you will need:
-2 cans (i used 2 regular aluminum pop cans)
-scissors
-tape (i used scotch tape)
-i also used a screwdriver to punch holes
safety precautions:
-cut aluminum is razor sharp, please use caution when cutting!
-poking holes is tricky, be careful not to poke a hole through your hand!
Remove these ads by
Signing UpStep 1Opening the can
2. punch a hole in the bottom as shown... be careful! then cut all the way around the can, remove the bottom.
3. tape the bottom from the outside in. this will make it less likely to cut someone. tape it twice in some locations.
don't forget to cut a inlet for the wire too!!! i taped it also.
Add Comment
