This is my version of the thick, custard-style yogurt you usually get in the grocery store.
Ingredients:
A half gallon of milk
1/2 to 1 cup powdered milk
1 cup of live, active culture plain yogurt
Equipment:
Large saucepan
Candy thermometer
9 very clean plastic yogurt cups with lids
Something to stir with, like a fork or a spoon
Cookie sheet (optional)
IMPORTANT: Make sure that all of your equipment is very clean. Your goal is to create a fertile, inviting environment for the yogurt cultures, so it's important to make sure that there aren't other, unwanted cooties lurking around as well.
Remove these ads by
Signing UpStep 1Scald the milk
Scald the milk by very slowly bringing it almost (but not quite!) to a boil. If you'd like, you can put the candy thermometer in now, to check the temperature as it's cooking. If you do want to use the thermometer at this stage, put it in the milk while it's still cold. If you put it in after it's started to scald, it will boil over and make a big mess.
At the scalding stage, the milk will start to look foamy and you'll see the tiny bubbles rising to the surface pretty quickly. This will happen at around 200 degrees F.
Remove it from the heat immediately. Once milk starts to boil, there's no stopping it.
4
comments
Add Comment
bentm
says:
bikeNomad
says:
Add Comment
