3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make biodegradable seeding pots.
Step 3Roll it.
Roll it.
Lay the cone shaped object of your choice onto the paper and roll the paper around it, it should cover the hole thing. You can also use the paper double layered, if you want the pots to be more stiff.
The paper must overlap the object you wrap around. This overlapping part, you crumple together, building the bottom of the pot.
2 comments
Mar 22, 2011. 3:18 PMBiffspagnutz says:
What kind of seeds are those?
Sep 24, 2009. 3:59 PMtglassburner says:
The object you are using is a cylinder not a cone.
Apr 25, 2010. 1:59 PMjohnny3h says:
As tglassburner says this is a cylinder in this 'ible, BUT...
IF
you can find a slightly TAPERED [larger at top than at the bottom] mold / form, it will be easier to remove the delecate wet newspaper pot from the mold.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:knarx
