Make an iPod Speaker from a Hallmark Music Card
 by justinseiter
Featured
Ever get one of those cards for your birthday that plays music when you open it? Don't throw it away! With a little help from Tony the Tiger, you can use it as a speaker for your iPod.
Step 1: Required materials
Hallmark Music Card
Old headphones
One empty cereal box from a Kellogg's Cereal Variety Pack - I used Frosted Flakes, but you can choose your favorite cereal. It will not impact the outcome of this project. ;-)
Glue Gun
Electrical tape
Utility knife
Not required, but helpful: Soldering iron
1-40 of 325Next »
ewilhelm says: Nov 22, 2008. 12:30 PM
This project was mentioned on NPR's Weekend Edition Saturday!
droski21 says: Dec 12, 2012. 12:36 PM
hmmm... so do I cut before the wire splits or after? Thanks in advance =)
Adambowker98 says: Jun 16, 2012. 8:04 PM
How loud is it?
4lifenerdfighter says: Mar 1, 2012. 6:39 AM
So are the headphones just used for their TRS plug and the card just for its speaker? This Instructable is a bit hard to follow.
Adambowker98 in reply to 4lifenerdfighterJun 15, 2012. 8:01 PM
Yep.
isaacwilk says: Apr 11, 2012. 10:49 PM
If you're using headphones with both left and right wires, then you only connect the speaker to one of the wires, won't it play only left/only right instead of both sides at once?
Noahslater16 says: Feb 5, 2012. 5:51 PM
Cool it works!!
mg9990 says: Dec 7, 2011. 3:51 PM
http://www.youtube.com/watch?v=e0v-JZLp06Y
I made this video, based off of this instructable :) hope it helps anyyone. feel free to ask me questions
nickiek says: Aug 10, 2010. 11:46 AM
Im trying to use a set of ipod headphones for this and there are four wires in it. A green, red, a green and red, and a copper wire. im trying to attach them in almost all combinations and they are not working. any tips?
mg9990 in reply to nickiekDec 4, 2011. 9:04 PM
Ok so what you need to do is separate the RED and COPPER wires from the headphones. You can tape the other 2 to the cable or cut them or keep them for adding a second speaker the same way. Then you need to take a lighter and burn the red and copper wires until they are black, but leave a little hint of color at the bottom so you can tell which is which. When you burn them, you will light the fiber insulation in the middle that keeps you from making a conection when you tie/solder the wires together. :) Hope it works for you! I found my project did not work with a pair of headphones that were broken (thought i'd try it). Make sure your headphones work before you use them!
Frank Lampard 13 says: Dec 4, 2011. 3:15 PM
mine did not work
Caleb Nehrbass says: Oct 12, 2011. 6:38 PM
i want to know how to actualy AMPLIFY it. thats what i'm looking for!
fireguard in reply to Caleb NehrbassOct 13, 2011. 8:48 PM
Zackly! I saw another instructable that mentions an amplifier, but not much about it... frustrating. I made one with a cardboard cornmeal can... also no amp, but it's almost loud enough, with the musical card speakers. Good luck with your search. If you find something, post here, I'll do the same, okay?
Thanks Caleb.
Doug
ariddick1 says: Aug 20, 2011. 1:17 PM
Cool. It works!
dodo91 says: Sep 22, 2010. 6:57 PM
im a genious! im use both side, and im ganna make the two sides, then stick the to my equilizer shirt! (a shirt that show a light up equalizer with music). i will be a walking dance party!! thnx man!!
robotalamode in reply to dodo91Aug 4, 2011. 2:40 PM
cool
i_is_for_impulsive says: Jan 8, 2009. 3:00 PM
where do you cut the wire?
robotalamode in reply to i_is_for_impulsiveAug 4, 2011. 2:39 PM
doesnt really matter
leggomylegoeggo in reply to i_is_for_impulsiveFeb 8, 2011. 7:21 PM
I don't think it realy matters as long as you have access to both the positive and negative wires inside the bigger one.
bassclarinet23 says: Nov 23, 2010. 2:34 PM
I'm just testing the speaker with my iPod, and I am able to hear the songs, but it is very quiet, even with the volume cranked up. What do I do?
robotalamode in reply to bassclarinet23Aug 4, 2011. 2:35 PM
get/make a preamp/amp(theyre called diffrent but they do the same thing)
ShadowAssassin says: Dec 23, 2010. 1:33 AM
I'm thinking of making this project... But instead of just one speaker I'm getting four. I'll get two pairs of head phones and Connecting them to all of my speakers. Then getting a headphone splitter so it can all go onto one ipod... Should I do it??? ;)
robotalamode in reply to ShadowAssassinAug 4, 2011. 2:33 PM
it will probably be quieter because at least with my nano 3 gen when you ues a splitter the volume in the speakers/headphones is halved
chilll2009 says: Dec 21, 2010. 6:59 PM
great(!), but does it work for a 5g nano?
robotalamode in reply to chilll2009Aug 4, 2011. 2:30 PM
it works for litterally any device with a headphone jack
charlie.nourse in reply to chilll2009Dec 22, 2010. 9:53 AM
Yes, in fact, I tried that with mine this morning before even reading this!
chilll2009 in reply to charlie.nourseDec 23, 2010. 9:28 AM
thx!
TheRyleeAnn says: Jul 27, 2011. 11:01 AM
hehe this seems simple. i always TRY stuff like this, and fail miserably. but i think if i come across some old headphones, and someone gives me an audio greeting card, i'll do this ASAP (mainly to stop my siblings from playing it day and night. it gets annoying.)
jmastroberardino says: Apr 7, 2011. 3:51 PM
How durable is this?
huntjulien in reply to jmastroberardinoJun 18, 2011. 11:18 AM
its super durable. its heavy duty. its what construction workers use.
Fearbot in reply to huntjulienJun 21, 2011. 9:21 PM
I like you.
Fearbot says: May 19, 2011. 5:35 PM
There is a way you could add more sound to it. Use the old headphones left and right stereo speakers, and the hallmark mono speaker. And arrange like in the image below, wiring is practically the same as this guides.
(Only major problem about this would be power, but since they are cheap speakers, might not be a problem.)
hgladysz says: May 15, 2011. 12:56 PM
its doesnt work, can u help at all? thanks
peacemon1198 says: Apr 9, 2011. 6:55 AM
does it matter the quality of the headphones
Loganbdubz says: Apr 3, 2011. 10:43 PM
Very nice. Quick and easy build.
packerfan12 says: Dec 1, 2008. 2:08 PM
would duct tape work instead of electrical?
cody316 in reply to packerfan12Sep 16, 2010. 10:59 AM
Duct Tape will work instead for pretty much anything! lol
popcorn4lunch in reply to cody316Feb 19, 2011. 12:51 PM
tru dat!
jotism in reply to packerfan12Feb 15, 2009. 10:14 AM
duct tape??? what is it with instructables and duct tape??? yes it would work.
Foaly7 in reply to jotismFeb 20, 2009. 3:29 PM
Duct Tape is The Universal Medium, and it fixes everything. Duct Tape Owns. That's what's up.
1-40 of 325Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
