Make annoying virus/worm. (very agrivating)
This instructable will be explaining how to use my very own, annoying virus that I made. You can have my word. What you will download WILL DO NO HARM to you or your victims computer.
Step 1Download
Download
Please don't leave comments that this is a virus. Technically, it really isn't, but I like calling it that, but it WILL NOT, AND CANNOT HARM YOUR COMPUTER!. If you think it's a virus, then DON'T DOWNLOAD IT AT ALL! All it does it make a series of measages popup that don't go away.
(note: if you don't believe me, download them, the inspect the batch and vsb files)
there are two versions: Vista and XP. This is mostly because the different file paths and having to run as Administrator.
These batch and vbs files required little work. You only have to run 1 or 2 batch files that copy the files to startup and other directory.
the link is below.
http://www.freewebs.com/louieaw/TypeVista.zip
http://www.freewebs.com/louieaw/TypeXP.zip
1. copy the link ou want, and paste it in a new tab or window. the download should automaticly start (hopefully)
2. download it wherever
3. unzip the ZIP file you want (TypeXP or TypeVista) to "C:\" (THIS ONLY HAS TO BE DONE IF YOU'RE USING VISTA
4. go to step 2
25 comments
Nov 1, 2011. 2:38 AM@B04C@0 says:
This is not worm virus,this is a simply bat "virus" lamers -.-''
Dec 5, 2011. 1:22 PMTheBeanhacker says:
this is a .bat file with {AUTORUN} enabled so that it automatically starts when you boot your computer
Oct 15, 2011. 1:01 AMlherrera3 says:
is this safe?
Aug 16, 2011. 12:10 AMwliu3 says:
can't download file!
Mar 2, 2010. 4:04 PMlikelikelikelike says:
 i did this last month to my cousin betty's computer. i got grounded but still real funny. i just made my own instructable to comment.
Jan 25, 2010. 4:07 PMa4great says:
what is the coding for KILL.bat?
Sep 25, 2009. 3:15 PMunominame says:
lol Knock knock lukas
May 29, 2009. 3:43 PMfwjs28 says:
this isn't a worm or virus and although a nice take on the original idea i think the title should be better
May 26, 2009. 2:19 PMdombeef says:
What is the thing in the upper right corner?
May 27, 2009. 2:34 PMdombeef says:
Oh ok
May 9, 2009. 9:48 AMB.F.L.M says:
once it gets past the first couple of boxes, its says "file directory not found" what do i do? (TypeXP) i pressed copyXP, and it copied everything to the write place, but that still happens.............. what do i do, and you didnt explain what Martix.bat is and what its for (typeXP)
May 11, 2009. 6:29 AMB.F.L.M says:
OK I figured it out 1: for some reason, i had to CREATE the ProgramData folder 2: the script for "annoyrun" "start1" "annoymessage2" was incorrect. They all were set to run the next preceding files, but it had the wrong address(something in the F:\ drive) so it kept popping up that the directory wasnwasn'tnd. i fixed it though and it worked exccexcellent!!! :D
May 11, 2009. 7:49 PMB.F.L.M says:
no problemo this visual basic script chain is awsome by the way
May 8, 2009. 4:36 AMaldecodex says:
THANKS louieaw...
May 4, 2009. 6:39 PMaldecodex says:
but how to do that..how to make it?...where those specific files found??..
May 4, 2009. 6:54 PMaldecodex says:
i mean..how am i going to make it activate by someone...or setting it as a trap...
Apr 27, 2009. 6:15 AMPKM says:
Hmmm, a wannabe hacker/virus writer who uses freewebs. You don't happen to know a guy called MODX, do you? :P
OK- this isn't a virus. It's just annoying and largely pointless.
Apr 24, 2009. 6:05 PMpelrun says:
What an awful 'ible. Can't you come up with something actually worthwhile?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:louieaw
