta77 says: Feb 13, 2011. 1:32 AM
I've been experimenting in my garden with a similar "soup" for the past 3 months.I used fresh garlic cloves insted of onions and added canola cooking oil,which also acts as a fungicide.Insted of using a detergent,I used a pure,fragrance free glycerine soap( just a few shavings).Keep up the good work saving the enviroment.
jtalbot522 says: Apr 7, 2011. 7:49 PM
Very intuitive! I think I'll do this instead
MTummino says: Mar 22, 2011. 8:01 AM
Once this is strained to a pure liquid form it can be applied by a garden sprayer such as those found at www.sprayerusa.com
just make sure that it it strained really well so there are no chunks to clog the sprayer.
de Oliveira says: Oct 27, 2010. 7:54 PM
Hi iPodGuy! You may use milk too! Ratio 10:1 - water:milk.
Or you may use strong tobacco on alcool 70%.
Mix with water to do not kill the plants and spray over.
Using tobacco, wash what you'll eat.
burnergirl says: Apr 21, 2008. 2:12 PM
I've been looking for a way to banish all the wee mite-like flying pests that have managed to set up house in just about every plant I have inside (which is approaching a small greenhouse, now - a mix of succulents, cactus and tropical). This seems a lot more effective than just using the soapy water my mother used to use. I'm hoping this will do the trick!
Dr. dB says: Sep 13, 2010. 5:27 PM
Plus, your entire place will smell either offensive or delicious!
ventifact says: Sep 12, 2010. 10:47 AM
You should label the containers.
Browncoat says: Aug 26, 2010. 8:51 PM
I wonder how long you could freeze this for longer storage & still have it be effective...
iPodGuy (author) says: Aug 27, 2010. 5:42 AM
I bet quite a while. It's basically salsa, you know?
1-40 of 96Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
