Make lipstick with crayons
 by belsey
Featured
Kids' crayons? Yes! Making your own lipstick takes only about 10 minutes, costs next to nothing and allows you to choose from a dizzying (and unconventional) array of colors.
Is it safe? Even though Crayola does not publish a detailed and specific ingredient list, they do formulate their crayons so that toddlers can eat a whole box of the stuff without suffering anything more serious than a stomach ache. Crayons consist mainly of paraffin wax and non-toxic pigments. Wax is a major component in any lipstick or chapstick, and crayons' pre-mixed pigments will give you more choices, at less cost than either food coloring (I've tried that too) or the powders and gels cosmetic suppliers will sell you.
This recipe works surprisingly well. The colors last longer, and stick to your lips better than regular commercial lipstick. No need to worry about evidence left on shirt collars, or on cigarette butts carelessly left in ashtrays... although sometimes, depending on the specific crayon color, the pigments might need a little extra smacking of the lips to disperse evenly.
If you're using a chapstick tube (or a lipstick tube of a similar size) and you're making this as a gift, you can download a pop-up, pop art lip balm holder I designed. The template comes in two versions, one with text and the other with an empty speech bubble in case you want to add your own.
Step 1: Containers and molds
Commercial lipstick is poured into molds to obtain a nice, slanted, rounded shape, but sometimes it comes in containers which look similar to chapstick tubes, with the top cut at an angle. I recycled one of those for the lipstick in the crayon picture, but I also used regular chapstick containers I had left over from making my chocolate chapstick, and tiny little plastic jars. It's a little harder to apply lipstick in a chapstick tube, but tins (or tiny jars) work really well if you have a brush. It's also much easier to pour the hot wax into a tin.
If you really want the real lipstick shape, you can buy molds at various suppliers. Most of these vendors cater to people who are making cosmetics for sale and not for personal use, so they sell trays with fifty or so molds, but Making Cosmetics sells a three stick mold. I decided I could do without the pretty shape, and stick with something easy and cheap. A good source for chapstick and other containers is called Specialty Bottle. They do not sell lipstick molds but they have a nice selection of tins, jars, and bottles, and no minimum quantity. Many other vendors sell similar items, and I'm not endorsing (or affiliated with) anybody.
Step 2: Ingredients and materials
You will need a small, heat resistant container, such as a stainless steel measuring cup. Use the smallest one you have.
The following quantity will fit easily into most lip balm tins, but you will have a little left over if you are using a tube, which usually holds only 0.15oz. For the triple lipstick mold, double the recipe.
I have tested a variety of different ingredients, and although the end product varies in "feel" you have a lot of flexibility in your choices.
Here is the basic recipe:
1/2 crayon of your favorite color (approx 2.4g)
1/2 tsp jojoba oil (approx 2 g)
1 almond-sized chunk of shea butter (approx 2g)
Ingredients you can add to the above:
1 pea-sized dab of lanolin (improves feel and possibly color distribution)
1 pinch gum arabic (improves color distribution and durability of color)
1 drop vitamin E (helps prevent oil from becoming rancid, improves shelf life)
1 pinch zinc oxide (makes color lighter and more opaque, offers protection against UVA and UVB sun rays -- but make sure your wax mixture is well stirred before you pour)
Alternate ingredients:
You can replace shea butter with cocoa butter (will make lipstick slightly more firm)
You can replace jojoba oil with castor oil (will make a glossier lipstick)
These are the alternate ingredients I've tried, but there's no reason you can't experiment with any other type of edible oils.
Step 3: Melting and pouring
The safest way to melt this mixture is to put it over a pan of barely simmering water. Although you might be able to melt it in the microwave, wax can combust if it's over-heated, so I prefer heating it slowly over a pan of hot water, while stirring it with a cocktail twizzler, chopstick, or the handle of a small spoon. Just be careful not to spill any water into your wax mixture.
As soon as all the ingredients are melted and well combined, pour them into your containers.
If you are using the slanted lipstick container prop it up in some rice, beans, or popcorn kernels like I did. This will allow it will set at the proper angle.
Wax contracts as it cools, so you will get a dent, or maybe even a small hole in the center of your tube. You can reduce this effect by tapping the container on the counter as it cools, but if you try topping it off with more wax chances are the extra drop you add will come off when you use the stick. I have a theory that plunking the tube in a cup of hot water and letting it cool super slowly would help too: if the sides cool at the same rate as the center, no hole should not form, instead the whole level would go down a bit. Putting it into a warm oven (turned off) might help too. I haven't had a chance to test out this theory yet... I'll keep you posted.
Step 4: Application and uses
As I mentioned in the intro, depending on the color and the exact proportion of ingredients (it's impossible to be 100% precise and accurate when you are making such small quantities) sometimes the pigments don't disperse quite as well as commercial lipstick. If you are applying it with a brush this is not really an issue, because the brush will smooth and even everything out, but if you are using a tube you may need to smack your lips more than usual, or smudge them with your fingertips.
After making my first few colors what should have been obvious from the start finally struck me: this doesn't need to be just lipstick, it can be used as rouge, or face paint! However, I do not recommend using this to paint the area around the eyes. Some pigments are approved for lips and skin but not for the eyes, and since the specific ingredients are not listed on the crayons I would not risk it.
Update: jfarn01 had a great idea which I want to point out here. Crayons can also be used for making colored shoe polish -- it just so happens that I had already posted a recipe for shoe polish here. Just replace the candle in that recipe with 3 crayons of the color of your choice, and you can finally have a polish which matches your shoes.
For up to date news on what I'm cooking up, check out my new blog.
1-40 of 107Next »
Veronika7 says: May 9, 2013. 6:13 PM
Would coconut oil work as a shea butter substitue?
belsey (author) in reply to Veronika7May 9, 2013. 7:05 PM
The texture of the final lipstick would be much softer because shea butter is solid at room temperature whereas coconut oil needs to be colder. It would be a better substitute for any of the oils.
VanityCalamity says: Jan 24, 2013. 11:46 AM
Ah thank you! I thought I'd ask someone who knew what they were doing before I started changing things on my own. (it won't let me respond in a reply for some reason)
VanityCalamity says: Jan 24, 2013. 8:51 AM
I'm wondering because I wear either black lipstick or a really deep purple, but the purple I finally fell in love with is a limited edition >_< so, doing a dark pigmented Crayons, will the product come off completely opaque and creamy? Or, do you know a way to make it that way? I know it's been a while since you posted this, but any help would be great ^_^
belsey (author) in reply to VanityCalamityJan 24, 2013. 9:08 AM
The way to get the color to be deeper is to use proportionately more crayon... but then the lipstick texture gets harder. One way to solve this is to replace the shea butter with a bit of extra oil. Test the quantities with you non-favorite color until you get the texture you want. Wait at least an hour for the lipstick to cool completely before you judge your results. Of course you can put it on your lips as soon as it hardens, but to get a feel for the final texture you have to wait.
irishwhistle says: Feb 15, 2010. 1:56 AM
Interesting... and we have such a lot of old crayons around here, as well as a 12-year-old girl who just started make-up... but a lot of the ingredients, while familiar, are a little bit exotic for my usual shopping list. Where might you find things like jojoba oil, shea butter, lanolin, etc, if you don't usually keep them around for other projects? I have to think that this would make it a not-so-inexpensive project, also, for someone like me who only has the crayons so far, which is a shame because when I see something like this I just want to head straight in and try it.
This would be great for Halloween... yellow-green lipstick, or if I remember my old crayons right... green-yellow instead. That always confused me. I suppose these days they just call one of them chartreuse.
Easily a-Mused in reply to irishwhistleDec 22, 2012. 7:41 PM
Coming in REALLY late to the party, but in case someone else happens upon it... Lanolin can be found with bottles and breast feeding supplies in the baby section of most supermarkets. Purple bottle, brand name of Lansinoh. The rest is usually at health food stores and such-like.
Kaffe in reply to irishwhistleDec 29, 2010. 2:35 PM
Whole Foods might have it, as well as any 'health' store.
belsey (author) in reply to irishwhistleFeb 15, 2010. 5:14 AM
I'll update the instructable with more details, but the short answer is I've found these ingredients in health food stores, grocery stores like Trader Joe's (for the jojoba oil) in pharmacies (cocoa butter, jojoba) and even on the streets of Brooklyn (African incense vendors usually also sell tubs of shea butter). Also lots of online stores, like the source I linked to for purchasing the mold. You can also replace the jojoba or castor oil with pretty much any high quality vegetable oil in your kitchen cabinet. Texture and taste will vary of course, but it will still work.
GummiBear says: Dec 21, 2012. 8:28 PM
Would this, like, taste horrible? Because from past Dares of licking crayons, they taste...horrible.
rrkrose says: Jul 24, 2012. 10:07 PM
This seems like a lot of fun! I will have to try it soon.
SharieAlexandria says: Jun 29, 2012. 8:57 PM
I love this idea and I cant wait to try it. I'm a BIG lipstick fan and I'm always trying out new colors and I was really hoping to get into the business of creating my own line of lipsticks one day and seeing diys like this really makes me want to experiment more and start getting myself out there.
Thanks for the recipe!
kperez6 says: Apr 30, 2012. 4:30 PM
Thank you very much!!! Me and my friend have already made 3 of those!!! We totally love it! right now am wearing it and it looks really pretty!!!!!!! Thanks again!!!
mon_star says: Apr 12, 2012. 5:31 PM
awesome tutorial. I can see how this could be incredibly addicting.
thatdamnragdoll says: Feb 4, 2012. 1:08 PM
I've been having some trouble with getting the crayon-shea-oil mixture to be as opaque as I'd like. I've experimented with it a lot, but I just can't seem to get it right. What's the magic ratio for those of you who have gotten it to work?
belsey (author) in reply to thatdamnragdollMar 22, 2012. 8:18 PM
If you want more pigment you can use a bit more crayon -- omit the shea and replace it with a bit more oil to get the texture right, otherwise if you just use extra crayon (i.e. wax) the lipstick will be too hard.
sarahnedz says: Feb 20, 2012. 11:13 AM
I just tried this and it works great! It stays on better and feels so good. I love it!
Mauigerbil says: Jan 16, 2012. 7:16 PM
Oh fine. I used only olive oil and a pink crayon. Only a touch of olive oil, or it will be too watery! You need to let it dry in the freezer for awhile, just so that it will be a little dry but still mostly liquid. Then, get a piece of foam or a soft sponge to apply. It is best to make in a paper cup that is disposable, and then cut most of the cup off so that it is easy to apply. The pink crayon blush gives a very natural look when mixed with a magenta
Mauigerbil says: Jan 16, 2012. 7:07 PM
I altered your recipie and made blush! The Great And Powerful Trixie does not tell her secrets!
mygibzone says: Jan 13, 2012. 1:19 PM
I must try this! I hate how expensive makeup is. I love your resourcefulness!
Queeniewtfbbq says: Jan 6, 2012. 2:53 AM
Great 'structable. I decided to go with three colors. I made a tiny pot of black, a slightly larger pot of pinkish-nude, and a big pot of a wine colored lipstick. For reference, I used just black for the black, a mix of 'Mauvelous' and 'Melon' for the nude. I feel like it has more depth than using a stick of regular flesh-toned crayon. I used 'Brick Red,' 'Scarlet,' and just a tiny bit of 'Cerulean' and 'Violet Blue' for the wine.
If you don't have any of the butters on hand, they're easily substituted with various food-grade oils you have around the house. I used olive and sesame. However, your lipstick will probably be much more opaque.
Thanks again. Such a cool idea. I might get some cheap, pretty tea cups and do something along the lines of the Nars kabuki-themed lipstick set. http://www.narscosmetics.com/holiday-gifts/modern-kabuki-holiday/~/kudoki-kabuki-lip-set
shortone says: Dec 9, 2011. 11:49 PM
http://www.instructables.com/id/For-the-Diva/
Just thought I'd let you know I included you in my guide! I'm not sure if the pictures are showing up properly because my internet is a little weird, but hopefully I'll figure it out tomorrow :)
belsey (author) in reply to shortoneDec 10, 2011. 8:28 AM
Thanks!
Katty May says: Dec 9, 2011. 10:54 PM
Thank you so much, I never have much make-up and I have little sisters with tons of crayons. I think this makes a realy good gift, but I've only ever made one batch, and that was about half an hour ago. Also I just thought I'd say, this makes a realy nice eye-shadow, I tried it with blue and it looks realy cute. Thanks again.
101hellokittys says: Oct 8, 2011. 11:11 AM
thanks! i was searching for a green lipstick for my halloween costume, and this really worked! i used olive oil and cocoa butter and it really was just amazing. thanks again!
belsey (author) in reply to 101hellokittysOct 9, 2011. 2:53 PM
That looks great! I'm glad it worked out, and thanks for posting the picture!
elombaard says: Sep 21, 2011. 4:19 AM
I am a makeup artist and this so cool for fantasy makeup. Can't wait to try it. Thanks for the great idea.
258 says: Aug 3, 2011. 2:45 AM
Plump, GaoLiangZe, simple sense is comfortable lip color, can draw down a lips, soft, smooth, sexy god color.MAC lipstick, ensure the permanence of formula can provide around-the-clock wet ze, comfortable feeling. Double lip present the absolute light feeling, crystal color and luster show excellent
neetz says: May 9, 2011. 9:03 PM
this is the neetest instructable i ever saw! i already made red and it works better then real lipstick ! and to top that of it only took like five minutes!
very good!
neetz says: May 9, 2011. 4:34 PM
thanks for the quick response! il try it out!
neetz says: May 9, 2011. 3:18 PM
could you use olive oil or canola oil instead of jojoba oil?
thanks
belsey (author) in reply to neetzMay 9, 2011. 4:10 PM
Yes, you can substitute the jojoba with any number of comestible oils, including olive or canola (though I haven't tried either). Depending on the oil it might taste or feel slightly different, but it should work with any.
Petalostemon says: Mar 26, 2011. 1:47 AM
Hi, I love this idea thank you so much! I'm really big on lipstick, ravishing red colours especially, so I had to try it out. I made mine with cocoa butter and jojoba oil because that's what was available. I made 6 different batches so that I could experiment, they all came out great but I have just one question. Is there a way I can make the final product less glossy? I want it to be more thick and rich and uhm..... pasty I suppose? I tried lessening my portions of butter and oil but it still seems to go on quite glossy. Is there a way to make it thicker and matte? Or is it just a glossy kinda' lipstick? Either way I love it and I'm so glad I don't have to go out and hunt for the perfect shade!
belsey (author) in reply to PetalostemonMar 26, 2011. 8:24 PM
You can vary how glossy it is by playing with different types of oil and proportions. Castor oil will make it more glossy, and using a bit more butter (like cocoa or shea) and less oil would definitely make it more pasty -- shea might be better because cocoa butter is harder at room temperature, which might make the lipstick too difficult to apply if you've cut down on the oil.
I've noticed also that when you make a fresh batch it tends to be more glossy, but after a day or two and it sets completely it's not so glossy.
Hope this helps...
Petalostemon in reply to belseyMar 26, 2011. 10:57 PM
I've also noticed that it got a bit less glossy over time an I'm surprised by how long the colour lasts! Thanks so much, I'll experiment some more.
rachelmaryb says: Dec 29, 2010. 10:59 AM
Can you melt the mixture in the microwave?
belsey (author) in reply to rachelmarybDec 30, 2010. 10:17 AM
Yes, but you need to be careful, because wax can sometimes ignite if it's heated too high and too long -- that's why I much prefer the controlled temperature double boiler heating.
glitterqueenofneworleans says: Feb 22, 2010. 12:37 PM
Very cool.  I work with kids and am always looking for cool DIY beauty products.  Has anyone tried this with unrefined shea butter?  I buy it at our local black arts festival every summer and have a big tub.  Just curious if it makes a difference.
SpiroExDeus in reply to glitterqueenofneworleansApr 25, 2010. 2:34 PM
Out of curiosity is that an arts festival for people of a dark colour or a festival for
Occultists of a sinister nature?
Ah the interesting double meanings that English can have.
glitterqueenofneworleans in reply to SpiroExDeusApr 26, 2010. 12:41 PM
Indeed.  The Denver Black Arts Festival is an afro-centric cultural affair.  As far as I know there is little of the Occult involved.  I can't say why they have chosed to call it the Black Arts Festival rather than the African-American Arts Festival.  Here is their website: www.denbaf.org/ if you would like to check it out yourself.  Interesting how the colors of my words has gone from black to red to green. . . how African. . .
1-40 of 107Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
