3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make stylish yet inexpensive curtain rods
Step 7Hang your curtain rod on the wall
Once your paint is completely dry (24 hours) you just have to screw your brackets to the wall, stick your finials in the rod and clip the rod into the brackets. It's best to screw into a stud, of course, and generally there will be a stud (or two) right beside the window. Also, be careful to line the rod up right in the middle BEFORE you clip it into the brackets because the little bump on the brackets will scratch the paint off the rod if you try to move it after it's clipped in.
That's it! Now we just need someone to create an Instructable on how to make no-sew $5 curtains... ;)
13 comments
Sep 3, 2011. 9:17 AMmpate2 says:
HI Steve my windows are 128" wide. If conduit only come is 10' lengths at its longest do you have any other suggestions? Thank you so much for you time! :o)
Mar 13, 2008. 3:53 PMKornelas8286 says:
Hey for the non-sewable curtains you could use your hot glue gun on heat safe fabric and a tape measure to calculate and measure before you cut. Careful to add the extra inches for seaming and folding the holes for the rod. Seam up ends with the hot glue. And glue the pieces together. Great Ideas on the rods!!! Thanks
May 28, 2009. 6:26 AMnubianepiphany says:
Another tip: To make your diy curtains hang properly, purchase some medium to large sized washers to insert into the corners of your curtains--makes them hang properly. Good curtains always come with weight hangers. To install: first, make sure that the washers will be the correct size for the type of fabric that you'll use. Next, either spray the washers with some type of rust-protectant or simply wrap them in duct tape. Before you make the final fold for the corner, simply sew the washer in and then make your final fold to complete the corner. Your curtains should hang very nicely and you won't have rust stains ruining your nice fabric!
Feb 19, 2011. 6:12 PMPinky212 says:
Some decorators use "curtain chain" that does the same purpose. It runs the total width of the curtain. An inexpensive substitute can be found at the hardware store, I'm sure.
Apr 26, 2011. 3:49 PMlauris says:
Ball chain. It's the very same stuff. Also what they use for lamp pulls and dogtags. Most hardware stores will have it cheap.
Feb 19, 2011. 6:10 PMPinky212 says:
I'm not going to create an Instructable for many reasons, one of which is my health. BUT, you can make inexpensive churtains by going to a thrift chop, finding what you need there. If the curtinas you find have pinch pleats and you don't want them, cut them off straight across, and using either a hot glue gun (as another person suggested) or hemming tape or other bonding material that is sold by the yard which you'd have to cut into strips, fold over at the top an amount enough to accomodate your rod + 3/4" and fasten the edge using the hemming tape or other fusible web material.
Burlap is relatively inexpensive and looks great when you fringe the bottom. BalladDesign.com, a high end home decor venue, has these for lots of money. Take a look anyway because you'll get an idea how neat they can look! Remember, though, burlap comes in a few different weights/ To get the look of a decorator curtain, use one of the heavier weights.
I've used old lace tablecloths, old rayon, old silk, and old cotton tablecloths with clip rings for curtains. They are especially cool if you're not going to be pulling them closed, using them as a side curtain with some type of blind that you can raise for light control.
If you're lucky enough to have old wool blankets, especially those with a pattern, or old quilts, these can be used with clip rings, too. An old matellase (a woven raised pattern) bedspread or other types of fabric bedspreads can be used, too. Slipcover throws are big, too, and should be considered.
Anything you can use with clip rings can be made to put directly (shir) on the rod, EXCEPT quilts or othings that would be too bulky to gather.
Check garage sales and flea markets for anything made with large pieces of fabric. Just be sure to leave the fleas and bed bugs at the market. LOL
Aug 25, 2010. 7:08 PMFrank_the_Bunny says:
Thanks for this great project. I live in northern Canada and only have ONE hardware store close by...and all home decor is only available from Sears! I will be using painter's drop cloths for my curtains.If you want a cheap no-sew curtain, get these and some curtain clips and VOILA! They also look great with bamboo blinds...Here is a picture of someone else's drop cloth curtains - just be aware that all drop cloths will not look "exactly" the same even if you purchase the same brand and size. The best part is they are already hemmed! (Also, the best way to wash is straight from the washing machine and HANG DRY for the least amount of wrinkles, I would pre-wash as well as they will shrink a little.)
Feb 19, 2011. 5:07 PMPinky212 says:
Frank, thanks for mentioning the painter's drop cloths! I'd completely forgotten about them and have been struggling with how to be thrifty while changing my decor. The window that is my biggest challenge is 103" wide and I want a covering at least 84" long, preferably 90". Being the painter's cloths come in various sizes AND because they are all cotton, they can be dyed or bleached so I can customize 'til my heart's content! They could be stenciled, trimmed on the edges with beads, braid, ribbon, etc. I'm a seamstress but can appreciate the value of a product, and the painter's cloths definitely give a lot of bang for the buck! I'm going for a white color design choice, and these will give another texture to the room, something a monochromatic color scheme depends on for success. Thanks!
Aug 25, 2010. 7:12 PMFrank_the_Bunny says:
Forgot to add these are cheaper than bedsheets and have a nice hefty feel to them as they are 100% cotton canvas.
Nov 9, 2009. 12:30 PMGeekTinker says:
This is an inexpensive and easy way to make curtains for this type of curtain rods:  www.wikihow.com/Make-Curtains-from-Bed-Sheets
May 16, 2009. 7:15 AMtwogirls says:
We bought curtain rods, but are taking them back and making our own. Making them also prevents having to look at the two different sized rods where they connect together, it's ugly and never ends up hidden under the curtain! This is a great tutorial, when we have ours made I will try to post them here! Thanks for sharing!
Oct 31, 2008. 4:30 PMcelticstar says:
Thank you so much for this share. I bought 2 curtain rods for $160.00 and I am taking them back. I am going to make my own and spent the money I save on good fabric for my curtains and other things I need.
Nov 1, 2008. 4:46 AMcelticstar says:
Thanks Steve for the encouragement. I just hate to go into hardware stores because most of the people that work there are so miserable to deal with. But if I want to make those rods I will have to deal with them. I will get creative with my finials. When I am finished I will post a picture.
Dec 11, 2007. 5:47 AMmguer133 says:
or go to Ikea and get a few 99c brackets and a 5$ 3m rod...
Jan 10, 2008. 5:19 PMdianaw says:
well, by the time you drive to Ikea, (if you are "lucky" enough to have one near you)pay the tolls and gas and fight the traffic and parking wayyyy down the other end of the lot, get inside, locate the item, or where the item is supposed to be and realize they are out of it, I think I'd rather go to the hardware store a half mile away.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:SteveGerber
