3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make hobbyist PCBs with professional CAD tools by modifying "Design Rules"
Step 3Our sample circuit: Blink some LEDs.
As an example, I'm going to use a simple and rather standard two-transistor, two-led "blinky" circuit. It looks like this.
(If you decide to actually build this, the transistors can be any general purpose silicon NPN types like
2n4401, 2n2222, 2n3904.) The ON time for each LED is about R*C (one second for the values here.)
The battery can be 3V up to ... whatever, although you may need to adjust the current limiting resistors
for higher voltages.) The caps should have a voltage rating a bit higher than the power source you intend
to use. For a 9V battery, I used 16V caps. Resistors are 1/4 watt. )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
