3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an awsome fuse
Make an awsome fuse
How to make an awsome fuse with easily attainable products that doesnt leave a trace and lights easily.
Step 1Get your materials
get your materials
To make this fuse all you need is ...
Yarn (as long as you want your fuse to be)
a rocket engine (technicly optional but is somewhat important)
rubbing alcohol ( also technicly not required)
clear nail polish ( works pretty well)or
colored nail polish( works very well)
81 comments
1-40 of 81next »
May 19, 2009. 5:36 PMshaneomacmcgee says:
might not wanna break it into powder with the hammer... it could very possibly explode if you hit it too hard
Oct 7, 2010. 4:44 AM22894 says:
man up
Jul 27, 2011. 9:43 AMItscrafty says:
XD
Aug 9, 2010. 11:40 AMToddisI says:
It would only happen if a spark appeared in the hammering process.
Jun 26, 2010. 2:21 AMxiaosijun says:
is this blackpowder or match head?
Jul 18, 2009. 3:11 AMlittlemog92 says:
heh When i made black powder i put it in a coffee grinder...But i grinded all ingridients seperate .....SO DONT THINK ITS SAFE TO PUT UNSTABLE EXPLOSIVE COMPOSITIONS IN A COFFEE GRINDER I DONT RECOMEND IT.
Jun 6, 2011. 3:21 AMfail says:
I tried making some fuse with twine soaked in acetone. I accidentally left the lid off the bottle of acetone, and the vapour caught and turned it into a pulse jet. This improvised jet then lit some other things on fire. I did manage to put the blaze out with a fire extinguisher, but it really made me think about how dangerous this sort of thing is. By the way, the fuse didn't work at all. The flame traveled the whole length of it in a fraction of a second.
Jun 24, 2009. 12:01 PMcclark13 says:
will flash powder work?
Aug 9, 2010. 11:39 AMToddisI says:
It will be flash cord if you used that stuff!!!!!
Jul 5, 2009. 3:51 PMBOOM5601 says:
probably, but it'd burn quite fast.
Jun 26, 2010. 2:28 AMxiaosijun says:
please email me if you succeed. xiaosijun@gmail.com. i am quite interested in your invention
Jun 26, 2010. 2:27 AMxiaosijun says:
well. i think that is not a fuse but a more flamable string. fuse has to be able to burn without oxygen. although you add some kind of powder to you "fuse", and the powder may generate some extra oxygen, i recommend you put the string in sand to test if it still burns well.
Feb 19, 2010. 10:55 PMdungeon runner says:
Nice one! You could also clip off the heads of matches, crush them, then dissolving them with water and soaking a length of string in it. I haven't yet tried, though.
Apr 20, 2009. 4:13 PMatokad33 says:
use white lightning wax lubricant for bikes it doesn't dry as fast and it burns really well soak some cotton or hemp string in it and light it up!!!
Feb 20, 2008. 1:41 AMMalaachi says:
The best way i have found to make a some what reliable fuse is as follows: Grant's stump remover/ potassium nitrate containing substance. Dissolve in water till saturation, soak napkin, let dry and cut off a small rectangular piece, it works great!
Sep 2, 2008. 3:27 AMDrCoolSanta says:
adding sugar with saltpeter should work better. Saltpeter as such will not be so good.
Jan 4, 2009. 7:53 AMPKTraceur says:
Salpetre, or Saltpeter, or Potassium Nitrate. Same things...
Apr 19, 2009. 7:50 AMac1D says:
If you can get me any of the 3 above, im paying you a big extra. in canada.
Jan 25, 2009. 2:48 AMDrCoolSanta says:
Well I know that. I said put suger in with it. Wierd people trying to show off.
Sep 18, 2008. 2:34 PMMalaachi says:
Adding sugar does nothing extra! Just makes it smoke more...
Jan 25, 2009. 8:01 AMPKTraceur says:
Actually, it makes it more ineffecient...
Apr 1, 2009. 6:12 AMVulcanator says:
Actually, it decreases the burn rate, so the fuse burns longer, increasing the time before your explosives go off
Apr 1, 2009. 1:54 PMPKTraceur says:
Exactly. Why wouldnt you want ineffeciencies in your fuse? It gives you more time to run! -PKT
Sep 19, 2008. 6:52 AMDrCoolSanta says:
It does, along with creating smoke, sugar burns better than most natural fibers. The smoke mixture one sustains better.
Apr 25, 2008. 8:42 AMladiesman247 says:
yah well not all ppl can get those items can they... great job dude....
Sep 18, 2008. 2:35 PMMalaachi says:
If you live in the USA you can.
Nov 12, 2008. 1:30 PMColbyCirca89 says:
Yes, the USA is good for being able to get pyro chemicals. This may be a bad thing, but I think it is quite nice.
Feb 20, 2009. 7:32 PMGamer917 says:
just soak string in purell hand sanitizer and lite it
Feb 21, 2009. 2:37 PMGamer917 says:
dip it in purell and immediately lite it
Nov 12, 2008. 1:28 PMColbyCirca89 says:
Seriously people, there is a Macro setting on your camera. It allows you to take up-close pictures without them being blurry. The most common symbol for this Macro button is a flower, more specifically a tulip. Other than that, this is a good Instructable.
Sep 9, 2008. 10:30 PMwhathisname says:
i do all kinds of pyro stuff and a reliable fuse is hard to make on limited materials so i usualy just use ordanary gold sparklers, they are reliable, burn in low oxygen, are wind resistent and give you enough time to run the f**k away.
Nov 12, 2008. 1:31 PMColbyCirca89 says:
Yes, time to run is a good thing.
Jan 1, 2008. 8:04 PMMalaachi says:
Common sense, is that why you lit it next to some rubbing alcohol. Other wise good work but um shouldn't it 100% cotton yarn because synthentic just melts I can't get it burn.
Sep 19, 2008. 6:57 AMDrCoolSanta says:
Last I remember, all the synthetic threads that I have burn better than cotton.
Feb 17, 2008. 4:31 AMjonrb says:
I would suggest putting a thin layer of glue so it help burn...
Sep 19, 2008. 6:56 AMDrCoolSanta says:
You can't seperate alcohol from water without burning the alcohol. I don't blame them for that.
1-40 of 81next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:mspark400
I love tinkering with anything and everything I can get my hands on. I also enjoy high adventure outdoor treks and relaxing in the shade at 14,000 ft. I am a sophomore at Rensselaer Polytechnic Inst...
more »
