Requirements:
TELESCOPE
1. Lens (Long focal length)
2. Webcam CCD circuit
3. 50mm camera lens
4. 60/50mm (Diameter) PVC pipe and joints
TRIPOD
1. 20/25mm (Diameter) PVC pipe/Joints
2. Nut & bolts
3. Mount
Construction:
1. At first select a long focal length lens, better to use compound lens to avoid chromatic aberration. Here I used high range binocular lens, focal length is 180mm.
2. Next pick a 50mm SLR camera lens ( I have used 50mm SMC Pentax-A) and remove all the lens elements from it and keep only aperture mechanism, this is used as aperture to control the light.
3. Fix the selected lens in front of the camera lens hood, this will act as fine tune focusing (Secondary focusing). And fix about 4 inches length 50mm pipe at rear. (if u have Pantax-A lens, it fits inside 50mm pipe)
4. Take 50mm pipe joint and scratch its inner surface (to increase its inner diameter, about 2mm) so that 50mm pipe moves freely forward and backward , this is act as primary focusing.
5. Take a 60mm pipe , fix its joint at the rear end and fix the 50mm joint inside at other end. The length of the 60mm pipe you should keep according to the focal length of lens that you have selected.
6. Cut a 60mm dia foam sheet ( or similar material) and fix webcam circuit , its ccd sensor should be at the centre of foam sheet. Make the ccd area maximum dark , perpendicularly about an 35mm from ccd make 2-3mm hole, this act as secondary aperture.
(Checkout construction schematic, step -10)
Remove these ads by
Signing UpStep 150mm Pantax-A lens
Great one and made me wanna do something like it. I found a Tele-Auto 6.3/400 mm lens but as I know nothing about lenses would a thing like this work? Or would it be better to buy something thats called like: Sigma 70-300 mm F4-5,6 DL Macro Super?
Im have not worked anything with camera lenses before so any input would be great =)
Thanks for a good one!
Well, with 400mm lens u can do easily, no need to de-assemble it. You need to provide a dark area for CCD (Tube-B) and a lens mount (Tube-A).
The following schematic will help you, checkout...
What I did not understand with this lens I was looking on was the 6.3/400 (and differense on a 70-300) but maybe that dont mean anything else than its just a 400 mm but I would guess its better than a 300.
As I been looking for telescopes to connect with computer none has by my meaning met any of the range and quality you actually can gain by doing it by your self.
Big thanks =)
You have to play with light adjustment, with aperture. At day time larger F number will give good result. I hv checked with my 28-105mm Nikon lens, i captured in the morning around 7.30-8.00, sun. so image has come little dull. :-)
That's all I can say. Good luck!
I suggest you make an equatorial mounting (it is easy), so you can use it for look planets, stellar cloud, etc.
thank u...
and one more thing to watch moon surface how much focal length (lens) is required?
