3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make pizza with a plasma cutter, a backhoe and a pile of mud!
After several years of baking in North House Folk School's wood-fired brick oven, I decided to build an oven of my own. I went a little crazy with extra features (slab foundation, arches, ash dump, chimney, doors, wood storage) and decorations (limestone around the foundation), but you can make a very usable version in a weekend with salvaged materials and a couple of friends.
The place to start is Kiko Denzer's "Build Your Own Earth Oven".
I also made extensive use of Daniel Wing and Alan Scott's "The Bread Builders", which is a great resource even if you're baking bread in a regular electric oven.
Step 1Bushwhacking, Lumberjacking and Limestoning
We have a big lawn next to the neighboring farmer's field, with a great view of Carleton College's wind turbine. What a great place for a pizza party!
The most obvious place to put the oven was in line with our garden shed, but the whole area was a dense jungle. I spent a day with our Stihl brushcutter, with a saw blade in place of the string trimmer. That thing would be awesome for fighting zombies!
I had to chainsaw out a medium-sized box elder tree as well.
Under all that jungle, I discovered an improbable trove of cut limestone left over from when they built our house in 1973. Too good! I'll use that for the keystone and the stone veneer around the foundation.
80 comments
1-40 of 80next »
Jul 4, 2009. 6:44 AMbeckenham says:
Hello Fritz, Wonderful instructions. About the foundation - did you go below the frost layer, or is that simply a pad? Thanks.
Jul 4, 2009. 6:47 AMbeckenham says:
Sorry - I see that you poured a slab. Have you been through a winter yet? I'm wondering how it's holding up.
Dec 19, 2010. 7:30 AMPaddyKevin says:
I am wondering if concrete pavers instead of a slab over the bed of gravel that you descibed would be the easiest way to go and not have to worry about cracks
Apr 29, 2010. 11:24 AMantonio.carrillo.bolea says:
Made my own earth oven!!! After several re-readings of your proyect, I finally made it! I work in a proyect located in southern Veracruz, México, and we are fortunate enough to have clay everywhere... (www.losamigos.com.mx).
I want to post the memories about the construction I wrote on our blog.
http://estampaverde.blogspot.com/2010/04/fiat-panis-o-de-como-hacer-un-horno-de.html
Its in spanish, but anyways... I might try the wood door because there isn't any metal workers around!!! Any advice on baking??? How long shall I leave the oven to dry before starting a big fire???
Apr 8, 2010. 6:18 PMmaterials says:
fritz-what would you say to topping off my adobe bread/pizza oven with clay brick and a mortar mix w/perilite? the oven works nicely as is but to make it more wisconsin weather-proof- i don't want to make a shelter for it because of where it is located nor keep a tarp over it except for winter weather-i've been thinking about it and i can't see any reason that it would disturb the tempertures-i would really like your opinion on this thought-bev
Mar 23, 2010. 10:20 PMabadfart says:
very nice i might make one for my self
Mar 14, 2010. 3:59 AMPaddyKevin says:
Greetings.  I have questions if you do not mind.  First, if, like me, metal work is not going to be practical, what would you suggest the doors be made out of?
Second, I was wondering if you thought of using the bottom area as a bbq smoker, with a tad of alteration I suppose
Kevin
Buffalo, NY
Mar 14, 2010. 8:26 AMPaddyKevin says:
Thanks so much.  That temperature controlled blower sounds good, but I like things as simple as possible.  Living in a similar climate as you, I am concerned with having to cover the oven with a tarp, but I suppose a protective wood structure around it after it is built might be neat, especially as you say if it is designed to allow moisture to leave
Jul 14, 2009. 8:25 PMmaterials says:
time to mix up some more clay and perlite! fritz thanks so much for your help
Jul 14, 2009. 6:08 PMmaterials says:
fritz: my mudd was cracked so badly i ended up taking it apart and starting over with new mudd yesterday-well i have it covered with plastic and it's doing some cracking close to 24 hrs later-question for you: how long after you did the mudd balling did you start the second layer of insulation? p.s. send good clay!!!!
Jul 10, 2009. 6:23 AMmaterials says:
fritz: i ran out of mud on the thermal mass (step six)-i'd say i got about 21/2 to 3 in. around sand dome-my question: now that i've got more clay is it possible to add it on to what is there or do i undo all of it down to the sand mound and start over again? one more thing i wanted to add is that i'm seeing cracking through-out it and i was very precise about adding 2 parts sand or more to the 1 part clay-is this also a problem on how my oven will function? help!!!!!!!!!
Jul 10, 2009. 11:34 AMmaterials says:
(removed by author or community request)
Jul 4, 2009. 12:23 PMbeckenham says:
Fritz, Thanks for the feedback. If it can survive MN then I guess it can cope with IA! I appreciate the advice.
Mar 25, 2009. 6:10 AMRouxyou says:
I have been wanting an oven in my yard for the last two years much was total material cost?. LIving in Florida, there is an issue with clay and mud.
Jun 25, 2009. 5:05 PMkoyaniskatzy says:
I'm in Florida too and been recently working out in the yard. I started digging to install a pond and about 3 ft down the way the soil turned red. Would that be the clay layer? It doesn't crumble easily, and the clumps look like actual rocks. Rouxyou: Have you found more info? I'm planning on building an outdoor grill and an oven would be great since I would also like to learn how to make my own bread. Great Instructable!!!
Jun 28, 2009. 5:24 AMRouxyou says:
I bought the book Build your own Earth Oven by kiko denzer. Thats as far as I got.
Jun 25, 2009. 8:18 PMkoyaniskatzy says:
thanks, would it be too much too ask for the name of the book? My library catalog didn't pick any Denzer, and I may have to request it on swaptree. thanks again!
May 11, 2009. 9:19 PMmaterials says:
recieved my "build your own brick oven" and i have been reading it - i'm calmer now that i have it-but have to add excited to experience it in the making-have my foundation hole almost finished to add the gravel-thanks to you too -i'm going to do pictures of the steps to give to my grandchildren and perhaps build a little one with the almost 6 yr old if he would like-i've enjoyed ever so much your direction and replies and want to ask if the roof you had talked about making for yours in the works yet? bev
May 8, 2009. 7:33 PMmaterials says:
fritz those doors are beautiful!!!! hats off to the artist-bev
Apr 27, 2009. 7:47 PMmaterials says:
you are brave with that minnesota weather to do that and know about the float-i have reasons for not pouring a ground foundation and opting for the 4ft dig-all i can say is thank you so much for your prompt and helpful replies-i am so excited to get the digging going but alot of rain and chilly yet-good day here and there=just have to be patient-you've been great!
Apr 25, 2009. 9:29 PMmaterials says:
hi fritz: thanks for answering back-you are so right about the confidence to build this-i want it to last for awhile and i do look forward to reading the book-cart before the horse in plans-digging 4ft down is the biggest chore soon for the frost line then doing a 4corner cement cinder block base........getting back to the question of "insulate w/paper-i'm calling it your step 10-and NO i wouldn't want that to happen to my bread making-all that work and to have that happen-back to the base-you didn't do that and i know what kind of weather winter can be for you too-i know the oven is heavy but i'm concerned about the heave and cracking the clay-were you concerned for yours?
Apr 23, 2009. 9:24 PMmaterials says:
fritz: i was thinking of using high fired clay that i can buy from a pottery shop here-with your expertise knowledge can i do that?instead of the dig & find and add? for my lst layer over the sand mold then insulate with paper and again use more for the outer insulating layer and place some brick , tile or metal design pieces.......will this have to have a roof for mid wisconsin weather-alot of question i know -have to wait for order on denzer book and want to get materials purchased-thank you bev
Apr 15, 2009. 6:51 PMmaterials says:
does the mudd have any cement or mortar mix in it? bev
Apr 15, 2009. 8:08 PMmaterials says:
thank you so much-i can't tell you how nice this looks and again your directions are great! thank you for sharing this and the great pics-i hope you,friends,and family are enjoying alot of pizza!!! bev
Apr 15, 2009. 6:45 PMmaterials says:
sorry-it's filled with bottles, woodchips-etc.bev
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:fritz.bogott
Fritz Bogott writes bread and bakes stories in an oak savanna just outside Northfield, MN.
