Step 3Melting and pouring
As soon as all the ingredients are melted and well combined, pour them into your containers.
If you are using the slanted lipstick container prop it up in some rice, beans, or popcorn kernels like I did. This will allow it will set at the proper angle.
Wax contracts as it cools, so you will get a dent, or maybe even a small hole in the center of your tube. You can reduce this effect by tapping the container on the counter as it cools, but if you try topping it off with more wax chances are the extra drop you add will come off when you use the stick. I have a theory that plunking the tube in a cup of hot water and letting it cool super slowly would help too: if the sides cool at the same rate as the center, no hole should not form, instead the whole level would go down a bit. Putting it into a warm oven (turned off) might help too. I haven't had a chance to test out this theory yet... I'll keep you posted.
I hope this helped! Your lipstick is awesome.
