3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make replacement pads for a cycling helmet.
This is how I made a set of replacement pads for my cycle helmet.
The cycling season is about to begin so I decided to spruce my cycle helmet with a new set of pads.
I have a size 8 head which is difficult to get a helmet big enough for, I bought this  XL helmet about 5 years ago (the biggest available then) and spend a very long time with a sanding pad to get the helmet to fit.  I recently tried to find a helmet big enough and found only one company that makes a street style helmet and even worse I could not find a single retailer that had one in stock all stockist where sold out.
The helmet had been sitting in storage for the last few years as only took up cycling last year again when I bought my cruiser.  The existing pads had become very worn and grubby looking so I decided to replace them until I could find a retailer who has a helmet the right size.
To make the pads I car window demister mitt that i bought in the poundland store. It was made of suede and microfiber cloth backed with a very thin foam pad.
I prepared the pads and then got my mum to do the sowing, I have driven a sowing machine before but not all that well so decide to get someone to do it properly.
I hope you find this Ible useful, thanks for looking.
Step 1Marking out.
Marking out.
I started by cutting along the seam of the mitt until I had two halves.  I was originally going to only use the suede side but there was a seam across the middle of the suede that would have been uncomfortable  on the pad that sit on my forehead.
I used the old rear pad as a template and used paper templates to make the outer pads for cutting.
The front pad was cut from the cloth side.
The 2 layers of the mitt are not joined together so i decided I would get my mum to sew them with an overlocking stitch on the sewing machine.  If you cant sew or have no access to a sewing machine the 2 layers could be glued together with a contact adhesive spray.
2 comments
Mar 1, 2011. 9:00 PMCrazyHowiesBikes says:
I too have a large head, and a helmet with worn pads. I think I have one of these mitts lying around. Thanks a bunch!! I'm going to do this tomorrow!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
117
Author:Dr Qui
Currently under no fixed agenda, just going with the flow. All projects are designed to be low cost and to be a simple as possible using recycled and re-purposed materials. Andy.
