Introduction: Make an Old Opinel Knife Lockable When It Is Closed
Picture of Make an Old Opinel Knife Lockable When It Is Closed
Invented by Marcel Opinel in 1955, the Virobloc safety ring was improved in 2000 on all the Opinel ranges. Since that year it is  possible to lock the blade in the closed position (safety during carrying). If you have a pre-2000 Opinel knife, this instructable will show you how to adjust the ring such that the  blade can be locked when the knife is closed. It will only take 5 minutes. You need a iron saw and a bench vice.
Close the knife.
Put it in a bench vice.
Take your saw and saw a corner of the lower part of the safety ring. The cut starts just above top of the blade and ends at the same height as the cut ends that is on the upper part of the ring.
Move the ring over the closed blade.
Done!
klee27x (author)2013-10-20
You can get a cleaner job if you pop the ring off, first. FYI, you cut the locking ring on the opposite side from the factory rings. When you buy a new Opinel, you're going to have knife lock dyslexia. :)
klee27x (author)klee27x2013-10-20
BTW, iron saw = file?
About This Instructable
2,464views
4favorites
License:
More by robertbuzink:Make an old Opinel knife lockable when it is closed
Add instructable to:
