Make Distance and Temperature Measuring Sensor
Published
Introduction: Make Distance and Temperature Measuring Sensor
About: An electronic hobbist and a tech-savvy. Love to know and publish good electronic projects. I use some popular micro controller like raspberry pi, arduino, linkit one and also some basic ICs to make my projec...
Hello friends. Today i am here to tell you how to make a distance measuring sensor which also tells you the temperature of your surrounding. If you want to measure distance of a object then you can use it or you are new to arduino projects. I made this because i want to do something interesting with my arduino. If you want to make some interesting projects with arduino then you are on right place. Friend this is my first instructable so please like it and also don't forget to comment on it. You are free to make my instructable better.
Step 1: COMPONENTS:
for this project you need following part:
  • Arduino UNO
  • Ultrasonic sensor(HC-SR04)
  • 16x2 LCD
  • Temperature sensor(LM35)
  • 10K potensio( i say it potensio you can call it variable resistance or preset)
  • Breadboard
  • some wires
Lets get started......
Step 2: Connecting LCD to Arduino
Connect the lcd to arduino according to the circuit give in the picture above.
if you are new to LCD and want to check weather your LCD is working connect the LCD to arduino according to the connection given in picture and open your arduino software on your PC. go to File >Examples >liquidcrystal >Hello world and upload the sketch to your arduino board. If you see hello world on lcd then your lcd is working perfectly but if nothing is displayed on your LCD just adjust the potensio and your LCD will start working.
Step 3: Connecting Ultrasonic Sensor
now we will connect the ultrasonic sensor.
• connect vcc pin of of sensor to arduino 5v pin
• connect trig pin of sensor to arduino digital pin 8
• connect echo pin of sensor to arduino digital pin9
• connect gnd pin of sensor to arduino gnd pin
if you want to check your ultrasonic sensor upload the following program to your board
#define trigPin 8
#define echoPin 9
void setup(){
Serial.begin(9600);
pinMode(trigPin, OUTPUT) ;
pinMode(echo pin, INPUT) ;
void loop() {
int duration,distance;
digitalWrite(trigPin,HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin,LOW);
duration=pulseIn(echoPin,HIGH);
distance=(duration/2)/29.1;
Serial.print(distance);
Serial.print(" cm");
delay(500);
Step 4: Connecting LM35 to Arduino
now we will connect LM35 to Arduino.
  • connect vs pin to 5v
  • connect vout pin to analog pin A0
  • connect gnd pin to gnd in arduino board
here is a program to check your LM35.
Step 5: The CODE
here is the code for distance and temperature measuring sensor. Upload it to your board and have fun with your project. Don't forget to like and comment
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    7 Comments
    Nice attempt on your first instructable.
    thanks a lot i could make it at last
    your ultrasonic sensor code says error compiling
    Their was a problem in the ultrasonic sensor code which I have now corrected
    and when I'm applying codes, only blackboxes appear in the display after upload. Please help.
    Blackboxes appear when your lcd is not connected properly. Please check your lcd connection
