Now how this works is the image is provided by a semi-dead computer. My computer can only display the win 98 screen but that will work for this Instructable.The line is really just the win 98 load screen just compressed into a long line. This will work with any computer that can display something. The monitor also does not have to be broken, but to comply with the dead computer contest rules, mine is. This oscilloscope is FULLY functional, not just a visual toy. So please treat this oscilloscope like an oscilloscope or else could result in electric shock.
Now the fly back transformer in this thing is running at 30,000 plus volts. So be safe and don't hurt yourself. Electrocution from this thing can result in serious injury or death. If you have any wear rubber shoes and only work on this project with one hand. Why? You ask. Because if you use two hands electricity could jump across both arms and hit the heart on the way. So only use one hand. And also if possible wear rubber shoes.
Remove these ads by
Signing UpStep 1Materials!
- wires
- Crt monitor
- dead computer (as long as it can display something)
- soldering iron and solder
- wire cutter
- screwdriver
- electrical tape
- Speakers with built in amp or an amplifier and speakers
BE SAFE
I am not responsible with what happens to you in the process of dealing with high voltage,
so don't shock yourself in the first place!
Actually, the monitor has a HV protection circuit, so it will shut down before it produces 30KV.
If you want it to run horizontally, why not just rotate the yoke 90 degrees?
It's been a while since i heard this so i may be mistaken and it was for a tv not a computer monitor which i'm not sure that makes a difference.
i think I have exactly the same bunch of wires as you . 4 wires that come from the circuit board and connect of a small circuit on the deflector.. ( theres a blue, red, yellow and brown). When I cut the red and blue, then I injected some music. But now my crt monitor doesnt go on! ??! When I reconnect them like it was originaly, my monitor work well.
Did you experienced this problem?? What can I do?
Is the input mono? Ive tried to put the + of the music signal on the red wire and the ground on the blue one. I have also tried the opposite....the crt monitor always shutdown byitself 2 secondes after i press the power button...
and also because that you can messup w\ the VGA so it will give u a bad reading but i'm not saying this is bad thoe.
i think i might tok the x axis or some thing.
are duct tape Energized?
do you need to have the monitor plug into a computer or is there a way to get it so you dont have to have a computer to use it???
