3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make rope out of dead plants -- with no tools
Step 6Reverse wrap
Reverse wrap
This is a highly tactile activity, so instructions can only go so far. Bear with me as I explain the reverse wrap from several different perspectives. Refer frequently to the diagram and video, but also experiment with different techniques.
Start your strand
About a quarter of the way along the strand, twist a short segment in opposite directions to form a tight loop. (Twist away from you on the right hand side, towards you on the left.) Pinch this loop with your left thumb and forefinger.
There are now two strands, one closer to you and one farther away.You are ready to start.
Wrap
For each iteration:
1. With your right thumb and forefinger a centimeter from your left, twist the farther strand "away" (clockwise if you are looking from the right). It should be twisted tightly, but not starting to loop. This step is called "twist away".
2. Use your (right) middle finger to clamp the closer strand to your (right) forefinger. Rotate your wrist 180 degrees back towards you, swapping the strands. This step is called "take back".
3. Nudge the Y-junction between the strands with your right forefinger a bit to keep the wrap tight.
Repeat many times!
How it works
Have you ever taken a wall-mounted hand-cranked pencil sharpener apart? (Of course you have.) The two grinders are precisely like the two strands in a reverse wrap. The friction they exert on a pencil represents the friction between the two strands, which keeps them from unwinding.
Alternative techniques
  • If you want to do a quick'n'dirty wrap, twist a long section of fiber until it starts to loop and kink. Allow one kink to grow and twist. (The first time you do this, have another person help you by gently twisting the forming rope.)
Time required for wrapping
Unlike the previous steps, this one is variable according to your needs. Here I have used the entire three-foot bundle for the starting cord, but I would ordinarily separate the bundle into several 3-foot sections to be spliced in later. This results in a much thinner, longer cord. If you divide the stalk into 2 3-foot sections, the cord will be half the width and twice the length, but will take something like *four* times the amount of time. (Twice as many twists per inch, twice as long.)
Show your work!
Upload pictures of your finished work into the comments.
17 comments
Aug 19, 2011. 8:14 AMrileius says:
Once you get through all of your cordage you can fold the rope over itself and do the reverse wrap step again, except you twist towards you and put forward
Jul 24, 2009. 12:47 PMsavain says:
how do you do the reverse wrap if you would have three or more pices of fiber than two? asome intestructable by the way:D:D:D
Jul 28, 2009. 10:12 AMgallop28 says:
with three or more strands you do exactly the same thing - you twist outward and take back - first becomes last.
Jul 24, 2009. 1:05 PMsavain says:
i have find a way:D:D it drivd my nuts that i did not could find i solusion so after i little more try and error i find a way. it is mutch harder, you must now with fiber you sould wrap. so you dont wrap one fiber 5 times and the orther 2 times. very difficult if the fibers look a like. but it is possible:D:D:D
Jul 24, 2009. 12:54 PMsavain says:
i have tryd it and it dident go well. it dont gett that rope pattern it just become a ball sort of.
Apr 27, 2008. 9:20 AMRaisedByRobots says:
It'd be interesting to see a video of how you splice in new strands with the reverse wrap.
Jan 27, 2008. 1:58 PMMOBucky says:
If I understand this correctly, the twist-away turns one fiber onto itself, then take back twists the two cords together. Is that right?
Aug 2, 2007. 10:55 AMnhpr says:
After watching a Ray Mears show, I was looking for some detailed instructions on how to make cordage. Unfortunately for me, I only found this website weeks after learning bits and pieces through multiple poorly-written, confusing websites. I wish I had found this one first.
Jul 24, 2007. 2:52 PMilikefireworks says:
i like the instructable. also since i just came home from camp, we were making small ropes out of paper towels(the brown ones that u find in bathrooms) and we would get them wet with our hands and then twist the whole thing and bite in the middle then twist both sections together and i will make a instructabe for it
Jul 10, 2007. 11:15 AMbeastbunny says:
A very interesting Instructable. We used to do this with young tree bark as kids. In rope and yarn making this step is called plying. Just FYI.
Jul 12, 2007. 11:29 AMMeragness says:
this is so cool! and that pencil sharpener explanation made it very clear for me!
Jul 1, 2007. 1:19 PMhighwaykind says:
Twist the strands clockwise, and wrap them around each other counter-clockwise. You can also braid your hair this way (which is how I knew how to do it...gets nice curls), but I didn't know you could use plant fibre to make wire!
Jul 4, 2007. 5:12 PMmymothermeatloaf says:
wow!! awsome dude!! i used that wrapping technique for cotton rope i made from my worn thshirt
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:phyzome
Software Engineer at Basis Technology. (Current as of August 2011.)
