3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make an indoor/outdoor boomerang
This originally designed to be indoor, but will work outdoors.
Make an indoor/outdoor boomerang that actually comes back.
I recently bought a three winged boomerang, it is the only boomerang that I have boughten that actually comes back. When I showed it to my friends they all wanted one, but there isn't any stores around here that sell them. I decided to make them copies that work.
If you have all the parts this can be a great day project for all ages.
This boomerang is safe to use in the house because it is made of styrofoam. The final boomerang will weigh only 0.3 ounces (six grams).
This boomerang will only go out about eight to ten feet and come back.
Use this in a large room with no air movement.
If you use this outside make sure there is very little wind. I like to use mine outside best.
You will have to move about a step or two to catch. As the video will show.
This will not come back 100% of the time.
Step 1Materials
Materials
The materials are very simple, and there isn't much to get.
All that you need to get is:
1-) 1 roll of aluminum duct tape (weight), normal duct tape will work, but still has to reach desired weight.
2-) 1 sheet of blue, Georgia Pacific, fan-fold (body of the boomerang)
3-) the pattern (in the pictures)
4-) utility knife
5-) scale (for weighing)
Both of the materials can be bought at Lowes, Home Depot, Menards, or any other hardware store.
The pattern is below, not quite sure how you are going to be able to print it out. Any suggestions will be greatly appreciated
64 comments
1-40 of 64next »
Feb 14, 2010. 4:20 AMwitchiwotti says:
I remember these!
check out the original @ http://adland.tv/commercials/nerf-boomerang-early-1980s-classic-030-usa
Oct 27, 2009. 9:33 PMyounce says:
it is very amazing jus with a few steps can create a safety toys for kids
Oct 19, 2009. 4:14 PMcantrell8 says:
A good way to make a boomerang is to use  2 paint stirrers ,whitle doun the egees & hot glu them together
Oct 13, 2009. 4:14 PMthepelton says:
I have a laser engraver.  I think I may use 1/16 inch plywood instead of the meat tray, but I may have to wait a couple of days because of my work before I can fly it.
Oct 12, 2009. 5:36 PMdukich5536 says:
Well, this might be a stupid question, why it's suppose to be 6g? Just curious.
Oct 12, 2009. 2:30 PMthepelton says:
Could you use some of that foam plastic from a supermarket meat tray?
Oct 2, 2009. 5:41 PMRe-design says:
I've got some foam that has aluminum on both sides. My 7 year old nephew is coming over next week end and I think we'll make a few of these and see how they work. Thanks for the fun inst.
Oct 11, 2009. 4:33 PMRe-design says:
It's been raining so we're putting it off until better weather.  We did inside stuff this weekend.
Oct 8, 2009. 11:24 AMMr. Thrak says:
 You could consider using a foam cutter (heated wire) or heat your knife over a candle to make it cut easier. The lines will be much smoother; it's like cutting through butter.
Oct 3, 2009. 5:29 PMzack247 says:
im bookmarking this so i can make it when i have the time
Oct 3, 2009. 11:00 AMkevinhannan says:
What a brilliant 'ible! Well documented, too! I'll be having a go at this with one of my unfortunate urchins! Thanks.
Oct 3, 2009. 12:07 PMRe-design says:
Children dependants.
Oct 2, 2009. 5:44 PMRe-design says:
How thick is your foam and do you shape the edges like an airplane wing or just leave it square?
Oct 3, 2009. 6:45 AMscoobbrandon says:
could i make it from a foam plate
Oct 3, 2009. 3:00 PMscoobbrandon says:
Ok I'm goin to make one soon
Sep 30, 2009. 3:09 PMampeyro says:
maybe if you put weight only in the end of the fans it accumulates more kinetic energy with the same weight, what could mean more fly time
Oct 3, 2009. 8:51 AMampeyro says:
I finally tested it, with a common 3 winged boomerang(from a 8-pack of cola cans) without anything added it flies normally, with 3 10 cent coins(euros, not dollars) on the center it just falls in a parabolic trajectory, with a coin in each wing it flies further but don't return (3 coins is a lot but I lost the aluminum tape and I didn't want to buy more)
Oct 1, 2009. 10:32 AMnoah1r says:
can i use foam core?
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:logangina
ADD ME ON XBOX 360 LIVE AT Encased Death ____________________ i am almost never on the site so comment or pm me and i will get back asap tell me if my instructables r good or bad leave comments pleez...
more »
