Tired of simple or sissy planters? Do you want more attitude flowerpots? Well, it's your lucky day, because today's instructable is about how to make planters using cheap stuff.
Due to the extremist group "Sons of the Atari" protests (see "Rob Zombie" comments), I won't use joysticks (just kidding, boys!) but a damaged coffee machine funnel, a feet deodorant cap and a Cologne cap for these "three amigos".
What about the green? I will plant cactus, because they will look beautiful in the smaller pots, don't need so much water and will be awesome as the "robo-planters" pilots! (and my friends of Cyclus Ecodesign want to buy my planters with cactus especifically, so my daffodils have to wait).
Well... LET'S GET GREEN!!!
Step 1: As always, the initial and useful Blablabla:
1. If you don't have it, replace it!
2. Use protective equipment (dust mask and goggles)
3. Beware of drilled and soldered hot surfaces
4. Work in a good ventilated area.
5. Always have junk in stock
6. Enjoy!
(7. Don't put your thumb on the way of a high speed drill bit. It hurts... a lot!!!)
TOOLS
tweezers
screwdivers
scalpel
pliers
Dremel Rotary Tool
And don't forget instant glue for fix the joints.
Step 2: Planter Man
MATERIALS:
1 damaged coffee machine funnel
2 Oven knobs
8 iron pieces for picture frame
2 small iron angles
1 roll-on deodorant balls
screws and nuts
Copper wire
Rubber hose (for the wire)
1 Heat gun nozzle (What I did with the rest of my damaged heat gun? Wait for my next instructable!)
1 plastic cap (for the hand)
2 plastic cylinders that fit with the nozzle and the cap.
Step 3: Bobby Da Crab!
MATERIALS:
1 Cylindric deodorant cap
2 small iron angles
16 iron small pieces for picture frame
2 black vents (from a joystick)
2 roll-on deodorant balls
Copper wire
2 alligator clips
screws and nuts
2 black plastic pieces for the eyebrows
Step 4: Globule
MATERIALS:
1 half metallic sphere (You can find it in some Cologne caps, like "Boss in Motion" by Hugo Boss and its cheap imitations, like this case)
2 iron pieces for picture frame
2 electric sockets
2 metallic clips form car lighter plugs
4 small iron angles
2 Oven knobs
A damaged camera lens
screws and nuts
Step 5: More ideas?
With the other half of the Cologne sphere, I made a Globule 2.0, using a damaged circuit as eye.
Now, it's up to you!!!
Visit Our Store »
Go Pro Today »
I see a lot of "picture hangar" pieces here, the iron strips with a hole on each end and teeth in the middle. Those pieces are for mounting on the back of a picture frame and are used to hand pictures on single nails on a wall. Maybe you could use those or bend them into "iron angle pieces" for your projects.
And, my dad always has some junk lying around so... :)
Would he notice if his junk is disapearing?
-R
just love your POT'' family, very creative
i wanna...
