3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an awesome Harry Potter wand from a sheet of paper and glue gun glue
Step 8Paint on the wand main colour
paint on the wand main colour
Paint on the wand's main colour. In this case I have chosen brown, but any colour will do. I chose this because I wanted it to look like natural wood. But you could use black or an off white for ivory or any other muted colour. Paint the whole surface but don't worry if it isn't too even, in fact this will make it look more like a natural material. (here you can see I have painted half of it.
IMPORTANT: you must use a type of paint that dries waterproof. Ideally use acrylic. The reason for this is that the next step uses a wash which you have to wipe off while it is wet and if you have used a paint that can wipe off for this stage, then when you apply the paint from the next stage it will rub this paint off as well (which is not what you want).
To mix brown use all the primary colours (red, blue and yellow) in varying proportions depending on what sort of brown you want, or one primary colour with any secondary colour (orange, purple or green). Mix in a little black (but not too much) for a darker brown and allow it to be streaky if you want.
17 comments
Dec 6, 2011. 10:00 PMzhuphaphared says:
I used painting paint, it works fine
Jun 22, 2011. 10:13 PMloveeveryone says:
Is it okay to put blue as the base coat and then try to put brown for the main color? I mean, does it show up below the brown???
Oct 28, 2011. 3:47 PMathomas28 says:
No, it doesn't show. I did the same thing with red. Just paint it on really thick.
Aug 7, 2011. 7:25 PMhtonks says:
Um.. my acrylic paint says water based... does that mean it will rub off in the wash?
Feb 26, 2011. 3:46 AMharry potter rules says:
instead of a glue gun could i use super glue to make the design in step 6
the super glue dries in 10 seconds and i was wondering if it could work
please reply quickly
Jun 10, 2011. 2:34 PMluke h says:
no i tried it it failed it doesent stich and it goes sraight through the papper and sticks ur fingers together
Jun 13, 2011. 12:02 AMharry potter rules says:
thanks for trying
Jan 26, 2010. 4:35 PMPotterWiz says:
Where am I supposed to get spray paint?
Aug 26, 2010. 5:22 AMthehongkid says:
A craft store or any 2 doller shop. maybe a hardware store too.
Feb 18, 2010. 2:26 PMcodongolev says:
hardware store.
Dec 19, 2009. 11:55 PMninjadino79 says:
What would be the best color to use if you are making, one: willow, and two: snapes wand?
Sep 29, 2009. 12:49 AMthehongkid says:
so what is the main reason for putting on the spray paint. do i have to put on the spray paint? ive noticed white spray paint is very similar to liquid paper/ white out.
Sep 28, 2009. 4:23 AMthehongkid says:
when spraying the base coat do you just keep adding layers untill the lines (gaps) disappear?
Sep 18, 2009. 3:39 AMthehongkid says:
how did this wand turn out so glossy? when ever i paint it, it leaves a stripy texture.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
