Make an easy guitar distortion pedal (STEP BY STEP!)
 by mikehayworth
Step 4: Important Step: diodes!
http://www.allaboutcircuits.com/vol_3/chpt_3/1.htmlI will not go into detail with the diodes as you do not really need to know much about them other than what they do, how to connect them and some other stuff.
Diodes are used in circuits to stop electricity from flowing back into the circuit. They only let current through in one direction. The diodes in the distortion pedal are what make the distortion. Diode-clipping distortion is what this called!
There is a certain way to connect diodes. It is pretty straight foreward.
There is always some sort of line on a diode (except for LED's) but on regular diodes there is always a line. Like in the picture below on the left side of the diode is a line.
The schematic symbol for a diode is shown below:
You connect the diode with the line facing the direction the arow is pointing.
Reccomend u read this
More on diodes: http://www.allaboutcircuits.com/vol_3/chpt_3/1.html
Undermig says: Nov 12, 2009. 1:33 PM
but is their a way to put them?
mikehayworth (author) in reply to UndermigNov 12, 2009. 3:49 PM
yes, there is a line on all diodes, (like the one above, it has a line!) and in my diagrams there is a line on each diode, so just put the lines facing the same way they are in the diagram!
Undermig in reply to mikehayworthNov 12, 2009. 5:20 PM
o ok
Undermig in reply to UndermigNov 12, 2009. 6:15 PM
and are they really small?
mikehayworth (author) in reply to UndermigNov 12, 2009. 8:08 PM
the lines, or the diodes? the diodes should'nt be reeaaly small but they will usually be about the same size as a resistor sometimes bigger sometimes smaller, but the line should be big enough that you can see it though.
Undermig in reply to mikehayworthNov 13, 2009. 5:19 AM
ok well i am pretty sure the one i have is a diode i can see in the picture its the same thing but mine is very small
mikehayworth (author) in reply to UndermigNov 13, 2009. 7:34 AM
yeah, some can be really small and some can be really big, like, some rectifier diodes are huge.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
