3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an articulating wall mount hold your TV perfectly level
I will show you how to make a relatively easy 'add-on' to your articulating wall mount to level your TV perfectly. I bought a fancy articulating wall mount for my 26" flat panel LCD TV and was disappointed to find out that after all the careful steps taken to make the mount perfectly level on the wall, that the arms have enough play with the weight of the TV that the more I swing the TV off-center, the more crooked it hangs. I have a solution for that. This instructable is suitable for smaller TVs not exceeding 40 lbs in weight. For larger TVs, please make appropriate modifications to materials used.
Level of difficulty is Medium.
Cost (not including TV and articulating wall mount) is Low (under $10).
Note: Have a helper when removing your TV or hanging it on the wall.
Parts I used (your list may vary depending on mount):
(1) flat panel TV with standard 75mm x 75mm or 100mm x 100mm VESA mounting pattern
(1) articulating wall mount with 75mm x 75mm or 100mm x 100mm VESA mounting pattern
(2) 4-3/4" square x 1/16" thick steel plates
(1) 9/16" x 1-1/2" long bolt (9/16" hex head, 3/8" shaft, 16 threads per inch)
(3) 9/16" x 16 nuts
(7) 3/8" flat washers
(2) 7/16" x 1-1/2" long bolts (7/16" hex head, 1/4" shaft, 16 threads per inch)
(2) 7/16" x 16 nuts
(20) 1/4" flat washers
(2) 1/4" wing nuts
(4) #8 x 1/2" long philips head machine screws
(4) 1/4" x 18 nylon thread lock nuts
Tools I used:
safety glasses (recommended)
cordless drill
3/8" drill bit
1/4" drill bit
file to smooth out snags from drilling
Rotary tool with cut-off wheels
hammer and punch to mark drill points (keeps drill bit from walking before starting into material)
workbench (recommended)
clamps for holding parts while drilling (recommended)
Step 1Drill corner and center holes in steel plates
I stacked both steel plates together and laid my bracket mount on the steel plates to mark the hole locations where the bracket is intended to mount directly to the back of my TV. I marked the center on both steel plates to drill out the rotating point of my home-made adapter. Both of my steel plates needed all 5 of these holes drilled in the same places.
Note: The steel plates I used were electrical box covers that already had one corner slot and one key-hole. Don't do like I did! Move your bracket more than 1/4" away from any existing holes in the steel plate in order to not compromise its strength. After making my mistake, I decided to place the hole I drilled that's too close to the key-hole at the bottom of the finished product so it won't have weight trying to pull on it. Hind-sight shows me I should have used the existing key-hole or moved my holes farther away from the existing key-hole.
2 comments
Apr 6, 2010. 9:30 PMdigital notes says:
Making your mount hold the tv perfectly level is often something overlooked by the DIY crowd. I couldn't tell you how many times i've been to someones place and the first thing that strikes you is the fact that the screen is not level. But then often the picture frames were the same . Anyway great article
www.articulatingwallmount.info
Jan 15, 2010. 7:19 PMgixxerjosh says:
Those plates are actually 4-11/16" ...es.....for electrical boxes ;) I'm just a dumb electrician!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:destructor gadget
I am an internal system support specialist for a telecommunications company in the US. I have written programs and scripts to assist my customers over the years, ranging from small scripts for individ...
more »
