3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make home energy improvements and have the government pay you back
Many energy improvements pay for themselves over a period of a few years. The reduced rates that the improvements pass on to you in annual savings should be enough incentive to make the change when possible. But what if you could get someone else to reimburse you for all or part of the improvements? Many areas in the United States offer incentives to home owners to improve the energy efficiency of their homes.
Energy improvements help more than your monthly utility bill. The environmental implications of making changes like these are significant as well.
Step 1Find programs
Before you do anything you should see what programs cover your area, demographic, or circumstances.
In most cases you'll need to own the home that you're making the improvements to. If you're a renter consider talking to the property owner about the improvements. Perhaps you can negotiate a trade by doing some of the labor if they buy the materials. They can knock your rent down in exchange for the work, you get lower utility bills and when they advertise to the next tenant they can brag about those lower utility rates and the energy efficiency.
The Database of State Incentives for Renewables & Efficienc is a great place to start in the U.S. Canada has an energy efficiency program for those using the Canada Mortgage and Housing Corporation or check out the ecoENERGY retrofit program for making improvements to your home.
There is a wide variety of programs available. Everything from local utility companies offering rebates for the purchase of compact fluorescent light bulbs to federal tax credits for the purchase of a vehicle that uses alternative energy.
Once you have found a program on the DSIRE site then make sure the information is up to date by contacting the agency or checking their website.
41 comments
1-40 of 41next »
Jun 18, 2011. 1:45 PMAvagio says:
Lots of great ideas!! But on a side note the Government does not have money, they do not pay for anything, they only borrow money and then have tax payers take care of the payments.
Sep 20, 2009. 8:58 AMellislake says:
the simplest and cheapest insualtion is plastic bags. im gona get round to do my instrcutable on cheapest insualtion ever. all you need to do is collect plastic bags rather than throwing them away and scrunch them up a little and put them between the joists then put a flat piece of plywood over them as a floor. that way theres no issue with weight and the bagsd are free and not going to waste on a dumping ground this owrks by trapping air inside the bags and insulates the loft. its simple i have done it in my loft but only about 10% completed so far.i think i will ahve to do the instructable soon as i got some free time coming up soon what does everyone think
Sep 20, 2009. 12:49 PMellislake says:
well in my house its ok with water vapour because the floor of the attic is insulated with normal glass fibre rolls and so is the floor of the first floor.the plastic bags are used in the actual apex of the attic underneath the tiles if you get what i mean.its a sheild against the cold air etc ????????
May 8, 2009. 12:15 PMtswain4 says:
I amplanning the vavop barrier in the crawl space but was wondering about the wall insulation you added. My crawl space is cinderblock. So you think this would create a moisture problem between the wall and the pink board? And just a comment. I have a real estate license in North Carolina and have been to many inspections. I have always seen paper backed insulation used under the house. The paper is installed facing the ground and rods are used to hold it in place, but I've never heard my inspectors say insulation is not good in this area. But, I guess we don't get as much rain? And as an added benifit, if you have a water leak you can usually find it cause it falls down or gets water stained.
Feb 6, 2009. 9:36 AMBettyinMaine says:
I live in the northeast, Maine, and recently had all the windows replaced in my nearly 100 year old house. I was amazed at the savings this improvement has already generated in regards to heating the house. So, it does make a difference and is well worth the expense.
Feb 1, 2009. 9:26 AMi.am.flink says:
When sealing pipe/electrical chases, you may be required by fire/electrical codes to use fire barrier material. Dap and Great Stuff both have fire barrier foam. Both are an orange foam, for easy ID after installation. When sealing a chimney chase, use steel flashing to bridge the gap between framing and the chimney, and close the final gap between chimney and flashing with high-temp silicone sealant (not a latex/silicone combo).
Jan 23, 2009. 9:27 PMunsernetz says:
Had an energy audit years ago, the auditor said that the whole replace the windows to save energy was marketing BS. Until the windows are the only thing left to replace leave them alone, other problems leak heat much faster than the glass panes. You need to fix the 'air' leaks before you worry about the radiant leaks. Even then it makes no sense to put high R windows into a low R wall, you won't get an ROI.
Jan 30, 2009. 10:15 AMjumpfroggy says:
Just a personal anecdote, here in the Northeast a lot of houses have a certain type of really old window, and they never seem to seal well at all. My then-fiance had all the windows replaced on her house, and the results were drastic. The problem was all the air leaks, which could have been addressed with foam tape constantly being reapplied or the (more traditional here) shrink-wrap plastic taped over the window. But replacing the windows, while expensive, did make a huge difference for the house. It's probably not great in terms of straight ROI, but it can make a huge difference for old houses with bad windows. Just an anecdote, I don't think it really negates your point at all. I was just surprised how much a difference new windows made on a seemingly ok house.
Jan 29, 2009. 9:08 PMMD_Willington says:
I can only dream of having a nice clean crawl space like that...
Jan 29, 2009. 1:40 PMlil_brown_bat says:
Energy audits and the like don't do that much if you have an older home. Yes, "there are programs" for insulation and such, but they generally require a homeowner to put up half the cost, and you have to clean up all old wiring and who know what all first. Bottom line, you'll be significantly out of pocket and will only get a fraction back. It's nice if you got the money, but...
Jan 29, 2009. 2:07 PMtoekneebullard says:
So you're saying you shouldn't do anything?
Jan 29, 2009. 2:57 PMgormly says:
No, that is not what he is saying. But unfortunately that is what way too many people are only willing to hear. lil_brown_bat speaks the absolute truth. If you have the means you should absolutely go for it, if you do not, the cost doesn't pay off. What he is saying is what is sorely lacking in the rush to be green, and that is financial considerations and honest cost/benefit. It does no good to: 1. Give unrealistic expectations. 2. Make people feel guilty about something. 3. Offer dishonest solutions for given guilt that they cannot afford. It helps more to: 1. Inform people of what they CAN do right now (like no cost recycle) 2. Give them HONEST cost/benefit analysis of things. 3. Get rid of the guilt. While I commend zieak, the "government" does not offer any significant programs that would pay for improvements, and by pay for, I mean pay for.. not a $300 tax credit on a $1000 purchase or something like that. I mean PAY for.. there are no government programs that do that. This is an AWESOME instructable no doubt, but it isn't something everyone can or should do.
Jan 29, 2009. 5:26 PMgormly says:
zieak, So you are saying your out of pocket is $462.50 for $5500 worth of work? I didn't see that in the instructable. What gives? I think you might be leaving something out? If true congrats to you, but honestly what's the catch? Only in Alaska? Only for a native? Ony in Oil rebate Checks? Or is this a foreclosure fix'er up special? Seriously, not being a jerk here but in the rest of the 49 States you do not get reimbursed all of your expenses to make energy efficient installations. Also, just so you know, my original comment wasn't a dig at you it was a dig at the increasing number of people who dont put any thought into anything. The kind that blurt out things like "So you should do nothing?"
Jan 29, 2009. 2:44 PMdiskincluded says:
I think what lil_brown_bat is saying is that for the older homes the task is somewhat impractical for the purpose of having the government reimbursing the costs.
Jan 29, 2009. 7:49 PMlordzion says:
I just want to point out that in one photo you have insulation between the ceiling joists in the attic the second layer should be running opposite of the first, I'm glad to see there are some people that care about this !
Jan 29, 2009. 12:00 PMbbmerc says:
Thanks for lots of good ideas and info. People should also check IRS.gov, form 5695 for tax credits on certain energy saving improvements. These are mainly for solar, geo-thermal and wind energy.They do change from year to year. 2 years ago I got pretty good tax credits for insulation and a tankless water heater. By the way, I don't see any mention above of tankless water heaters which really do save on your monthly bill because it's hot water on demand rather than keeping the water heater hot 24/7.
Jan 23, 2009. 6:41 AMdavethegiant says:
In step 8, you recommend that the space between floor joists should be insulated. In my personal experience this is NOT a good idea. Trapping moisture between the crawlspace and the carpet is not a good idea. I have repaired a house that did this same thing with R-19 faced rolls. Within 7 years of the home owner installing the insulation, the floor joist ends rotted and the entire south end of the house sank 2 inches. The repair was long and extensive and required hydraulic jacks, sledge hammers and some finesse. Once again, this was with fiberglass insulation, not with rigid foam, however I think I can speculate this same end with different insulation.
Jan 22, 2009. 6:55 AMNesagwa says:
Most electric companies will offer a free energy audit of your home so you can just call them and schedule it. Youll get a professional certified audit done at no cost to you.
Jan 21, 2009. 6:38 AMjeff-o says:
The governments of Canada and Ontario also offer pretty large reimbursements for energy efficiency improvements. Typically the process is to get an evaluation done, then do your upgrades, then have another evaluation. Then just sit back and wait for the cheque to arrive!
Jan 22, 2009. 6:15 AMjeff-o says:
Great, thanks! I will soon be calling them up for my second audit - hopefully I'll be getting some cash back in my pocket!
Jan 21, 2009. 10:36 AMunjust says:
one important thing to note is that older homes are not *designed* as a system to be as air tight, and sealing them up can cause serious problems. most of this you can do yourself if you're marginally handy, but look into how your home was designed to function, and where you need to maintain ventilation to keep it healthy.
i.e. the 104 year old house i just bought is *designed* to let heat melt the snow off it's roof. were I to insulate between the roof joists i would get serious moisture problems, ice dams, and possibly even roof collapse as it's not intended to take a full snow load all winter. insulating *inside* of the joists and adding roof vents with strategically placed electric snow melt cables will save me buckets of energy, but is not nearly as simple as tacking in a vapor barrier and fiberglass batts. (it's on the list of projects, but there are other issues more pressing)
Jan 21, 2009. 3:16 PMshooby says:
A very good point. Newly constructed houses in general (in the US) tend to be too air-tight. Consequentially, a typical problem with these houses is the development of mold due to high moisture and heat levels. Mold doesn't just grow on things, it eats through them, and the result is often a very costly repair bill, especially when floor joists have to be replaced.
Jan 21, 2009. 8:56 AMwebman3802 says:
Very well written. You might want to add some information about sealing leaks inside the house. There are big-ticket improvements that can be made, like replacing single-pane windows with energy star-compliant ones, but also cheaper tricks like weatherstripping (which you did mention), outlet cover gaskets, water heater blankets, etc. I'm not sure if these would be covered under the government program, but they also would pay for themselves fairly quickly.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:zieak(Zieak's site)
I like making things out of items that would have otherwise been discarded. Check out my other projects! Now a PE teacher in Mongolia! I don't have much time or even the resources to make much any m...
more »
