3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an iPod Speaker from a Hallmark Music Card
Step 3Prep headphones
prep headphones
Cut headphone wires at the base of each headphone (L & R). You'll only need one of the two lines so pick the one you want to use and cut the other where they converge mid-way down the length of the chord.
Next, strip the wires. You may notice some fiber-like material interlaced with the leads themselves. Strip this stuff out with your utility knife or you will not be able to get a solid connection from your headphones to the speaker (thanks to Richard at my local Radio Shack on that one). Alternatively, you can use a soldering iron to burn this stuff away. I found this method much easier and a bit more effective.
22 comments
Sep 22, 2010. 6:57 PMdodo91 says:
im a genious! im use both side, and im ganna make the two sides, then stick the to my equilizer shirt! (a shirt that show a light up equalizer with music). i will be a walking dance party!! thnx man!!
Aug 4, 2011. 2:40 PMrobotalamode says:
cool
Jan 8, 2009. 3:00 PMi_is_for_impulsive says:
where do you cut the wire?
Aug 4, 2011. 2:39 PMrobotalamode says:
doesnt really matter
Feb 8, 2011. 7:21 PMleggomylegoeggo says:
I don't think it realy matters as long as you have access to both the positive and negative wires inside the bigger one.
Feb 20, 2009. 7:18 PMshenkmeister says:
I don't quite get the second paragraph, at the beginning where it says, "Next, strip the wires." what part of the wire do i strip?, the parts at the ends?
Sep 22, 2010. 7:04 PMdodo91 says:
lolz u dont know what stripping a wire is.
ok. u see the plastic, covering the metal wires inside, we need to get it so on the end, just metal is showing, using ur nails (or sissors carefully) get that colored plastec off of all those small metal wires. only on the end. not all the way down. congrats, u just learned how to stripe a wire.
May 26, 2009. 10:54 AMpryrofreak119 says:
it didnt do any thing
ok heres the wire where do you cut it ----------<
here --------/< or here -------------</
Sep 22, 2010. 7:01 PMdodo91 says:
it says -------/< but i recomend getting 2 cards, cutting --------
Mar 16, 2010. 1:01 PMMylesMaverick says:
I tried to do this with an old pair of airplane earphones (the ones you put in your ear) and then again with a dollar store earphones (again the ipod type that you put in your ear) and nothing happened. Do you have to use the Big Ol Clunky headphones from back in the day? cuz the wires in the new earphones is too small. Dang I was really looking forward to this! :o(
May 20, 2010. 11:02 AMybahman says:
The cables you're using probably have magnetic sheilding on them. You'll need to solder the connection so as to melt the shielding to make an electrical connection.
You also could sand the tips of the wire (where you will make the connection) down so the conductive metal will be showing, but then again you said they're small so that'd be tedious.
Another possibility is that you have the polarities switched. There're probably 3 wires out of the headphone connector. Try all different combos until one works. It doesn't really matter which ones you use since it will be mono eitherway.
Aug 23, 2009. 11:44 AMBenX10 says:
the wires were 2 small 2 connect well, spent a while for nothin, might Re-Try to connect it later when im really bored,..
Jul 18, 2009. 12:44 PMspidangular says:
I did this and it's not much louder than a set up headphones with the volume up. you've got to be in absolute silence, or have the speaker resting on your shoulder to hear it. i found a headphone set at the dollar store, so hey, i got my dollar's worth of fun out of it.
Aug 17, 2009. 9:24 AMpipsniper says:
if you want it to be louder, get some bigger speakers. May I suggest trying speakers from old steros or old computer speakers
May 17, 2009. 9:56 PMskatelong says:
does the material stuff catch fire?
Jul 17, 2009. 8:01 PMalex_mccoy51 says:
no
Mar 1, 2009. 10:35 AMbassclarinet23 says:
So the original plug and one of the wires goes to the ipod and the other goes to the stereo?
Jan 11, 2009. 8:59 AMi_is_for_impulsive says:
earbud wires are too small. you should either but headphones from a garage sale or get something from Radioshack. Ps the plug thing for an iPod is 1/8"
Dec 13, 2008. 9:08 PMsliceofpain says:
i dont understand step 3
Nov 20, 2008. 9:25 AMPyromaniak says:
You can also use a lighter to burn the fiber off too.
Jun 15, 2008. 10:53 AMzach12 says:
could i use earbuds instead of headphones
Jul 1, 2008. 9:23 PMLebanite says:
I believe it would work the same because what you are looking for is the cord, so it wouldn't matter if you used headphones or earbuds, they use the same cord.
Jul 2, 2008. 7:28 AMzach12 says:
k thx
Jul 2, 2008. 11:10 PMLebanite says:
No Problem :)
May 19, 2008. 10:25 AMmegold says:
Cool and simple for a newb like me! If you have two cards, could you keep the stereo leads and create a matching set?
May 19, 2008. 6:21 PMschimmi says:
yes
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:justinseiter
