3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an awesome Harry Potter wand from a sheet of paper and glue gun glue
Step 7Spray with base coat
spray with base coat
Apply a base coat to the wand to seal it, either you can use spray paint (more or less any colour will do and spray paint is good because it drys hard, but you can use household emulsion instead if you haven't got any spray. (In the US, emulsion paint is called Latex Paint). If you use emulsion (latex) make sure that the wand is dry before going to the next step.
19 comments
Aug 7, 2011. 7:22 PMhtonks says:
Will modge podge work?
Mar 14, 2012. 10:10 AMAshlynWeasley says:
I used mod podge for mine and it came out well
Mar 14, 2012. 9:56 AMAshlynWeasley says:
I used mod podge and it worked perfectly for me.
Feb 28, 2012. 3:55 PMsilverstorm says:
green spray paint would work right?
Oct 30, 2011. 6:58 AMvrousseau2 says:
Do you have to do a base coat?
Mar 9, 2011. 6:38 PMI am Lord Voldemort says:
I didn't have a good base coat so I used white glue and painted it on!!! It worked reeeeally well :)
Aug 7, 2011. 7:23 PMhtonks says:
Do you paint it then put a base coat on?
Mar 23, 2011. 4:15 PMsupertoria12 says:
will acrylic work?
Jul 30, 2011. 3:52 PMsbates3 says:
Acrylic works fine actually. I have used Acrylic for both my base and my main coats of paintand they've both gone over the glue perfectly and evenly. I used Gouache for my distressing coat & that worked great over the acrylic. I strongly advise my method :)
Apr 26, 2011. 9:01 PMJujubeanO says:
Yes but it does NOT stick well to the glue so you will have to texture it first
(just take a nail file of bit of sand paper and go over it until it's a bit rough then you can paint)
Jul 25, 2011. 1:44 AMjanpogi09 says:
can i yse textile paint?????
Oct 7, 2010. 6:09 PMrumbleroar98 says:
I have a clear waterproof krylon spray... would that work?
Mar 9, 2011. 6:39 PMI am Lord Voldemort says:
oops.... i meant IS
YOUR NAME ID EPIC!!!!!!!
Dec 19, 2009. 11:45 PMninjadino79 says:
um, where do i find emusion paint? can is there anything else i could use OTHER than spray and emusion?
Sep 25, 2009. 5:21 PMjanpogi09 says:
what colour should i use
Sep 12, 2009. 12:56 AMthehongkid says:
does it really dry hard??? also what colour spray paint should i use for a white wand?
Aug 2, 2009. 10:59 AMD_J_T says:
Is there anything other than spray paint or emulsion that I could use? I tried using paint but I wasn't satisfied. But then again it was my first time so... any suggestions?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
